Author Topic: [BROKEN] UMotd Revived - Motd and OTHER informational screens.  (Read 117262 times)
Offline WildWill
  • Global Moderator
    • Beast_Building_Server
Re: UMotd Revived - Motd and OTHER informational screens.
« Reply #60 on: September 11, 2008, 07:14:20 am »
Jam I've tried that link there before and just now again and there doesn't seem to be much there other then uclip. Maybe I'm doing something wrong here..
« Reply #61 on: September 11, 2008, 04:54:39 pm »
Oops sorry. I accidentally copied the wrong svn dump over for Umotd. I'll put this next on my todo list.
« Reply #62 on: September 11, 2008, 08:43:08 pm »
EEk. Thanks Meg.
Sorry Will.
* JamminR really should think about updating to the ULib player spawn check at the least.
Offline Zenox
    • VB forums
« Reply #63 on: September 13, 2008, 02:30:32 pm »
Great!!! This is the first thing to download tomorow !!! Ty guys.
-Zenox
It's nice to be important, but more important to be nice... -Zenox
Offline WildWill
  • Global Moderator
« Reply #64 on: September 13, 2008, 10:31:20 pm »
Did you see something that I missed there Zenox?  They may or may not have that there by then, right now Meg is very busy doing some other things.  Just hang in there and it will come.
« Reply #65 on: September 14, 2008, 07:39:21 pm »
Sorry 'bout the delay folks, should be all fixed up now. You may have to delete your local copy and re-checkout.
Offline angrykid
« Reply #66 on: September 18, 2008, 07:38:36 pm »
It seems that CSS does not work in-game. D:
« Reply #67 on: September 18, 2008, 07:45:35 pm »
CSS works for me, show me your code, and I'll check it out for you.
« Reply #68 on: September 18, 2008, 07:59:06 pm »
Not sure external CSS links work. Think you have to put it inline like I did for my stats template.
Offline angrykid
« Reply #69 on: September 18, 2008, 10:11:44 pm »
Feh...
« Reply #70 on: September 19, 2008, 04:57:22 am »
I've used inline, and I've placed it in the head tags and it still works.
<style type="text/css">
     div.main {
     width:800px;
     background-color: #CCCCCC;
     border: 2px solid #000000;
</style>
Reiko
« Reply #71 on: September 29, 2008, 08:43:49 am »
Would it be possible to add an option to each UMOTD entry in the config to keep the page loaded after the window has been closed? Such as steam MOTD behaviour.
I use this to my advantage by streaming media into an embedded media player, however with Umotd when you close the window, the page unloads and the stream stops. D= I don't know if it's Garry's doing, or even Steams doing with the Orangebox engine, but I have tried using SourceMod to bring up an old style MOTD box to see if that still works but it just sits there like a lemon.
Would it be possible to add that feature, and if not; any ideas for how I could acieve this again?
« Reply #72 on: September 29, 2008, 07:01:29 pm »
Reiko,
 There is no way to do this in configuration.
I have far off "to do" plans of adding a radio function, but it will require several lines of code change.
Well, yes, maybe only one, but, I want the frame to close if not a radio (save memory), or hide if a radio page.
If you (or anyone else for that matter) knows GLua (The Gmod functions of Lua) and want to tinker, look into Umotd_client.lua.
The button is now set to :Close()
I'm pretty sure that would need to change to :SetVisible( false )
Problem is, I've looked around the GMod Lua Wiki. Panel has a SetVisible. The DFrame I'm using doesn't show one in the Wiki.
« Reply #73 on: September 29, 2008, 07:04:37 pm »
It inherits from EditablePanel which should have that function. :)
« Reply #74 on: September 29, 2008, 07:14:51 pm »
Yeah, I'd seen code examples using it too, just not blatantly in the DFrame library listing.
I think I remember even seeing it the oooold URadio.
Thanks.
