Re: UPS - Ulysses Prop Share
« Reply #315 on: April 03, 2010, 11:04:11 pm »
I've seen this before too.
Forget how I fixed it.
I think I had SPP installed on my client also. Even though I was connecting to a UPS server, some SPP files seemed to be running client side.
(Again, I don't rememeber this for sure..been a long time (2-3 years))
Offline Patrik
« Reply #316 on: April 08, 2010, 11:40:09 am »
Suggestion: A toggle for whether or not only prop friends to the original owner can take stuff that are "up for grabs". This would prevent the ability for people to steam while still allowing your friends to keep the fort you built together.
Offline Frrz
    • Youtube ftw
« Reply #317 on: April 09, 2010, 12:53:34 pm »
OMG
After reading that ten times, I finally understand what you are saying.
And that would be a good idea =-P
Offline someone920
« Reply #318 on: April 09, 2010, 07:23:57 pm »
I have a slight problem with UPS, I have the SVN version of ULX and ULib, but the past few days it's been working and then all of a sudden breaks. What happens is it stops removing player's props after they leave. Anyone have a solution to this or should I use something else until UPS works with SVN again?
« Reply #319 on: April 09, 2010, 11:55:53 pm »
Are there any errors in the console around the time it breaks?
Offline someone920
« Reply #320 on: April 10, 2010, 06:38:07 am »
None at all.
« Reply #321 on: April 10, 2010, 09:09:30 am »
None at all.
Are you absolutely certain there are no errors in server console? Do you have any idea how to replicate the breakage?
« Reply #322 on: April 10, 2010, 09:32:35 am »
Someone920...key word..server console.
UPS is darned verbose.. Megiddo wrote it that way. Would surprise me if it's not spitting out an error.
Also, are you using the SVN of it? Though it too hasn't been updated in a while, the one from the front page is even older.
See my post a few posts back for the SVN link if you're not.
Offline someone920
« Reply #323 on: April 10, 2010, 11:37:28 am »
ahhhh, that might be the problem, I'm using the one on the front page. What's weird is that sometimes it works, sometime it doesn't. Usually on a busy day, it stops working then on the next restart or crash, it works fine.
« Last Edit: April 10, 2010, 11:45:05 am by someone920 »
« Reply #324 on: May 19, 2010, 03:53:15 pm »
http://www.facepunch.com/showthread.php?p=22051479#post22051479
See "Choy" post a few above mine. I figure it's due to whatever was keeping ULib/ULX from running (case sensitivity? (darn Source for not finding a generic way around that)).
He gives no error though.
« Reply #325 on: May 19, 2010, 04:54:53 pm »
Oops, thanks for the notice JamminR... I'll see if I can't get it fixed tonight.
Offline Mika32
« Reply #326 on: May 22, 2010, 09:34:31 am »
Why ?
« Reply #327 on: May 22, 2010, 10:34:47 am »
Why ?
Do you have any errors in your server or client consoles?
Offline Mika32
« Reply #328 on: May 22, 2010, 11:39:38 am »
"gm_construct_flatgrass_v5.
AdvDupeShared: Server Compression: false
ULX version <SVN> unknown revision loaded.
RunConsoleCommand blocked - sent before player spawned (ZLib_Installed)
Player [1][unconnected]   authed
Redownloading all lightmaps
PCMod2: >> DarkRP 2.3.5 PCMod Plugin 1.0.0 Post-Loaded! (NO DARKRP)<<
===  Wire revision: 0     ===
=== Local Wire revision:0 ===
Where is the problem ? (sorry for my bad english i'm french)
« Reply #329 on: May 22, 2010, 12:03:48 pm »
How about in your server console?
