Offline tsmelinda
ok i found it.
is there a way to make it point to a sql server or is that a separate version?
Use UTimeM for MySQL
Offline tinyanimations
I'm getting a problem with this utime. It doesn't save total time and shows the session time for both. We are using the ULX SVN if that makes any difference.
i have the same problem on my server how do i resolve this??
Do you have the sv.db file set to read-only?
where do i find the sv.db file? and is there aparticular way to check if its read only?
It's in the garrysmod root, check the properties of the file.
ive checked the file and it isnt read only, im using admin mod exsto if that makes a difference?
Offline Botman
I have a question. After messing around with some glitchy mods my playing time on my server has been reset to 0. I removed said mods yet it seems to have saved. Is there any way of setting my play time manually?
Not without a good understanding of SQL...
Offline Botman
Ugh, wouldn't it at least be possible to run some Lua command that orders an edit in the SQL file?
Yes, but you'd still need to know SQL. :P
I have a simple setting command that I'd be willing to give you.
Offline Botman
I would greatly appreciate it.
If you don't mind Aaron113, would you post it here for the future benefit of everyone? :)
local CATEGORY_NAME = "Custom"
function ulx.setutime( ply, targ, time )
if not targ:IsValid() then return end
targ:SetUTimeStart( CurTime() )
targ:SetUTime( time*3600 )
sql.Query( "INSET into utime( player, totaltime, lastvisit ) VALUES( ".. targ:UniqueID() ..",".. time*3600 ..",".. os.time() .." );" )
ulx.fancyLogAdmin( ply, "#A set the hour's for #T to #i", targ, time )
//return true
local setutime = ulx.command( CATEGORY_NAME, "ulx setutime", ulx.setutime, "!setutime" )
setutime:addParam{ type=ULib.cmds.PlayerArg, hint="player" }
setutime:addParam{ type=ULib.cmds.NumArg, default = 0, min = 0, max = 9999, hint="hours" }
setutime:defaultAccess( ULib.ACCESS_SUPERADMIN )
setutime:help( "Sets a player's hours." )
//setutime:logString( "#1s set the hour's for #2s to #3i" )
Goes in your ULX/lua/ulx/modules/sh/
The commented out lines are for a few revisions back before the logging changed.
