Author Topic: ASpam  (Read 174441 times)
Offline Euphytose
  • I love Lemonade!
Re: ASpam
« Reply #120 on: August 08, 2009, 10:43:03 am »
I had to remove ASpam, my server was filled with minges creations and was always crashing due to them.  :-\
Re: ASpam
« Reply #121 on: August 08, 2009, 06:30:51 pm »
ok, sorry to hear that, but removing ASpam will not stop minges from making their creations lol.
Offline Euphytose
  • I love Lemonade!
Re: ASpam
« Reply #122 on: August 08, 2009, 06:33:51 pm »
I lol'd.  ;D
I meant, they didn't disappear, and minges creations are... You know, really... " Mingy ". :)
Seriously, could you fix that? Your plugin is really needed against minges, but having creations that don't disappear after a set time is unacceptable.
« Last Edit: August 08, 2009, 06:35:46 pm by Euphytose »
Re: ASpam
« Reply #123 on: November 14, 2009, 11:35:42 am »
UPDATED!!!!
Offline yomogimochi
Re: ASpam
« Reply #124 on: February 11, 2010, 02:33:31 am »
Hello! Nice Addon.
I would like to request a ban feature.
If after a user is kicked three times, auto ban for 60 minutes?
Offline yomogimochi
Re: ASpam
« Reply #125 on: March 08, 2010, 08:44:16 am »
Re: ASpam
« Reply #126 on: March 08, 2010, 06:07:14 pm »
Nice yomogimochi!
Offline someone920
Re: ASpam
« Reply #127 on: March 20, 2010, 09:53:02 am »
I'm not sure if this was ASpam, but when someone gets 10 warnings, and they get kicked, when they come back, the server crashes. Is the server suppose to let the person back in? or does it kick them again?
Re: ASpam
« Reply #128 on: March 20, 2010, 04:40:16 pm »
ASpam should let them back in unless you've modded it to do otherwise.
Re: ASpam
« Reply #129 on: April 01, 2010, 04:16:37 pm »
I found a small glitch.  If you are waiting in line because someone else is using the dup when you try it starts the timer even though your dup is not spawning.  It should wait till you spawn your first prop or somehow check to see if your dup has started yet.
Re: ASpam
« Reply #130 on: April 01, 2010, 11:06:31 pm »
I'll take a look at it, but no promises. I'm pretty short on free time.
Re: ASpam
« Reply #131 on: April 02, 2010, 02:00:39 pm »
It also seems to just completely stop working, I am not 100% sure why but it just randomly stops.
Edit:  I'm not sure about the stop working anymore,  I'll keep an eye out for it.
« Last Edit: April 03, 2010, 09:27:02 am by Aaron113 »
Re: ASpam
« Reply #132 on: April 10, 2010, 04:07:14 pm »
Just to update everyone who is interested. I have found a way to fix the duplicating problems the way I originally intended the script to work. Just have a few more tests, and should be releasing later tonight.
New Features:
local Max_dupe_ents = 100 -- Max number of entities allowed to be pasted via advance duplicator
local allow_default_duplicator = false -- Allow the use of the default duplicator (Recommend false: Not as much control over props spawned)
Comments speak for themselves.
Thanks for your interest.
Re: ASpam
« Reply #133 on: April 10, 2010, 10:37:41 pm »
As promised, ASpam has been updated to V2.2.
Re: ASpam
« Reply #134 on: April 17, 2010, 08:15:09 pm »
K but the readme is wrong now, the configurations are in a different folder from which it says.  Not really that bad but just letting you know.
And can you do this with the dlist:
local dlist = {
"crane_frame.mdl"
"models/props_phx/ball.mdl"
"models/props_phx/oildrum001_explosive.mdl"
"models/props_phx/mk-82.mdl"
It would be much easier to add and know what is already in the dlist.
« Last Edit: April 17, 2010, 08:17:55 pm by Aaron113 »
