Author Topic: [BROKEN] UMotd Revived - Motd and OTHER informational screens.  (Read 117262 times)
Reiko
Re: UMotd Revived - Motd and OTHER informational screens.
« Reply #75 on: September 29, 2008, 08:03:12 pm »
That's great! I'll have a fiddle around with it myself then.
Thanks for the hint!
Offline Reiko
  • Wheee!
    • VorixNet
« Reply #76 on: September 29, 2008, 08:54:24 pm »
Sorry for the double post. I decided to grab myself an account since I modify guest posts.
I've changed a bit of "Umotd_client.lua" to;
if UMotd.command == "radio" then
Ubutton:SetText( "Hide" )
Ubutton.DoClick = function() Uwindow:SetVisible( false ) end
Ubutton:SetText( "Close" )
Ubutton.DoClick = function() Uwindow:Close() end
Which works a dream, which in itself is amazing because I know no LUA. However, I've come across another problem. Although this works well now, you can open up multiple radio windows at once because the old window just stays hidden, I was wondering if someone could tell me if there is any way to have the previous radio window close upon a new radio window opening? And if not, if there was a way to just make every window (hidden or not) close whenever a new window is opened so that there can only ever be one window open at once.
Thanks for all the help!
« Last Edit: September 29, 2008, 08:56:15 pm by Reiko »
So there! D=<
« Reply #77 on: September 29, 2008, 10:14:55 pm »
My guess, untested...
At the very top of the function before Uwindow gets set, check if it is nil and command = radio.
If it isn't nil and command = radio, Uwindow:Close() (Radio was shown already, close it)
If it is nil, do nothing. (Radio wasn't shown, this is first time)
Uwindow should stay the same in memory, and be able to be closed later before being reset in the function.
Offline Reiko
  • Wheee!
    • VorixNet
« Reply #78 on: September 30, 2008, 02:36:12 am »
I currently have it set up like this;
function UMotd.showUMotd()
        if Uwindow != nil then
                Uwindow:Close()
local Uwindow = vgui.Create( "DFrame" )
Uwindow:SetSize( ScrW()*0.9, ScrH()*0.9 )
Uwindow:SetSize( 640, 480 )
Uwindow:Center()
Uwindow:SetTitle( "UMotd v" .. UMotd.version .." - Viewing the " .. UMotd.command .. " screen." )
Uwindow:SetVisible( true )
Uwindow:MakePopup()
        etc...
I've also tried every variation of the;
        Uwindow:Close()
That I can think of and sometimes I would get this error;
Couldn't include file 'Umotd/umotd_client.lua' (File not found)
So basiclly the server refused to send it, and every other time there were no errors, but nothing happened.
It behaved exactly as I described before.
Any ideas?
So there! D=<
« Reply #79 on: September 30, 2008, 03:06:14 pm »
Try removing 'local' from in front of the Uwindow = vgui... line.
I forgot about that.
Up near the top of the client file,
local HTML = { }
local UMotd = { }
Add "local Uwindow"
(Lua lesson for you, 'local' inside a function makes the variable local to the function only)
I'm thinking that may cause other issues, but we'll go from there.
Offline Reiko
  • Wheee!
    • VorixNet
« Reply #80 on: September 30, 2008, 08:56:10 pm »
Sorry about posting this unfinished. I accidentilly hit tab, then space and the form submitted. Editing it now.
local HTML = { }
local UMotd = { }
local UWindow = { }
--local UMotd_sc
local UMotd_sstart
for k, v in ipairs ( UMotd_sounds ) do
    util.PrecacheSound( v )
    UMotd_sc = k
function HTML:StatusChanged( text )
function HTML:ProgressChanged( progress )
function HTML:FinishedURL( url )
function HTML:OpeningURL( url, target )
vgui.Register( "UMotd", HTML, "HTML" )
Uwindow:Close()
Uwindow:Center()
Uwindow:MakePopup()
Right, this is a lot closer. Now; the first time you open up a radio (hiding) window the window opens up fine, then the next time, the old one closes first. However, upon using the "X" button at the top of the window or using a different window such as !motd and closing we get an error;
Umotd/umotd_client.lua:56: attempt to call method 'Close' (a nil value)
Which I thought the if was suppost to take of. Any ideas?
Thanks again for all the help
« Last Edit: September 30, 2008, 09:00:14 pm by Reiko »
So there! D=<
« Reply #81 on: October 01, 2008, 12:06:24 pm »
Lua is case sensitive. And you've tried to convert Uwindow to a table.
At the top, you have
local HTML = { }
local UMotd = { }
local UWindow = { }
Change that to
local HTML = { }
local UMotd = { }
local Uwindow
I simply changed W to w. And I changed it from the assignment you were doing that declared a table to just a local variable.
Offline Reiko
  • Wheee!
    • VorixNet
« Reply #82 on: October 01, 2008, 08:00:19 pm »
MsgN( Uwindow )
Uwindow:Close()
MsgN( Uwindow )
Uwindow:Center()
Uwindow:MakePopup()
local html = vgui.Create( "UMotd", Uwindow )
local Ubutton = vgui.Create( "DButton", Uwindow )
if UMotd.command:lower() == "radio" then
Ubutton.DoClick = function() Uwindow:Close() Uwindow = nil MsgN( Uwindow ) end
This helped a lot, didn't realize I was making it a table however, using MsgN as debug I found that even after the panel is closed, the variable keep's it... ID (or whatever that code was) so to get around that, after I noticed that the button was in a function, I added in that once the close button had been pushed, it set Uwindow to nil. Now it works perfectly UNLESS you press the "X" button up in the corner. Is there any way to register when that has been pressed or just when the panel has been closed in general?
So there! D=<
« Reply #83 on: October 01, 2008, 08:33:39 pm »
<clip>
Ah, sorry about that. I forgot to tell you to account for the fact that Uwindow wasn't local to the function anymore, just the script.
When it's local to a function, it gets set back to nil after the function is over. When we removed it from the function and declared it local to the script, we have to manipulate it ourselves. Though we didn't want it to be nil at the beginning if the radio was playing, we do want it to go nil if the radio is stopped.
Glad to see you learned how to account and fix it yourself now though.
Wow, you seem to be learning quite nicely.
As for the X button, yes, there's a way to detect it. Unfortunately, I cant' find it on the Gmod wiki at the moment.
You know about the Gmod Lua wiki, right? Lots of insight to GLua can be found there to tinker with for various projects and ideas.
Several tutorals too.
Anyway, I found this that could be used to now show the X. Perhaps that would work for you.
[Edit] Oh, that 'id' as you call it by the way is I believe a memory address where the object is stored. One of my fellow team mates can correct me on this, or elaborate if I'm close. It's not a string variable, so it doesn't get printed as a 'readable' string.
« Last Edit: October 01, 2008, 08:38:33 pm by JamminR »
Offline Reiko
  • Wheee!
    • VorixNet
« Reply #84 on: October 01, 2008, 08:43:37 pm »
That's perfect! It's now fool proof.
That makes sense.
Great! It's working perfectly now. Thanks so much for all your help!
So there! D=<
« Reply #85 on: October 01, 2008, 08:59:43 pm »
And thank you for the inspiration and practice.
It's been months since I've done any hobby coding I could enjoy.
Now that we've helped each other debug, I'll know what not to do when I incorporate streaming radio into UMotd.
If you ever have ideas or projects you need help with now that you've dabbled in Lua, please feel free to visit our Developer's corner forum.
I personally don't always know the direct answer, but I like learning from our community and my team.
Offline Frostyfrog
« Reply #86 on: October 07, 2008, 05:23:29 pm »
The MOTD on player spawn thing won't work :(
I think somewhere here is the problem:
function Umotd_help(ply, cmd, argv, args)
         ULib.console(ply, "[Umotd] - The following are available; help(this context), " .. string.Implode( ", ", Ucmds ) )
--ULib.concommand( "Umotd", Umotd_help )
ULib.begin_subconcommand( "Umotd", Umotd_help, nil, ULib.ACCESS_ALL  )
  Umotd_content = { }
  for Umotd_cmd, Ufile in pairs( Umotd_command_files ) do
      Umotd_content[Umotd_cmd] = { }
      Umotd_content[Umotd_cmd].cmd_name = Umotd_cmd
      if Ufile:lower():find("http:", 1, true) then
         Umotd_content[Umotd_cmd].path = Ufile -- It's a URL!
         Umotd_content[Umotd_cmd].path = Umotd_LoadDir .. Ufile
      if string.lower( Umotd_cmd ) == "motd" then
        if not Umotd_content[Umotd_cmd].path:lower():find("http:", 1, true) then
           local motdpath = "../" .. GetConVarString( "motdfile" )
           if file.Exists( motdpath )
           and not file.Read( motdpath ):find( "Welcome to Team Fortress 2", 1, true ) then
               Umotd_content[Umotd_cmd] = { path = motdpath } --Use motdfile variable if it exists, otherwise use config.
      if file.Exists( Umotd_content[Umotd_cmd].path ) or Umotd_content[Umotd_cmd].path:lower():find("http:", 1, true) then
         Umotd_funcname = Umotd_cmd
         table.insert( Ucmds, Umotd_cmd )
         function Umotd_funcname(ply)
                 if not ply:IsValid() then
                    ULib.console(ply, "[Umotd] - You can't see the "..Umotd_cmd.." from the console.\n" )
                    return
                  UshowMotd( ply, Umotd_cmd, Umotd_content[Umotd_cmd].path )
         Umotd_content[Umotd_cmd].func = Umotd_funcname
--print("Created ".. Umotd_cmd .." and passing ".. Umotd_content[Umotd_cmd].path )
         ULib.add_subconcommand( "Umotd", Umotd_cmd, Umotd_funcname, ULib.ACCESS_ALL )
         ULib.addSayCommand( Uchat_prefix .. Umotd_cmd, Umotd_funcname, "Umotd " .. Umotd_cmd )
         Msg("[Umotd] Error - I can't create function \"" .. Umotd_cmd .. "\", file\URL " .. Umotd_content.Umotd_cmd.path .. " couldn't be found/understood.\n" )
         Msg("[Umotd] Error - Function \"" .. Umotd_cmd.. "\" not created\n" )
         --       Don't create functions.
  function UShow_motd(ply)
           if util.tobool( GetConVarString( "ulx_showMotd" ) ) then -- If ULX is loaded, attempt to disable its motd.
              game.ConsoleCommand( "ulx showMotd 0\n" )
           ply:ConCommand("Umotd "..Umotd_SpawnCommand .."\n")
local function Umotdinit()
                 if util.tobool(Umotd_ShowatPlayerSpawn) then
                    hook.Add( "PlayerInitialSpawn", "Umotd_Spawner", UShow_motd)
                 Umotd_map_starttime = os.time()
hook.Add( "Initialize", "UmotdInitialize", Umotdinit )
--[[ ToDo
--table.HasValue - look it up ]]--
end -- UmotdLoaded
end -- Server
My configuration file:
Umotd_LoadDir = "Umotd/"
Uchat_prefix = "!"
Umotd_SpawnCommand = "listaddons"
Umotd_ShowatPlayerSpawn = "true"
Umotd_command_files = {
                    ["motd"] = "motd_template.txt",
                    ["rules"] = "rules.txt",
                    ["helpme"] = "help.txt",
                    ["serverinfo"] = "info_template.txt",
                    ["ulysses"] = "http://www.ulyssesmod.net/",
["donations"] = "donations.txt",
["listaddons"] = "addons.txt",
["website"] = "http://www.pawspubserver.co.uk/",
Umotd_dynvar = true
Umotd_AddOnSep1 = ", <br>" -- this sets what to use as separator if you use %addon_long%
Umotd_AddOnSep2 = ", " -- this sets what to use as separator if you use %addon_short%
« Reply #87 on: October 07, 2008, 05:35:06 pm »
Any errors at server startup? Any errors when you join your server? When other people join your server?
Offline Frostyfrog
« Reply #88 on: October 10, 2008, 08:39:03 pm »
nope, no errors. then again, not really my server. I'm just the Lua guy for it. When I have this, it works: Umotd_ShowatPlayerSpawn = "false"
I shows the default (which isn't what we want)...
Offline angrykid
« Reply #89 on: October 12, 2008, 01:05:43 am »
It's not showing up for me either. I don't really care, though, since nobody ever visits my server. :P
Oh, non-inline CSS works now! Kickass!
Now all I need for it to do is not lag so badly when trying to make a post on my forums... :P
« Last Edit: October 12, 2008, 01:11:53 am by angrykid »
