Author Topic: ASpam  (Read 174441 times)
Offline Alex
Re: ASpam
« Reply #90 on: January 28, 2009, 08:48:26 pm »
Actually, can someone give me the LUA kick command. I'll fix it myself. ;)
:) Alex T. :)
Re: ASpam
« Reply #91 on: January 28, 2009, 10:19:10 pm »
Ok, updated, added 3 different ways for it to kick the person. Hopefully that'll work, if now I'll change to something else.
Offline Alex
Re: ASpam
« Reply #92 on: January 28, 2009, 11:35:20 pm »
Argh still doesn't work!  :'(
But look what I found in console:
game.ConsoleCommand blocked!
Any help?
:) Alex T. :)
Offline Alex
Re: ASpam
« Reply #93 on: January 29, 2009, 09:43:15 am »
Ok I got another LUA error.
Startup:
autorun/cl_ASpaminit.lua:3: attempt to call global 'LocalPlayer' (a nil value)
Kicking:
Jay?
:) Alex T. :)
Re: ASpam
« Reply #94 on: January 29, 2009, 12:06:18 pm »
- Can't do anything about the LocalPlayer error, that's all garry, but hopefully it kicks now. If
                        not you have conflicting addons, because it's working fine for me.
Offline Alex
Re: ASpam
« Reply #95 on: January 29, 2009, 05:11:38 pm »
@#%!*^ still doesn't kick. :(
I get this:
If it's too hard just modify it so it doesn't kick and it just deletes the props.
:) Alex T. :)
Re: ASpam
« Reply #96 on: January 29, 2009, 05:28:09 pm »
for it to delete props, all you need is either UPS, and SPP installed. As for the kicking, I have to find a way around garrys new blocks.
Offline Alex
Re: ASpam
« Reply #97 on: January 29, 2009, 05:38:55 pm »
It deletes props just doesn't kick.
:) Alex T. :)
Re: ASpam
« Reply #98 on: January 29, 2009, 05:42:03 pm »
Ok, I'll have to figure something out then, because console commands are apparently blocked by garry now, so just give me some time.
Offline Alex
Re: ASpam
« Reply #99 on: January 29, 2009, 06:01:03 pm »
Ok, thank you very much!
:) Alex T. :)
Offline Alex
Re: ASpam
« Reply #100 on: January 30, 2009, 08:30:22 pm »
I'm not sure if you have tried this or not (I don't know LUA) but I believe there is a kick command you can use.
kick ((name here))
If it helps this is entered in console.
:) Alex T. :)
Offline Darksoul
Re: ASpam
« Reply #101 on: March 24, 2009, 07:46:46 pm »
Can someone please fix the kick function (And I am sorry for the huge bump/revive)
...???????...?'s props have been cleaned up
(Console) to admins: Player ...                      ...     is spamming, and has a warn level of 58. Kicking them after -48 more warnings
player ...                      ...    's props have been removed
Offline Hardy
Re: ASpam
« Reply #102 on: April 02, 2009, 01:20:19 pm »
Working kick function(in ASpam.lua)
function Spammer_Kick( ply )
if ply.warn >= Warn_Player then
ply:PrintMessage(HUD_PRINTTALK, "If you continue to Spam, you will be kicked!")
Warn_Left = Max_Warn - ply.warn
game.ConsoleCommand( "ulx asay Player " ..ply:Nick().. " is spamming, and has a warn level of " ..ply.warn.. ". Kicking them after " ..Warn_Left.. " more warnings \n")
if ply.warn >= Max_Warn then
if SPropProtection then
SPropProtection.DRemove( ply:SteamID(), ply:Nick() )
if UPS then
UPS.deleteAll( ply:UniqueID(), true )
game.ConsoleCommand("kickid "..ply:UserID().." \"Spamming!\" \n")
Offline Darksoul
Re: ASpam
« Reply #103 on: April 03, 2009, 07:22:42 am »
Thank you, I had just looked at the code before opening up this site and saw this:
//ULib.kick(ply, "Quit Spamming")
..what?. :D.
Offline iExiledSniper
Re: ASpam
« Reply #104 on: April 10, 2009, 11:03:27 am »
You need to make it ignore admins if it doesn't already.. I'm admin on a server that uses this and I like to build fast, which gets my props cleaned up and me kicked. -_-
