Author Topic: ASpam  (Read 174441 times)
Offline NikolaiResokav
Re: ASpam
« Reply #75 on: September 25, 2008, 07:00:01 pm »
Is there any way to make admins immune to the spam kicker?
Nikolai Resokav
Re: ASpam
« Reply #76 on: October 02, 2008, 05:33:29 am »
I will work on adding this feature tonight, unless someone wants to take up the job?
Offline DiscoBiscuit
    • DiscoBuild
Re: ASpam
« Reply #77 on: December 18, 2008, 06:07:40 pm »
When I tossed this into my server, someone convieniantly spammed, and when the warnings got to 10 it just started cleaning his crap up over and over and the number left went into the negatives  ???
Is there any way to make it kick them instead?
Re: ASpam
« Reply #78 on: December 18, 2008, 07:02:27 pm »
It does kick them if you have ULX, ULib, and ASpam installed properly.
Offline Hardy
Re: ASpam
« Reply #79 on: December 18, 2008, 10:52:14 pm »
It does that before latest gmod update(50)(i think it is why), now it doesn't...
Re: ASpam
« Reply #80 on: December 19, 2008, 05:35:35 am »
The update shouldn't of been able to do anything to it, since it uses the ULib.kick() function milliseconds after removing their props.
Offline Hardy
Re: ASpam
« Reply #81 on: January 04, 2009, 05:36:00 am »
Rly? Maybe you check it out?
(Console) to admins: Player hardy is spamming, and has a warn level of 5. Kicking them after 5 more warnings
hardy<STEAM_0:0:12673821> spawned model models/props_borealis/bluebarrel001.mdl
You must wait 0.3 second(s) before spawning another prop/ent
If you continue to Spam, you will be kicked!
(Console) to admins: Player hardy is spamming, and has a warn level of 6. Kicking them after 4 more warnings
(Console) to admins: Player hardy is spamming, and has a warn level of 7. Kicking them after 3 more warnings
(Console) to admins: Player hardy is spamming, and has a warn level of 8. Kicking them after 2 more warnings
hardy's props have been cleaned up
(Console) to admins: Player hardy is spamming, and has a warn level of 9. Kicking them after 1 more warnings
(Console) to admins: Player hardy is spamming, and has a warn level of 10. Kicking them after 0 more warnings
player hardy's props have been removed
(Console) to admins: Player hardy is spamming, and has a warn level of 11. Kicking them after -1 more warnings
all cleaned
(Console) to admins: Player hardy is spamming, and has a warn level of 12. Kicking them after -2 more warnings
all cleaned
all cleaned
(Console) to admins: Player hardy is spamming, and has a warn level of 13. Kicking them after -3 more warnings
(Console) to admins: Player hardy is spamming, and has a warn level of 14. Kicking them after -4 more warnings
all cleaned
all cleaned
Re: ASpam
« Reply #82 on: January 04, 2009, 03:46:56 pm »
You must have another addon that is hindering the script, cause I've tested it with all the common ones and it still works.
Re: ASpam
« Reply #83 on: January 04, 2009, 04:01:35 pm »
Jay, he's having problems with UPS too. I'm definitely leaning towards his issue being addon conflict.
However, could either be affecting the other? That is, could ASpam be preventing UPS from working or perhaps vice versa.
Re: ASpam
« Reply #84 on: January 04, 2009, 07:42:22 pm »
No, infact ASpam is designed to use UPS :D
Offline jdjesse
Re: ASpam
« Reply #85 on: January 05, 2009, 02:10:09 pm »
I had this problem also. It was giving - levels.
Offline Nuclear_Ice
Re: ASpam
« Reply #86 on: January 10, 2009, 06:32:30 pm »
I flippin love this! But how can I make it so it doesn't affect admins? lol
Offline Cephalexin
Re: ASpam
« Reply #87 on: January 27, 2009, 02:17:41 am »
I have had the same problem to where it will not kick
Offline Darksoul
Re: ASpam
« Reply #88 on: January 27, 2009, 07:22:46 am »
Won't kick. It's likely a easy fix though.
Offline Alex
Re: ASpam
« Reply #89 on: January 28, 2009, 08:26:41 pm »
Please fix this! Me wantz.  :'(
:) Alex T. :)
