Re: UPS - Ulysses Prop Share
« Reply #270 on: July 16, 2009, 10:24:46 pm »
Is there a way I can, per default, disable the whole " vehicle " and " use " protection for everyone?
Sometimes there are some noobs, building vehicles, or making a trap, they call their friends to jump into the seat, or press the button, but they can't. I have to explain them how to do that, or disable their protections by myself.
What you want is possible from SVN, but not the current release.
Offline wishbone
« Reply #271 on: July 17, 2009, 12:10:13 am »
If you enabled the ability for admins to touch others' props, you probably have a conflicting addon. You don't have another prop protector installed, do you?
No I only have ups for my prop protector.
Offline Euphytose
  • I love Lemonade!
« Reply #272 on: July 17, 2009, 03:38:40 pm »
Ok, I'll wait for the next release so.  ;D
« Reply #273 on: July 17, 2009, 07:04:35 pm »
Honestly don't know what your problem might be, it seems to be working fine for everyone else.
Offline wishbone
« Reply #274 on: July 18, 2009, 12:08:52 am »
Well when i try to click on any of the buttons it said you do not of access to this cvar could that be whats breaking it for me?
-- thanks
« Reply #275 on: July 18, 2009, 08:22:55 am »
Yes. You need admin access to change the cvars.
Offline wishbone
« Reply #276 on: July 19, 2009, 12:45:31 am »
Im super admin so it must must be my access rights for my teams.
--thanks
« Reply #277 on: July 19, 2009, 08:29:21 am »
Delete data/ULib/misc_registered.txt and restart your server.
Offline Samusaaron3
« Reply #278 on: August 01, 2009, 11:48:38 pm »
any luck on the UPS is not loaded on this server error?
I'm having this same problem.
I ran 'path' on my server, and though I cant copy/past (running through wine on linux), I can tell you that "...\ups\lua" "SLUA" was on the list.
Help?
« Reply #279 on: August 02, 2009, 07:31:00 am »
Help?
Any errors on server or client startup?
« Reply #280 on: August 03, 2009, 11:36:30 am »
Just a note, if you're using the SVN version of UPS, make sure you're using the SVN version of ULib as well, as I made some dependent changes to both.
Offline atomicspark
« Reply #281 on: August 03, 2009, 02:20:11 pm »
SVN version of UPS? Hmm. Are you making major changes to that too?
« Reply #282 on: August 03, 2009, 02:30:57 pm »
No, sorry. :P
Offline Jethro
« Reply #283 on: August 03, 2009, 04:45:46 pm »
Dang it would be convenient to have SVN of UPS =p.
Hint hint =p
 :P
« Reply #284 on: August 03, 2009, 05:39:53 pm »
The SVN of UPS is in the main Ulysses repository just like all our other projects. I'll leave it as an exercise to see if you can find it. :)
