Author Topic: sui_scoreboard with UTime and Steam Avatars  (Read 184442 times)
Offline TweaK
    • Garry's Mod Engineers
Re: sui_scoreboard with UTime and Steam Avatars
« Reply #150 on: April 16, 2013, 11:35:25 am »
You mean the ratings? Shouldn't be too hard to hide if you comment out some things in the info panel...
Offline Ch1lly
« Reply #151 on: April 16, 2013, 12:04:57 pm »
Yes I mean those. I'll have a look, although I'm noob ;)
Offline Duke Nukem
« Reply #152 on: April 17, 2013, 06:43:16 am »
Does this work on TTT?
Offline Ch1lly
« Reply #153 on: April 17, 2013, 12:44:42 pm »
Are these the lines I should comment out from player_infocard.lua?
self.VoteButtons[5] = vgui.Create( "suispawnmenuvotebutton", self )
   self.VoteButtons[5]:SetUp( "icon16/wrench.png", "builder", "Good at building!" )
Offline bballchamp99
« Reply #154 on: April 18, 2013, 07:09:08 pm »
I keep getting this error with both versions of sui_scoreboard
[ERROR] addons/sui_scoreboard_modified_v4_no_utime/lua/sui_scoreboard/player_row.lua:3: bad argument #2 to 'CreateFont' (table expected, got number)
  1. CreateFont - [C]:-1
   2. unknown - addons/sui_scoreboard_modified_v4_no_utime/lua/sui_scoreboard/player_row.lua:3
    3. include - [C]:-1
     4. unknown - addons/sui_scoreboard_modified_v4_no_utime/lua/sui_scoreboard/scoreboard.lua:1
      5. include - [C]:-1
       6. unknown - addons/sui_scoreboard_modified_v4_no_utime/lua/autorun/sui_scoreboard.lua:14
[ERROR] addons/sui_scoreboard_modified_v4_no_utime/lua/sui_scoreboard/scoreboard.lua:4: bad argument #2 to 'CreateFont' (table expected, got number)
   2. unknown - addons/sui_scoreboard_modified_v4_no_utime/lua/sui_scoreboard/scoreboard.lua:4
    3. include - [C]:-1
any help would be great and thank you.
Offline TweaK
« Reply #155 on: April 19, 2013, 01:23:21 am »
-stuff-
I think you downloaded the gm12 version from the OP, give this one a try https://dl.dropbox.com/u/7934790/gmod/sui_scoreboard.zip
Give it a try *shrug* that may be all you need to do
« Reply #156 on: April 19, 2013, 02:39:52 pm »
Ok the version you gave me works but it says my team is unassigned! I tried to set teams for myself and changed groups in ulx but it wont work any help?
Offline TweaK
« Reply #157 on: April 20, 2013, 08:42:07 am »
Yeah, sounds like a problem with your teams/groups setup... make sure you have given them all a name/color and such, beyond that I'm not really sure.
Offline Ch1lly
« Reply #158 on: May 06, 2013, 01:37:16 am »
Sorry for the necro but I thought it would be useful info for the thread. The lines I stated are the ones that need removing/commenting out to get rid of the buttons.
In player_infocard.lua just comment out lines 21 to 68.
Now when you expand someones details on the scoreboard, you'll get an error. Simply comment out lines 234 to 244 in player_infocard.lua also. See below
-- for k, v in ipairs( self.VoteButtons ) do
      -- v:InvalidateLayout()
      -- if k < 6 then
         -- v:SetPos( self:GetWide() -  k * 25, 0 )
      -- elseif k < 11 then
         -- v:SetPos( self:GetWide() -  (k-5) * 25, 36 )
      -- else
         -- v:SetPos( self:GetWide() -  (k-10) * 25, 72 )
      -- end
      -- v:SetSize( 20, 32 )
   -- end
Offline venom1324
« Reply #159 on: July 05, 2013, 06:32:20 am »
[ERROR] addons/sui_scoreboard/lua/sui_scoreboard/player_row.lua:113: attempt to call method 'GetUTimeTotalTime' (a nil value)
  1. UpdatePlayerData - addons/sui_scoreboard/lua/sui_scoreboard/player_row.lua:113
   2. SetPlayer - addons/sui_scoreboard/lua/sui_scoreboard/player_row.lua:92
    3. AddPlayerRow - addons/sui_scoreboard/lua/sui_scoreboard/scoreboard.lua:94
     4. UpdateScoreboard - addons/sui_scoreboard/lua/sui_scoreboard/scoreboard.lua:269
      5. Init - addons/sui_scoreboard/lua/sui_scoreboard/scoreboard.lua:62
       6. Create - lua/includes/extensions/client/panel/scriptedpanels.lua:153
        7. CreateScoreboard - addons/sui_scoreboard/lua/autorun/sui_scoreboard.lua:33
         8. unknown - addons/sui_scoreboard/lua/autorun/sui_scoreboard.lua:40
[ERROR] addons/sui_scoreboard/lua/sui_scoreboard/scoreboard.lua:234: attempt to index field 'lblPing' (a nil value)
  1. unknown - addons/sui_scoreboard/lua/sui_scoreboard/scoreboard.lua:234
[ERROR] addons/sui_scoreboard/lua/sui_scoreboard/scoreboard.lua:202: attempt to index field 'lblPing' (a nil value)
  1. unknown - addons/sui_scoreboard/lua/sui_scoreboard/scoreboard.lua:202
   2. unknown - addons/sui_scoreboard/lua/sui_scoreboard/player_row.lua:251
When trying to open scoreboard on server. Why this addon is soo outdated?
Offline TweaK
« Reply #160 on: July 05, 2013, 11:07:11 am »
That error is due to not having UTime properly installed.
Offline Epsilon
« Reply #161 on: July 28, 2013, 03:00:25 am »
So where is the data for each individual client's ratings stored?
« Reply #162 on: July 28, 2013, 03:10:23 am »
The ratings are stored in sv.db if I remember correctly. It's a SQLite database.
« Reply #163 on: July 28, 2013, 05:50:32 am »
Memory serves you well.
From UTime thread - /index.php/topic,3039.45.html#msg10509 starts a 3-4 post discussion confirming it.
Offline nexbr
« Reply #164 on: February 06, 2014, 03:36:26 am »
I like to share here my version of SUI Scoreboard, it is compatible with Exsto or ULX + uTime or only ULX.
It have the mute button and i fixed the Steam Avatar clickable but this is not the TweaK's code.
I imported the missing vgui textures from Garry's Mod 11, and it will be downloaded automatically from steam Workshop.
The time connected (total or only from the current session (without uTime)) are formated as weeks, days, hours, minutes, and seconds just like in uTime.
Fixed Admin buttons (Kick, 1h Ban and PermBan).
You can download it from Github or Steam Workshop
It have suicidal.banana approved Seal  ;).
If you think on my version there is some coding you did (and if you really did) i'll be happy to add the credits.
« Last Edit: February 06, 2014, 03:38:06 am by nexbr »
