Author Topic: sui_scoreboard with UTime and Steam Avatars  (Read 184442 times)
Offline notownz
Re: sui_scoreboard with UTime and Steam Avatars
« Reply #165 on: October 16, 2014, 05:43:39 pm »
Will this work with murder gamemode?
Thanks
notownz
Offline Xopez
« Reply #166 on: April 10, 2016, 02:16:44 pm »
I get following error and dont know why, utime is running, it shows up in clients.
it doesn't matter if its the utime version or no utime version
[ERROR] addons/sui_scoreboard/lua/sui_scoreboard/player_infocard.lua:124: attempt to call method 'GetCount' (a nil value)
  1. UpdatePlayerData - addons/sui_scoreboard/lua/sui_scoreboard/player_infocard.lua:124
   2. SetPlayer - addons/sui_scoreboard/lua/sui_scoreboard/player_infocard.lua:107
    3. SetPlayer - addons/sui_scoreboard/lua/sui_scoreboard/player_row.lua:91
     4. AddPlayerRow - addons/sui_scoreboard/lua/sui_scoreboard/scoreboard.lua:94
      5. UpdateScoreboard - addons/sui_scoreboard/lua/sui_scoreboard/scoreboard.lua:269
       6. Init - addons/sui_scoreboard/lua/sui_scoreboard/scoreboard.lua:62
        7. Create - lua/includes/extensions/client/panel/scriptedpanels.lua:37
         8. CreateScoreboard - addons/sui_scoreboard/lua/autorun/sui_scoreboard.lua:33
          9. unknown - addons/sui_scoreboard/lua/autorun/sui_scoreboard.lua:40
[ERROR] addons/sui_scoreboard/lua/sui_scoreboard/scoreboard.lua:234: attempt to index field 'lblPing' (a nil value)
  1. unknown - addons/sui_scoreboard/lua/sui_scoreboard/scoreboard.lua:234
[ERROR] addons/sui_scoreboard/lua/sui_scoreboard/scoreboard.lua:202: attempt to index field 'lblPing' (a nil value)
  1. unknown - addons/sui_scoreboard/lua/sui_scoreboard/scoreboard.lua:202
[ERROR] addons/sui_scoreboard/lua/autorun/sui_scoreboard.lua:56: attempt to index global 'SuiScoreBoard' (a nil value)
  1. unknown - addons/sui_scoreboard/lua/autorun/sui_scoreboard.lua:56
« Reply #167 on: April 10, 2016, 07:17:46 pm »
Xopez, I'd be surprised if you could get this working.
The original post is 4+ years old.
The last post of the thread before yours was 1.5 years ago.
Make sure you're using the last known working code, submitted by someone other than the original developer, from this 1.5 year old message.
/index.php/topic,3650.150.html#msg35204 />
If it's not working, we likely need to move it to Release archives in read-only.
I probably didn't move it last time I cleaned the releases section because it was about a year ago, and that link I posted above was probably working at the time.
Gmod's updated many times since then, as has ULIb and ULX.
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
« Reply #168 on: April 13, 2016, 02:45:37 am »
« Reply #169 on: April 13, 2016, 06:40:45 pm »
I'd recommend using the workshop version
It's even older than the one I linked.
Updated Jul 23, 2013 @ 5:13pm
