ULX Playsound Question
Topic: ULX Playsound Question (Read 24783 times)
Skullhead860
Guest
June 30, 2007, 02:01:17 pm »
Hey i'm running a listen server on Gmod 10 and using version 3.11 of ulx. I got the playsound to function, but im the only who can hear it. I added
ulx addForceDownload "sound/NFR.wav"
ulx addForceDownload "sound/LS.wav" at the bottom of the server configuration file in garrysmod\garrysmod\addons\ulx\lua\ulx\configs. I want to make it so that everyone in my server can hear it. Is there something that im not doing right? thx
Megiddo
Ulysses Team Member
Project Lead
Re: ULX Playsound Question
June 30, 2007, 02:45:34 pm »
Are people actually downloading it when they join? Do they get an error in the console when you play it?
Skullhead860
Guest
Reply #2 on:
June 30, 2007, 02:49:40 pm »
I will check this and get back to you
Skullhead860
Guest
Reply #3 on:
June 30, 2007, 03:06:59 pm »
Ok when the players are connecting i see the SWEPs that are being sent to the client.. but i dont see the sound file..
When i tried to play the sound they got
[LC ULX ERROR] Received invalid sound
and
B Failed to load sound "friends\friend_ingame.wav", file probably missing from disk/repository
in the console
atomicspark
Full Member
Reply #4 on:
June 30, 2007, 03:37:33 pm »
Are you using sv_downloadurl? If so, are the wav's on the host? You must have all maps, sounds, etc. (whatever loads before urls) on the sv_downloadurl host if it is enabled. It basically disables downloads from the server.
Skullhead860
Guest
Reply #5 on:
June 30, 2007, 03:50:23 pm »
Uhh im really noobish when it comes to stuff like this
So i dont know what sv_downloadurl is. Which means im probably not using it...
Skullhead860
Guest
Reply #6 on:
June 30, 2007, 04:01:40 pm »
Here is a screenshot of what i have so far...
Megiddo
Ulysses Team Member
Project Lead
Reply #7 on:
June 30, 2007, 04:19:02 pm »
It's ulx addForcedDownload not ulx addForceDownload.
Hope that fixes it for you!
Last Edit: June 30, 2007, 04:54:40 pm by Megiddo
Skullhead860
Guest
Reply #8 on:
June 30, 2007, 04:30:22 pm »
I didn't realize that i made that mistake... but unfortunately it still doesn't work. My clients are still getting
[LC ULX ERROR] Received invalid sound when i try to play it
Megiddo
Ulysses Team Member
Project Lead
Reply #9 on:
June 30, 2007, 04:54:48 pm »
What do you have in your config now?
Skullhead860
Guest
Reply #10 on:
June 30, 2007, 05:00:17 pm »
Here is what i have after the changes...
Megiddo
Ulysses Team Member
Project Lead
Reply #11 on:
June 30, 2007, 05:04:00 pm »
You need a space between forceddownload and the filename.
Skullhead860
Guest
Reply #12 on:
June 30, 2007, 05:07:44 pm »
Yea i just noticed that after i posted the image... if that was my problem im gonna feel really dumb
Skullhead860
Guest
Reply #13 on:
June 30, 2007, 05:16:16 pm »
I fixed the problem with the space.. but they still get the invalid sound error....
Skullhead860
Guest
Reply #14 on:
June 30, 2007, 05:18:29 pm »
// You can also add forced downloads here. Make sure you put quotes around the path/filename, and take out the comment string '//'.
// Add as many as you want. You can also add these to your map- or game-specific files.
//ulx addForcedDownload "sound/cheeseman.mp3"
ulx addForcedDownload "sound/NFR.wav"
ulx addForcedDownload "sound/LS.wav"
ulx addForcedDownload "sound/MW.wav"
It Looks right to me... Is there any other file that could possibly cause the error?
