Author Topic: ULib attempt to index 'str' (a nil value): praseKeyValues; removeCommentHeader  (Read 5641 times)
Offline Imperial Knight
  • gLua/Web Developer
Hey.
So with an addon I'm working on, it appears I get ulib errors on some of ulib's functions, for some reason. I'll provide each line of code for the error.
addons/ulib/lua/ulib/shared/misc.lua:30 (ULib Code)
local newpos, endpos = str:find( separator, curpos ) -- find the next separator in the string
addons/ulib/lua/ulib/shared/misc.lua:696 (ULib Code)
local lines = ULib.explode( "\r?\n", data )
addons/imbans/lua/autorun/server/ulx_sv_mysql.lua:915 (My Code)
local bans, error3 = ULib.parseKeyValues( ULib.removeCommentHeader( ULib.fileRead( ULib.BANS_FILE ), "/" ) )
lua/includes/modules/concommand.lua:54 (Garry's Mod Dedicated Server Code)
CommandList[ LowerCommand ]( player, command, arguments, args )
I'm a bit confused as to why it's erroring out there. (I've provided the error below)
ULib v2.61 (latest as of now)
ULX v3.71 (latest as of now)
Game mode(s) I am having this problem on: Not relevant: any gamemode.
[ERROR] addons/ulib/lua/ulib/shared/misc.lua:30: attempt to index local 'str' (a
 nil value)
  1. explode - addons/ulib/lua/ulib/shared/misc.lua:30
   2. removeCommentHeader - addons/ulib/lua/ulib/shared/misc.lua:696
    3. unknown - addons/imbans/lua/autorun/server/ulx_sv_mysql.lua:915
     4. unknown - lua/includes/modules/concommand.lua:54
Any help or suggestions with this would be greatly appreciated. If this is an actual issue on ULib's side, I'll create a bug report.
Offline Timmy
  • Code monkey
Are you checking if ULib.BANS_FILE (data/ulib/bans.txt) exists before trying to read it? ULib.fileRead will return nil if the file does not exist. That would cause the other functions to fail, as they expect a string type argument.
You can refer to the source code for ULib.refreshBans to see how ULib loads bans.
« Last Edit: July 11, 2018, 12:11:51 am by Timmy »
Thanks for the reply.
The problem I was having was an addon (custom ban message addon somehow) that was stopping ULX from creating a bans.txt file and instead read the garrysmod/cfg/banned_user.cfg file, which messed with the ULib.BAN_FILE.
