Re: UPS - Ulysses Prop Share
« Reply #240 on: June 15, 2009, 08:20:30 pm »
Just searching this thread for that error, it's common, but has been known to be caused by Wire door stool ( /index.php/topic,3363.225.html#msg14475 ) and Stargate.
Have either?
Also, make sure you don't still have SPP or other prop protect scripts that might conflict.
Offline pump1er
« Reply #241 on: June 16, 2009, 09:37:32 am »
i do not have stargate, i do have wire door stool it came with wire svn, im going to deleate the door stool lua located in \addons\wire 4\lua\weapons\gmod_tool\stools and see if the error sill occures, is this the correct file to deleate ?
Offline pump1er
« Reply #242 on: June 16, 2009, 10:26:10 am »
i found the fix for my world protection not being enabled i had to edit gmod_cvars_sv in there ups_worldprotection was set to 0,
« Reply #243 on: June 19, 2009, 09:31:55 pm »
For those who were getting this error: "[UPS ERROR] Ownership table is not setup for a ply in onEntRemoved! Could be a bad UPS addon installed or bad initialization? Please report this error to ulyssesmod.net with information on how you got it."
I just made an update that should fix this for you. Let me know how it goes. :)
« Reply #244 on: June 20, 2009, 09:41:46 pm »
New version in the wild! Here's the changelog...
v0.95 - *(06/20/09)*
   * [ADD] Ability to enable and disable world protection.
   * [ADD] Ability to revoke admins' elevated privileges.
   * [FIX] Some problems with data consistency on player initialization.
   * [FIX] Added checks all over to ensure data integrity.
   * [FIX] Rewrote the anti-damage system. Should be able to take just about anything you can throw at it now (npcs, turrets, fire, etc).
Offline DiscoBiscuit
    • DiscoBuild
« Reply #245 on: June 22, 2009, 03:33:01 pm »
The only thing keeping me from using this instead of simple prop protection is that I tried it a while ago, and players could pick other people up with the physgun. Is that still a problem or been fixed?
« Reply #246 on: June 22, 2009, 04:56:54 pm »
That's not a UPS issue.
« Reply #247 on: June 22, 2009, 08:51:58 pm »
Disco, your issue is 99% surely caused by a conflicting mod... not ULib/ULX or other products.
See /index.php/topic,1169.0.html - Gcombat was known to cause that.
« Reply #248 on: June 28, 2009, 04:23:01 pm »
Added the ability for global disabling of protections in SVN rev 49. This feature has been requested quite often, so let me know how you like it.
Offline wishbone
« Reply #249 on: July 11, 2009, 02:40:32 am »
Hi, I need help my admins/superadmins cant pick up players props, only there own I think it has to do something with commands in the group.txt. So please help.
Thank's
« Reply #250 on: July 11, 2009, 02:40:42 pm »
It's an option in the menu
Offline Jethro
« Reply #251 on: July 11, 2009, 04:54:45 pm »
Would it be possible to make the options you select in the panel to save because everytime my server restated i would have to reset the options from their default settings.
Offline cobrasvt1999
« Reply #252 on: July 11, 2009, 05:54:34 pm »
I am trying to understand a problem i am having... its probably an install error but i don't know where it is.
the problem is when i boot the dedicated server with UPS in the addons folder and log in client side it seems to be working until i go to the "utility's" tab. the UPS controls seem to be there but when i try to use them it says that "UPS is not loaded on this server"...... i tried to go to \addons\UPS\lua\autorun and only found the client folder, and don't know if i need a server folder also. any suggestions would be helpful!!
« Reply #253 on: July 11, 2009, 06:16:07 pm »
It should save automatically. Perhaps your config file is set to read only?
Do you have ULib installed?
« Reply #254 on: July 11, 2009, 07:53:48 pm »
yes. it is installed and ulx runs properly.
