When someone says "root" folder, specifically in this place, Gmod, it means the first folder.
Megiddo did not mention addons.
He mentioned sv.db in root folder
So, you need to make sure the user that your server runs as has write access to <your gmod folder>/sv.db
That file stores much information about Gmod and some addons, not just UTime.
If you do not know how to do that, check with your host.
Checking write permissions of that file is beyond the support of this thread.
Offline Canne
I can't see .db files on my pc wtf
Offline TT=open again Isabella Jazzlyn
We've never been able to figure out why some users get that error occasionally, but it's harmless.
oke any idea how to implement utime into a ttt_scoreboard?
Offline Canne
I stil didn't get any help i'm sorry but my utime resets all the time... anyone that can help me? i would appreciate it it's really annoying when i restart my server everyone lose their stats of time it goes back to 0 and i have auto promote ranks....
Offline Canne
ii contacted my host they say it has the permissons my utime stil resets all the time any other thing i can do ? any other addon that has utime aswell?
Offline monkeymacman
If you know GLua then it is pretty simple just look at the TTT hook documentation, if you don't then it's pretty easy you could learn or I'm sure somebody on here would be glad to do it for you (I can throw together a quick 5 minute or less code, but I don't have my computer so I can't test it.)
Something is removing information from the database. Try removing all addons EXCEPT UTime and see if you have a conflict somewhere.
Thnx found someone to do it for me  ;D
Offline Canne
Heeey utime dissapeared out of the nowhere wtf? how can i get it back it's not ingame more do i have to reinstal it or something?
Offline Canne
Can it get fixed pleasse?
Did you disable UTime?
Offline Canne
disable where??
In the client settings, you can disable UTime. Run the following in your client console...
utime_enable 1.0
Offline Canne
utime_enable 1.0
this is the error i get...
it stoped working out of nowhere didn't touch anything at all
[ERROR] addons/utime/lua/autorun/cl_utime.lua:310: attempt to index local 'cpanel' (a nil value)
  1. buildCP - addons/utime/lua/autorun/cl_utime.lua:310
   2. resetCvars - addons/utime/lua/autorun/cl_utime.lua:305
    3. fn - addons/utime/lua/autorun/cl_utime.lua:334
     4. unknown - addons/ulib/lua/ulib/shared/hook.lua:105
      5. LocalPlayer - [C]:-1
       6. fn - addons/utime/lua/autorun/cl_utime.lua:333
        7. unknown - addons/ulib/lua/ulib/shared/hook.lua:105
it's enabled...
local utime_enable = CreateClientConVar( "utime_enable", "1.0", true, false )
« Last Edit: January 25, 2016, 12:05:09 pm by Canne »
You need to run "utime_enable 1.0" in your console.
