Author Topic: ASpam  (Read 174441 times)
Re: ASpam
« Reply #60 on: August 01, 2008, 12:56:24 pm »
Dang, did you add any new addons between the time it was working and wasn't?
Offline Smoot178
Re: ASpam
« Reply #61 on: August 02, 2008, 11:23:50 pm »
Let's retrace our steps.
The promotions were working in the beginning.  That's a clean aspam install.  The only problems I had was the fact that it "promoted" moderators, admins, and superadmins as if they were users to the second ranking group.
Your fixes for this have made the whole thing not work at all.
Re: ASpam
« Reply #62 on: August 03, 2008, 10:20:08 am »
that is strange, since the only changes we made was to the table itself =/
Offline Smoot178
Re: ASpam
« Reply #63 on: August 04, 2008, 03:07:52 pm »
Could you give me a fresh version of the script that will filter out admins superadmins and moderators?
Re: ASpam
« Reply #64 on: August 04, 2008, 04:06:55 pm »
I added an option "None" to the promote_to table. This should work.
Re: ASpam
« Reply #65 on: August 07, 2008, 06:27:59 pm »
V1.9
     - Promotions are no longer supported by this script, I will be making a better version soon!
New Dowloads posted.
Offline nofear1999
Re: ASpam
« Reply #66 on: August 07, 2008, 07:02:57 pm »
Looks like a pile of awesome. I'll try her out! :)
:\ May be a him :o anyways NIce work as usual jay :)
Re: ASpam
« Reply #67 on: August 07, 2008, 07:11:37 pm »
Thank you!
Offline nofear1999
Re: ASpam
« Reply #68 on: August 07, 2008, 08:08:05 pm »
I added it onto my server im testing it out right now ;)
Offline Smoot178
Re: ASpam
« Reply #69 on: August 08, 2008, 06:51:41 am »
V1.9
Nooooooooooo.  It works now btw.  LOL.  I will still get the new promotions system!
Could I make a suggestion?
I would like some sort of ingame GUI where I can check the status of each player and the different promotional groups.
Also, you should be able to set the time it takes to promote from one group to another.  Say User -> Respected takes 5 hours and Respected -> Regular takes 17 hours.  You should also be able to change this on the fly ingame using the menu :P
Re: ASpam
« Reply #70 on: August 08, 2008, 07:52:06 am »
Suggestions noted, and as for the way the users were promoted previously; the were promoted by this formula:
time = time - (warning * penalty )
time > (interval * (#goups_to_promote - (#groups_to_promote + 1)))
I'm too tired to think too much right now, but I'm pretty sure that's how it's coded.
Offline Chief_runningwater
  • Fpsbanana User
    • Chiefrunningwater.com
Re: ASpam
« Reply #71 on: August 09, 2008, 11:31:38 am »
Is there any way of disabling the promotion thing I don't want people being promoted and I don't know lua at all...
Re: ASpam
« Reply #72 on: August 09, 2008, 12:12:51 pm »
V1.9
The Promotions have been removed, just if you have ASpam previously installed delete the original ASpam folder, and replace with v1.9
Gunner71
Re: ASpam
« Reply #73 on: September 22, 2008, 06:54:09 pm »
instead of kicking people who spawn an adv dup over 10 seconds, why not just delete the dup they were spawning and give them a warning message? like "Please do not spawn dups that large."
Also can you add stacker support like if they try to stack over 10 props it will add a warning level and give them a warning
Re: ASpam
« Reply #74 on: September 22, 2008, 07:24:17 pm »
     -This would require a re-work of the entire code, and atm I'm working on a few more releases.
     -I've thought about this, but it is also another thing that would require alot of change to the existing code to get it working.
