Author Topic: [Solved] Hide ULX Commands for Spectators  (Read 8045 times)
Offline allofmywutsteam
  • MNWO Owner
    • MNWO Discord
« on: October 01, 2016, 10:12:10 am »
ULib v..2.6 // ULX v..3.70 // Game mode: TTT
When players are spectating, they can still run commands (ignore the target). This can cause an issue when they're showing up as alive (TTT).
I'm curious if I can HIDE the command ONLY for spectators? And leave it alone for those alive (obv).
To add to it, if inheriting from respected/admin/superadmin/owner/whatever, then this does not apply for them. So basically everyone below 'respected' will have their Spectator commands hidden to LIVE players, but will show to other spectators.
Update (10/04/2016): the "Everything else" color config section affects @admin chat and User Management echoes. I changed the color to a unique blue color. It's also covering other ULX commands, so it may be the ULX echo color (one of them).
The
« Last Edit: October 04, 2016, 07:19:58 am by allofmywutsteam »
Re: Hide ULX Commands for Spectators
« Reply #1 on: October 01, 2016, 10:14:28 am »
From what I know about ttt, I don't think you'd be able to change the colour. If you mean when spectators use a command and their name is yellow vs green, right? That's just a default ulx thing I believe. Not sure you can change it.
« Reply #2 on: October 01, 2016, 10:41:57 am »
You can disable team coloring. It's in the XGUI settings, under the server tab. Commands and echos, I believe.
« Reply #3 on: October 01, 2016, 10:53:45 am »
Well there you go.
  • MNWO Owner
    • MNWO Discord
« Reply #4 on: October 01, 2016, 02:51:13 pm »
I'm pretty sure that may have worked. I just mimicked the color for other players. Except, what else may this effect?
« Reply #5 on: October 01, 2016, 03:02:14 pm »
snip
Nothing---though, you'd probably want to keep the "everything else" setting different. I forget what that applies to.
Changing the "Color for players" option only makes player names in chat that color if "Show team colors for players" is disabled. That's it.
  • MNWO Owner
    • MNWO Discord
« Reply #6 on: October 01, 2016, 03:08:30 pm »
Okay thank you. Ill wait and see what changes
