Author Topic: ULX Playsound Question  (Read 24783 times)
Re: ULX Playsound Question
« Reply #15 on: June 30, 2007, 05:23:42 pm »
Did you restart the server after fixing the config?
Skullhead860
« Reply #16 on: June 30, 2007, 05:42:51 pm »
Yes i did :(
« Reply #17 on: June 30, 2007, 05:44:04 pm »
Are people downloading the file when they join? Post a console dump of your server start.
Skullhead860
« Reply #18 on: June 30, 2007, 05:54:24 pm »
Mounting Apps From /settings/mount/*.txt
   Mounting App 240 (cstrike) - Ok!
   Mounting App 300 (dod) - No Permission!
   Mounting App 340 (lostcoast) - Not Installed!
   Mounting App 220 (hl2) - Ok!
   Mounting App 380 (episodic) - No Permission!
   Mounting App 320 (hl2mp) - Not Installed!
   Mounting App 280 (hl1) - No Permission!
   Mounting App 360 (hl1mp) - No Permission!
Done!
Not mounting addon/gamemode 'day-of-defeat', requires missing GCF file (300)
Parent cvar in server.dll not allowed (sk_apc_missile_damage)
Garry's Mod client.dll Build #0027 [May 17 2007 16:35:02]
maxplayers set to 1
Heap: 256.00 Mb
Parsed 23 text messages
Adding Font resource/fonts/akbar.ttf
Adding Font resource/fonts/coolvetica.ttf
Adding Font resource/fonts/csd.ttf
Render Targets.. Done!
Couldn't find custom font file 'resource/HL2EP2.ttf'
Couldn't find custom font file 'materials/vgui/fonts/buttons_32.vbf'
Garry's Mod server.dll Build #0027 [May 17 2007 16:35:01]
execing config.cfg
Can't use cheat cvar dsp_dist_max in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar dsp_dist_min in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar r_ambientfraction in multiplayer, unless the server has sv_cheats set to 1.
2 CPUs (1 physical), Frequency: 3.4 Ghz,  Features: GenuineIntel SSE SSE2 MMX RDTSC CMOV FCMOV
GetAllManifestFiles:  Unable to load maplist.txt
execing valve.rc
execing autoexec.cfg
Starting Level gm_construct (Gamemode Override 'sandbox')
maxplayers set to 4
Unknown command "sbox_allownpcs"
Unknown command "sbox_maxprops"
Unknown command "sbox_maxragdolls"
Unknown command "sbox_maxnpcs"
Unknown command "sbox_maxballoons"
Unknown command "sbox_maxeffects"
Unknown command "sbox_maxdynamite"
Unknown command "sbox_maxlamps"
Unknown command "sbox_maxthrusters"
Unknown command "sbox_maxwheels"
Unknown command "sbox_godmode"
Unknown command "sbox_plpldamage"
Unknown command "sbox_playergod"
Unknown command "sbox_noclip"
Unknown command "sbox_maxhoverballs"
Unknown command "sbox_maxvehicles"
Unknown command "sbox_maxbuttons"
Unknown command "sbox_maxsents"
Unknown command "sbox_maxemitters"
Unknown command "sbox_maxspawners"
Unknown command "sbox_maxturrets"
Unknown command "contraptionary_intermission_time"
Unknown command "contraptionary_guess_time"
Unknown command "contraptionary_max_guesses"
execing game.cfg
Network: IP 192.168.1.136, mode MP, dedicated No, ports 27015 SV / 27005 CL
Spawn Server gm_construct
Begin loading faces (loads materials)
End loading faces (loads materials)
Lua initialized (Lua 5.1)
ERROR: Couldn't open Lua file 'particletrace.lua' (Path: 'weapons/weapon_flamethrower')
//  shared/concommand.lua    //
[ULIB] Loading module: ulx_init.lua
//  util.lua                 //
//  fun.lua                  //
//  vote.lua                 //
//  toolmode.lua             //
//  slots.lua                //
1 active EHandles!
ScriptEnforce: gamemodes/sandbox/clientscripts.txt wasn't found. This gamemode is unprotected.
Unknown command "ulx"
execing ulx_aliases.cfg
execing skill_manifest.cfg
execing skill.cfg
Executing listen server config file
Precache of sprites/light_glow02_add_noz ambigious (no extension specified)
Section [Scenes]: 1096 resources total 17.54 KB, 0.84 % of limit (2.10 MB)
4 player server started
couldn't exec listenserver.cfg
No challenge from 68.142.232.33:27243.
Client "Veritas" connected (127.0.0.1:27005).
Connected to 127.0.0.1:27015
Adding master server 68.142.72.250:27011
Adding master server 72.165.61.190:27011
Connection to Steam servers successful.
   VAC secure mode is activated.
No challenge from 68.142.232.32:27243.
[L] Sandbox
Map: gm_construct
Players:  1 / 4
Build 3152
Server Number 1
No pure server whitelist. sv_pure = 0
CSoundEmitterSystem::AddSoundsFromFile:  No such file scripts/sounds/game_sounds_phx.txt
CSoundEmitterSystem::AddSoundsFromFile:  No such file scripts/sounds/dod_game_sounds.txt
CSoundEmitterSystem::AddSoundsFromFile:  No such file scripts/sounds/dod_game_sounds_ger_commands.txt
CSoundEmitterSystem::AddSoundsFromFile:  No such file scripts/sounds/dod_game_sounds_us_commands.txt
CSoundEmitterSystem::AddSoundsFromFile:  No such file scripts/sounds/dod_game_sounds_weapons.txt
CAsyncWavDataCache:  2 .wavs total 0 bytes, 0.00 % of capacity
Initializing renderer...
Precaching Spawn Icons... DONE!
--- Missing Vgui material vgui/entities/weapon_annabelle
--- Missing Vgui material vgui/entities/weapon_alyxgun
--- Missing Vgui material vgui/entities/weapon_citizenpackage
--- Missing Vgui material vgui/entities/weapon_citizensuitcase
Server is running Garry's Mod Version 27 - gamemode 'sandbox'
Waiting for String Tables..
Creating RT Texture 'GModToolgunScreen'..DONE!
Joining Game..
[UCL] Access set.
This server is running ULib version 2.05.
ULX version 3.11 loaded.
Client "Pojo226" connected (141.150.179.175:50822).
Pojo226 has joined the game
« Reply #19 on: June 30, 2007, 06:14:13 pm »
It's not loading your ULX correctly for some reason... What other mods are you running?
Skullhead860
« Reply #20 on: June 30, 2007, 06:19:07 pm »
Hmmm i hope the picture helps... phx is phoenix mod
Skullhead860
« Reply #21 on: June 30, 2007, 07:03:43 pm »
The vehicle folders contain gmow, vmod, and car mod as far as i know
