Offline Jethro
Re: UPS - Ulysses Prop Share
« Reply #285 on: August 03, 2009, 08:07:46 pm »
Looked everywhere in "http://ulyssesmod.net/Ulysses" and I didn't see any UPS folders =/
« Reply #286 on: August 03, 2009, 08:57:35 pm »
You need to do a physical checkout to see it, not sure why our host doesn't show it in http server.
Offline Jethro
« Reply #287 on: August 04, 2009, 08:18:45 am »
Thank you very much for that. It only shows all the other folders with a physical checkout (as you suggested); maybe something to do with read permissions?
Thanks again
Jethro
Offline Duelincheese
« Reply #288 on: August 04, 2009, 10:14:09 am »
 ;D THIS IS THE BEST! I COULDNT FIND ANYTHING TO FIX MY PROP PROTECTION BUT THIS DID IT :D THANK YOU SO MUCH!!!! Can you make a version that you don't need ulx or ulib to use?  :D
« Reply #289 on: August 04, 2009, 10:31:41 am »
You don't need ULX, you only need ULib. And no, I won't make a version that doesn't require it because that's the whole point of having ULib in the first place. Glad you like it though. :)
Offline Euphytose
  • I love Lemonade!
« Reply #290 on: August 05, 2009, 08:55:40 am »
Hello,
I wanted to give my mini-admins the access ups_remove, so I added " ups_remove " into groups.txt, for miniadmin group. But it does nothing, when my mini-admin wants to delete his own props with UPS, for example, it is said that he doesn't have access to this cvar.
What can I do?
Thanks in advance.
Edit :
Also, sometimes, players are asking me on Steam : " Hey, Euphytose, clean up the server, it's very laggy there! ". But, the only thing I can do is to reboot the map, I don't know which command would work to delete everything on the map without having to reboot it, could you give me a standard command, or a UPS one? I tried ups_remove * and ups_remove all, but it doesn't work.
« Last Edit: August 05, 2009, 02:26:39 pm by Euphytose »
« Reply #291 on: August 06, 2009, 06:30:32 pm »
The access to delete all a player's props is actually "ups miscDeletionAccess" (watch the case!).
ups_remove <uid> is the format for that command, where uid is retrieved from the 'status' command on the server. Not terribly easy to use from a console, sorry. :P
Offline Euphytose
  • I love Lemonade!
« Reply #292 on: August 06, 2009, 06:43:59 pm »
Thanks. :)
Edit : It was ups miscdeletionaccess, without any caps. :) Like written in the groups.txt so, but now it works. :)
« Last Edit: August 10, 2009, 01:08:02 pm by Euphytose »
Offline DiscoBiscuit
    • DiscoBuild
« Reply #293 on: August 29, 2009, 08:59:25 pm »
Sorry about the bump, but I've looked through it seems every file and I can't find a place to change the default values for cleaning up props and making props up for grabs. Do you know where it is?
« Reply #294 on: August 29, 2009, 09:38:17 pm »
Garry only saves the settings on a successful server shutdown. This is going to change down the road as soon as we have time to write our own saver.
Offline NaRyan
« Reply #295 on: September 01, 2009, 09:59:35 am »
Hi.
I installed UPS today on my server, basically just to try out a different Prop Protection script, and also due to the fact I got fed up with other admins being idiots and deleting world props.
Pain when they remove the track switching buttons on maps that have train tracks.....
All was going well with UPS, until I encountered a slight bug.
I was having a little war with a few zombies and all was going well until I ran into the problem of where the zombie is killed but the headcrab survives.
I could not kill or delete the headcrab as it said it was owned by Map.
I had to disable the protection (was not quite sure what option to use, I had only been using it for about 45 minutes, and had been to busy playing with my toys :) )
Sorry if this bug has already been mentioned, I did read the entire thread, but I might have missed it.
:edit:
oops forgot to say I am using the version from the 1st post in this thread (UPS-v0_95.zip)
Also I just tested, and it does the same with the Fast Zombies and the Poison Zombies if they are killed and the headcrab is left behind.
I have no idea if the headcrabs that jump off the poison zombie are effected as for some reason that was not happening.
:edit2:
Disregard I sent Megiddo a pm, As I decided it might be best not to have the info in public display.
« Last Edit: September 02, 2009, 02:57:12 pm by NaRyan »
    • DiscoBuild
« Reply #296 on: December 22, 2009, 02:08:41 pm »
I am having trouble of some people trying to use the utilities menu and it saying "UPS is not loaded on this server". I have ULib, ULX, and UPS svn. It also will say "Warning: Unhandled usermessage 'ups_ownerinfo'"
« Last Edit: December 22, 2009, 02:10:32 pm by DiscoBiscuit »
« Reply #297 on: December 22, 2009, 03:19:40 pm »
Does this happen all the time or only some of the time? Any errors in the server console during startup?
    • DiscoBuild
« Reply #298 on: December 22, 2009, 08:05:24 pm »
It has happened before with me, but most of the time mine works and it's other people that talk about it.
Here is my startup. I didn't find anything to do with UPS.
Mounting hl2.. OK
Mounting ep2.. OK
Mounting tf.. OK
Mounting cstrike.. OK
Mounting dod.. OK
Mounting episodic.. OK
Mounting hl2mp.. Failed
Mounting portal.. OK
Mounting lostcoast.. Failed
Mounting hl1.. Failed
Mounting hl1mp.. Failed
Mounting zeno_clash.. Failed
Error, bad server command sv_allow_voice_from_file 0
Parent cvar in server.dll not allowed (sk_apc_missile_damage)
Garry's Mod client.dll Build #072 [Nov 20 2009 20:20:42]
maxplayers set to 10
Unknown command "cl_interp"
Unknown command "sv_AdvDupeEnablePublicFolder"
ConVar fps_max old flags: 4194304
ConVar fps_max new flags: 4210688
ConVar lua_filestats old flags: 4
ConVar lua_filestats new flags: 16388
ConVar lua_run old flags: 4
ConVar lua_run new flags: 16388
ConVar sv_cheats old flags: 8448
ConVar sv_cheats new flags: 24832
ConVar sv_lua_datafolder old flags: 4
ConVar sv_lua_datafolder new flags: 16388
Network: IP 69.162.71.189, mode MP, dedicated Yes, ports 27015 SV / 27005 CL
Unknown command "sv_rollangle"
Unknown command "sv_unlag_fixstuck"
Lua initialized (Lua 5.1)
======== Installing Table (De)Serialiser Module | ver: 1.4 ========
//  server/upgrade.lua       //
//  server/hook.lua          //
//  server/gamemode_hooks.lua//
//  shared/concommand.lua    //
//  sh_base.lua              //
//  MODULE: playertitle.lua  //
ulx\modules/playertitle.lua:94: attempt to index global 'Ulib' (a nil value)
[ULIB] Loading SHARED module: UnoLimited.lua
[ULIB]*** UnoLimited v2.1 Ready! *******
[ULIB] Loading SHARED module: ups_init.lua
||    Ulysses Prop Share(UPS)    ||
|| Loading...                    ||
||  sh_defines.lua               ||
||  sh_lib.lua                   ||
||  lib.lua                      ||
||  sh_friends.lua               ||
||  base.lua                     ||
||  MODULE: gm_fix.lua           ||
||  MODULE: map_protect.lua      ||
||  MODULE: player_disable.lua   ||
||  MODULE: player_leave.lua     ||
||  MODULE: restrict.lua         ||
||  MODULE: cppi.lua             ||
|| Load Complete!                ||
[ULIB] Loading SHARED module: URestrict.lua
//         URestrict         //
//Loading...                 //
//  MODULE: init.lua         //
//  MODULE: canTool.lua      //
//  MODULE: give.lua         //
//  MODULE: giveSwep.lua     //
//  MODULE: pickup.lua       //
//  MODULE: props.lua        //
//  MODULE: spawn.lua        //
//Done!                      //
[ULIB] Loading CLIENT module: URestrict_cl.lua
[ULIB] Loading CLIENT module: ur_gui.lua
===  Wire  1910 (exported)   Installed  ===
======== Beam NetVars Lib v0.71 Installed ========
ERROR! Module 'zlib_b64' not found!
==== Advanced Duplicator v.1.72 shared module installed! ====
Added EntCheckHook: AdvDupe_NoItems
Added EntCheckHook: AdvDupe_DisallowedClasses
Added EntCheckHook: AdvDupe_ModelCheck
==== Advanced Duplicator v.1.85 server module installed! ====
ScriptEnforce is disabled
Stacker Version 2.5 loaded.
Loading Wire Tools
Writing cfg/banned_user.cfg.
Executing dedicated server config file
Adding master server 72.165.61.136:27015
Adding master server 72.165.61.189:27011
Connection to Steam servers successful.
   VAC secure mode is activated.
Client "ت" connected (74.71.250.174:27005).
game.ConsoleCommand blocked!
Invalid command entered. If you need help, please type "ulx help" in your console.
Client "[GMU|GDI]Γιοѕпчрєѓ" connected (75.36.143.25:27005).
Offline vader0146
UPS Broken
« Reply #299 on: January 10, 2010, 12:04:44 pm »
I'm using UPS 0.95 with ULX 3.40 and ULib 2.30.
I love UPS, it works really well  ;D
About 2 days ago people started not being able to move their own props, tools started breaking, and then people could just move any prop.  :'(
I went back to Simple Prop Protection but I couldn't stand the buffer overflows/snapshot overflows so I put UPS back on, and now the problems have started happening again.
When it first started going wrong I hadn't uploaded/changed/removed any addons, gmod hadn't updated, nothing had changed. It just .. broke.
No errors in server/client consoles.
Any ideas?  :-\
