Author Topic: How does system.GetCountry() work?  (Read 4560 times)
« on: October 11, 2016, 04:35:46 pm »
Just realized... I make a lot of threads here.
Anyways, I was wondering how system.GetCountry() works. I want to have it so that when someone joins a server, they will see {the 2 letter country code} | "their name" has joined. I've tried using this:
  1.
  2.
  3. if SERVER then
  4.
  5.
  6.    util.AddNetworkString( "Get Country" )
  7.
  8.
  9.    net.Receive( "Get Country", function( len, pl )
  10.
  11.       userCountry = net.ReadString()
  12.       print( userCountry ) -- Tried to debug. Nothing prints.
  13.
  14.
  15.    end )
  16.
  17.
  18. end
  19.
  20.
  21. if CLIENT then
  22.
  23.
  24.    hook.Add( "PlayerConnect", "GetCountry", function( name, ip )
  25.
  26.
  27.       net.Start( "Get Country" )
  28.          net.WriteString( system.GetCountry() )
  29.       net.SendToServer()
  30.
  31.
  32.       for k,v in pairs( player.GetAll() ) do
  33.
  34.
  35.          if IsValid( v ) then
  36.
  37.
  38.             v:PrintMessage( HUD_PRINTTALK, "{" .. userCountry .. "} | " .. name .. " has connected." )
  39.
  40.
  41.          end
  42.
  43.
  44.       end
  45.
  46.
  47.    end )
  48.
  49.
  50.    hook.Add( "OnPlayerChat", "Add Country to Chat", function( ply, strText, bTeamOnly, bPlayerIsDead )
  51.
  52.
  53.       local tab = {}
  54.
  55.
  56.       if ( bPlayerIsDead ) then
  57.
  58.
  59.          table.insert( tab, Color( 255, 30, 40 ) )
  60.          table.insert( tab, "*DEAD* " )
  61.          table.insert( tab, Color( 255, 255, 255 ) )
  62.
  63.
  64.       end
  65.
  66.
  67.       if userCountry != nil then
  68.
  69.
  70.          table.insert( tab, "{" .. userCountry .. "} | " )
  71.
  72.
  73.       end
  74.
  75.
  76.       if ( IsValid( ply ) ) then
  77.
  78.
  79.          table.insert( tab, ply )
  80.
  81.
  82.       else
  83.
  84.
  85.          table.insert( tab, "Console" )
  86.
  87.
  88.       end
  89.
  90.
  91.       table.insert( tab, Color( 255, 255, 255 ) )
  92.       table.insert( tab, ": "..strText )
  93.
  94.
  95.       chat.AddText( unpack( tab ) )
  96.
  97.
  98.       return true
  99.
  100.
  101.    end )
  102.
  103.
  104. end
Using the help of the code here but it doesn't print anything. It has no errors, it just doesn't do anything. I put PlayerConnect hook in the CLIENT as it's shared, so I thought it could, because I thought I could run system.GetCountry() in the client and it will get the client's system information, but that didn't work. I have this in
garrysmod/addons/Viscosity%20Command/lua/autorun/get_country.lua, is there somewhere else I should put it or is this just not how this function works?
Re: How does system.GetCountry() work?
« Reply #1 on: October 11, 2016, 06:46:17 pm »
Few things I see quickly;
You're setting a variable (userCountry) on the server.
You're then attempting to use the variable on a client side hook (OnPlayerChat).
There's some more that I can't decipher, but that's a big start.
« Reply #2 on: October 11, 2016, 07:01:35 pm »
Derp I can just use PlayerSay can't I since that's a serverside hook that does the same thing? I'll try that out tomorrow..
