Author Topic: [HELP!] ULX - When a staff member joins they need a pin to get the group  (Read 9966 times)
Offline Scout | Anthony F
How do you add a system where when an admin or staff logs in they have to enter a pin that is 6 letters in length. When they first get admin or staff they need to put a code in. I want this to be stored locally on the disk.
Thanks in advance - Anthony
« Last Edit: October 16, 2016, 02:41:55 am by Scout | Anthony F »
« Reply #1 on: October 16, 2016, 04:29:21 am »
The title says all but I want the min and max to be 6 NUMBERS only numbers.
When they get the rank for the first time (they have to be online) they need to type in their own code.
If you can a command for it to change or remove or add a pin would be good so I can change it if the account gets compromised.
I don't want them to have to type in the command when they get their group I want it to pop up on their screen maybe idk.
I.E !changeauthpin [STEAMID OR NAME if they are online] [new pin]
     !removeauthpin [STEAMID OR NAME if they are online]
     !addauthpin [STEAMID OR NAME if they are online] [pin]
Thanks in Advanced - Anthony
P.S. I don't know if this is the right forum for it.
Re: [HELP!] ULX - When a staff member joins they need a pin to get the group
« Reply #2 on: October 16, 2016, 09:33:36 am »
I don't have the time to write something like this for you, but here's a thought: TOTP-based 2-factor authentication would be an interesting idea to implement. Wonder how hard that would be in Lua.
« Reply #3 on: October 16, 2016, 10:32:37 am »
I would be happy if you could but I don't know much in lua
Offline roastchicken
  • I write code
« Reply #4 on: October 17, 2016, 04:29:42 am »
What should happen if they don't log in correctly? Does this need to happen on every log in, or just the first login?
« Reply #5 on: October 17, 2016, 07:31:00 am »
This sounds interesting, I'd like to see something like this, too. Do you have a Github repo of this? Or are you just doing it locally? I'd like to help :D
« Reply #6 on: October 17, 2016, 11:19:15 am »
Everytime they log back in. this will activate and tell them to enter their pin. Another server has it. But it isn't vgui just a command I think. I messaged him about it. He just told me what is already is - login they enter pin to get group.
I already know that
« Reply #7 on: October 17, 2016, 11:22:47 am »
I'll certainly give it a look. It's a good idea, roastchicken if you want to work with me on it I think it could be interesting.
« Reply #8 on: October 17, 2016, 11:42:53 am »
On the server I was talking about you could ignore it like if you want to rp with no staff perms.
« Reply #9 on: October 17, 2016, 03:35:05 pm »
Ok, so if they don't enter the pin, they're just a "user"?
« Reply #10 on: October 17, 2016, 11:27:13 pm »
Yes. I they get it wrong 3 times they get kicked. That is how it works on the other server
