Re: UPS - Ulysses Prop Share
« Reply #345 on: May 28, 2010, 10:25:48 am »
People were complaining about physgun not working on my server, so i tried downgrade my self to theyre level. I got the same error...
Can you copy and paste the error?
Offline Anderen2
« Reply #346 on: May 28, 2010, 10:59:48 am »
I get this in the client console when i'm an "normal user".
Warning: Unhandled usermessage 'ups_ownerinfo'Cannot lift the props i spawn... Not my guests either...
Offline TheDuck
« Reply #347 on: May 28, 2010, 11:15:03 am »
Problems are back with some users and some users got it work normally.. Weird!
« Reply #348 on: May 28, 2010, 11:54:13 am »
I think your problem is that the clients aren't getting the files properly anderen
Offline Anderen2
« Reply #349 on: May 28, 2010, 12:32:54 pm »
How can i fix it then? It all worked perfectly before the update!
« Reply #350 on: May 28, 2010, 12:56:18 pm »
I haven't had a whole lot of time to research garry's new system, but my guess would be that there's something you need to upload to your fast download server, or you could just disable sv_downloadurl for a time.
Offline Anderen2
« Reply #351 on: May 28, 2010, 01:14:53 pm »
Yeah, im making myself an fastDL server now, ill try that :)
Offline blindbox
« Reply #352 on: May 28, 2010, 03:37:04 pm »
What files do they actually need? I have my fastDL server synchronized with my server's garrysmod folder, so if it requires anything, fastDL will have it (I'll be honest here, my garrysmod folder is where all the fastDL files are located. I'm merely using it to bypass the speed limit. I don't think this matters though  ;), as fastDL doesn't start if the server doesn't start. No locking problem afaik). Does garry disobey the fastdl rules or something? Plus, even if it doesn't work through fastdl, i have sv_allowdownload 0 to allow people to fall back.
Maybe i should just put the whole garrysmod folder into fastdl. I only put specific folders.
Thanks for the input though, I'll try disabling fastDL.
UPDATE: It works, even with fastDL! I cleared the cache folder first though, just in case.
« Last Edit: May 29, 2010, 12:14:03 am by blindbox »
Offline TheDuck
« Reply #353 on: May 29, 2010, 12:38:29 am »
Seems like auto-remove on disconnect doesnt work, there are many props owned by unknown.
Offline blindbox
« Reply #354 on: May 29, 2010, 02:41:57 am »
Same here, issue still exists. All props owned by unknown. Maybe I just got lucky that time, maybe setting sv_downloadurl after the server has started like 10 minutes after doesn't actually set sv_downloadurl. Who knows.
Offline TheDuck
« Reply #355 on: May 29, 2010, 03:02:31 am »
Anyways, one weird thing. For some people, everything works likely fine (like before update). Like me. But some players have much problems with clientside stuff.. This is mystic.. Everyone has the newest gmod and plugins work for some people, but not all. And those unknown props etc, I think they came when meg tried to fix the thing gmod update broke.
« Reply #356 on: May 29, 2010, 08:41:28 am »
Worth seeing if that's the problem, I removed the datastream fix from ULib svn. That means you'll have to implement the fix yourself now, though.
Offline RynO-SauruS
« Reply #357 on: May 29, 2010, 07:13:14 pm »
How about you, Ryno?
Sorry, I didn't see your message until now. It worked fine when I tried it after your update, but it rarely messed up before.
« Last Edit: May 29, 2010, 07:19:29 pm by RynO-SauruS »
YouTube music player by RynO-SauruS
Offline TheDuck
« Reply #358 on: June 02, 2010, 04:02:49 am »
Still bugged up, unknown props full whole server...
I mean, I think autodelete on disconnect is bugged up. There's always so many unknown owned props.
Friends menu is bugged up, I cannot if I remove my UPS friends, go away the menu and come back, they're all checked again..
« Last Edit: June 02, 2010, 04:07:35 am by TheDuck »
Offline TheDuck
« Reply #359 on: June 02, 2010, 06:05:12 am »
New info.. Someone tried to spawn a dupe and it went automatically unknown owned props... Something is hardly bugged up
