If it shows as an invalid command in your client, they are NOT running UTime. Not this version of it, anyways.
Sent from my iPhone using Tapatalk
Offline pmag
Thank you for helping me understand this as best as you could. I wonder if its just an older version of Utime or even a ULX pack which includes Utime but only shows for some people. Im still not exactly sure how ULX/Utime work but in my experience "modding" minecraft I know that the tiniest of differences can mean a whole different outcome.
Thank you
to sign up I had to identify the "admin mod" I thought it was talking about the top admin/mod for the forum not "ULX" I spent too long looking for an admin/moderator with a name that ended in X.
Offline DrSchnell
Hello,
Up until about 1 hour ago uTime has been working flawlessly and I really thank you for it. I recently tried setting up a server admin panel and it required a modified lua script in the ULX files. So i disable my workshop ULX and ulib and I go and get it from the website. After some fussing around, I get it set up and working, but none of the hours show up. Almost all of the players on the server have their hours reset to 0. One person retained his hours. I chmod'd sv.db to 777 and it still doesn't work. i don't know if between the set up of the admin panel and the different versions of ULX that my database became corrupt? Is that a possibility? I was just wondering if there is a way to fix this as my users' rank progression depends on how many hours they have.
Thank you again,
Schnell
Offline saya
how can i set permissions? users can change the colors
Colors are configured clientside. Changes on the client don't affect the server.
Offline jtw144
What folder do you put the download in?
It goes in your addons folder, jtw144.
Offline Rokilo
I'm getting this error :(
[ERROR] addons/utime/lua/autorun/server/sv_utime.lua:127: attempt to call global 'log' (a nil value)
  1. updatePlayer - addons/utime/lua/autorun/server/sv_utime.lua:127
   2. unknown - addons/utime/lua/autorun/server/sv_utime.lua:153
So the time doesn't save when I reset the server
Rokilo, Not sure what you're using, but you aren't using this release of Utime.
Likely someone elses modified version. This release has no 'server' folder in autorun.
(As reviewed - https://github.com/TeamUlysses/utime/tree/master/lua/autorun )
I even looked in this releases sv_utime.lua folder, it doesn't even have 127 lines of code.
I'd recommend finding the author of the release you're using and ask for help in that release comments.
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
If you have only one server, then I'd recommend to just download the original copy of uTime from the original post on this thread.
Offline Noobless
I keep getting a error and i don't know why. This is what i found in my server console
Unknown Function:             InitTimer       player [1][NoobLess]
Noobless is my steam name.
I've tried reinstalling it and i even put utime and ulx as the only two addons on my server and still had the same problem. i got it straight from the git hub as well.
Offline Gr0m3r
Me and my friends noticed that today a few players lost their time on utime on server. It has reset to 0, for some players time get back, but not to the same value as early. I'm useing autopromote and some players lost their ranks then they get ranks back, but time not. I created that post to ask if someone can help me or have idea what can cause that.
ULX groups are stored in gmod\data\ulib\groups.txt, users for groups are stored in gmod\data\ulib\users.txt
Utime data is stored in gmod\sv.db (the root gmod server folder)
If by 'ranks' you mean admin "groups", they have nothing to do with the same file area.
If by 'ranks' you mean something actually called 'ranks' in a gamemode, then it's possible whatever stores ranks are also in sv.db
No matter, it sounds as though your sv.db has been erased/modified/or corrupted.
If you do not have a recent backup of your gmod\sv.db file from recently, your UTime data is gone.
Offline Gr0m3r
Well, only a few players lost their time and i've modified SV.db file, but it was almost 2 weeks ago and everything was fine. I didn't even touch utime data, what could affect that?
- what could affect that?
- i've modified SV.db file
You've answered your question. Sounds like you corrupted the file.
Likely not noticed until certain players joined.
The only time I've ever seen player times lost is when the sv.db was damaged, erased, server reinstalled fresh (which writes new sv.db), etc.
Really, we can't know for sure, but, it's corrupt now. I'd recommend restore from backup.
