Offline someone920
Re: UPS - Ulysses Prop Share
« Reply #360 on: June 06, 2010, 09:28:40 am »
I just found something. The UPS friends seems to be messed up. Everyone is allowed to prop share, but you can't remove a friend from prop sharing.
« Reply #361 on: June 12, 2010, 10:39:31 am »
Can someone who is having problems with UPS contact me on Steam, please? Email address on steam is megiddo@meg-tech.com. Thanks!
Offline DeimosTK
« Reply #362 on: June 15, 2010, 02:07:10 pm »
Skimmed the thread and it looks like others are having the same error I am. Only admins are able to manipulate their own props, everyone else apparently gets an error.
I'm unable to join the server to check what the actual error is because I'm on my laptop though, so I guess this doesn't really help much :[
« Reply #363 on: June 15, 2010, 03:13:18 pm »
please contact me on steam, I'll be on in about 3 hours.
Offline DeimosTK
« Reply #364 on: June 15, 2010, 07:20:56 pm »
For anyone else having issues with players not being able to pick up their props, using the SVN version of UPS fixed that for me.
SVN link is http://ulyssesmod.net/UPS/trunk/
Offline matthall
« Reply #365 on: July 27, 2010, 08:32:49 pm »
Ok i'm having the "not loaded on this server error" (it is on the server). Would SVN fix this?
« Reply #366 on: July 28, 2010, 05:12:48 am »
It should, if not I'd like to debug your server. :)
Offline lavacano201014
« Reply #367 on: July 29, 2010, 07:34:45 pm »
Since the last GMod update, my server regulars have complained that the prop protection "doesn't start until an admin starts it".
From my superadmin's response, UPS is starting with the "DISABLE EVERYTHING FOR EVERYONE" box checked. Did my config go splat, or is something worse at work?
« Reply #368 on: July 29, 2010, 08:03:46 pm »
I haven't gotten around to weaning our configs off garry's system, so in order to save a config the server must be shut down gracefully (full shut down, not a crash or a map change).
In short, try changing that setting and then shutting down the server.
Offline Alfie
« Reply #369 on: August 20, 2010, 01:13:20 pm »
I just installed the latest versions of UPS and ULib via SVN and it's said in the readme of UPS that the settings section will show up in the utilities. It doesn't, I'm testing it SP for my server.
Here's a console log from launch to in SP:
Mounting hl2.. OK
Mounting ep2.. OK
Mounting tf.. OK
Mounting cstrike.. OK
Mounting dod.. OK
Mounting episodic.. OK
Mounting hl2mp.. OK
Mounting portal.. OK
Mounting lostcoast.. OK
Mounting hl1.. OK
Mounting hl1mp.. OK
Mounting zeno_clash.. No permission
Garry's Mod server.dll Build #095 [Aug 16 2010 12:58:33]
maxplayers set to 128
Unknown command "sv_allow_wait_command"
Steam config directory: c:\program files (x86)\steam\steamapps\alfierulz\garrysmod\platform\config
Parent cvar in server.dll not allowed (sv_scriptenforcer_initialkick)
Garry's Mod client.dll Build #095 [Aug 16 2010 12:58:32]
maxplayers set to 1
Unknown command "cl_thirdperson"
Unknown command "hud_showemptyweaponslots"
Unknown command "sv_backspeed"
GetAllManifestFiles:  Unable to load maplist.txt
Not playing a local game.
maxplayers set to 1
KeyValues Error: RecursiveLoadFromBuffer:  got } in key in file maps/gm_construct.res
resources,
Lua initialized (Lua 5.1)
KeyValues Error: RecursiveLoadFromBuffer:  got } in key in file In
Users, superadmin,
//  shared/datastream.lua    //
//  server/upgrade.lua       //
//  shared/hook.lua          //
[ULIB] Loading SHARED module: ups_init.lua
||    Ulysses Prop Share(UPS)    ||
|| Loading...                    ||
||  sh_defines.lua               ||
||  sh_lib.lua                   ||
||  lib.lua                      ||
||  sh_friends.lua               ||
||  base.lua                     ||
||  MODULE: gm_fix.lua           ||
||  MODULE: map_protect.lua      ||
||  MODULE: player_disable.lua   ||
||  MODULE: player_leave.lua     ||
||  MODULE: restrict.lua         ||
||  MODULE: cppi.lua             ||
|| Load Complete!                ||
===  Wire  2137 (exported)   Installed  ===
ERROR! Module 'zlib_b64' not found!
ScriptEnforce is disabled
Executing listen server config file
Couldn't find scene 'scenes/npc/female01/question21.vcd'
Couldn't find scene 'scenes/npc/female01/question31.vcd'
Couldn't find scene 'scenes/npc/female01/answer35.vcd'
Couldn't find scene 'scenes/npc/female01/gordead_ques03a.vcd'
Couldn't find scene 'scenes/npc/female01/gordead_ques03b.vcd'
Couldn't find scene 'scenes/npc/female01/nice.vcd'
Couldn't find scene 'scenes/npc/male01/nice01.vcd'
Couldn't find scene 'scenes/npc/male01/nice02.vcd'
Couldn't find scene 'scenes/npc/female01/oneforme.vcd'
Couldn't find scene 'scenes/npc/Barney/ba_run.vcd'
Couldn't find scene 'scenes/npc/Barney/ba_ohshit.vcd'
Couldn't find scene 'scenes/npc/Barney/ba_thisisbad.vcd'
Couldn't find scene 'scenes/npc/Barney/ba_headcrabs.vcd'
exec: couldn't exec listenserver.cfg
InitFastCopy: only 51% fast props. Bug?
RunConsoleCommand blocked - sent before player spawned (sv_tags)
You are running ULib version 2.40.
--- Missing Vgui material ignore_this_error
[ Mounting DepthHUD Inline ... ]
DepthHUD Inline >> Unmounting Theme [DepthHUD Classic].
DepthHUD Inline >> Mounting Theme "DepthHUD Classic" :
[ DepthHUD Inline is now mounted. ]
--- Missing Vgui material texturemissing
Sending 1161 'User Info' ConVars to server (cl_spewuserinfoconvars to see)
repopulating clients
Player [1][[KotSC] Alfie] authed superadmin
populating client Player [1][[KotSC] Alfie]
Attempting to precache model, but model name is NULL
RunConsoleCommand blocked - sent before player spawned (ZLib_Installed)
===  Wire revision: 0     ===
=== Local Wire revision:0 ===
Physgun build mode is available on this server
Warning: Unhandled usermessage 'ups_client_init'
Warning: Unhandled usermessage 'ups_readnames'
test false
Redownloading all lightmaps
Timer Error: attempt to call a nil value
« Reply #370 on: August 20, 2010, 01:21:07 pm »
UPS is not supported in single player mode
Offline Alfie
« Reply #371 on: August 20, 2010, 02:20:02 pm »
Okay, maybe you should note that down somewhere :P
And I've got a request;
Make a new variable for "World protection" so it can be toggle-able for players to physgun/gravgun/toolgun world props. But deny entities like doors and windows.
« Last Edit: August 20, 2010, 02:37:06 pm by Alfie »
Offline Alfie
« Reply #372 on: August 24, 2010, 05:01:35 pm »
No comments about my idea?
« Reply #373 on: August 29, 2010, 06:21:35 pm »
So it won't even load in SP?
Cool, I can just ignore it when Addonissimo gets fixed.
« Reply #374 on: August 29, 2010, 07:24:49 pm »
I should make it not load in SP I guess. Why would anyone want it to work in SP?
