Author Topic: Make echo visible for players, but not when superadmin use it.  (Read 4301 times)
Offline machond
« on: December 05, 2016, 08:02:35 am »
Hey, I have a question. I made that players see the commands of other administrators (echo 2). However, I want to make the command superadministrator remain invisible.
I set echo to show echo and identify admin. But now i want make exception - if superadmin (or specify group) use command - then echo will be " (someone) slap Nickplayer."
How can i do this?
Thanks for help.
Re: Make echo visible for players, but not when superadmin use it.
« Reply #1 on: December 08, 2016, 10:43:11 am »
This was already answered.
/index.php/topic,10069.html
Quote from: JamminR
This isn't the section to discuss such code, nor would it be easy, or recommended, to change.You'd have to make lots of changes every time ULX updated.d.
Like he said, it would be difficult and tedious to change every update. You can do it, but good luck.
« Last Edit: December 08, 2016, 10:48:25 am by iViscosity »
