Author Topic: sui_scoreboard with UTime and Steam Avatars  (Read 184442 times)
Offline Adult
Re: sui_scoreboard with UTime and Steam Avatars
« Reply #120 on: November 25, 2012, 05:21:20 pm »
I tried getting it working. I got it working, but not pretty. Before, it would update while you had it open, but now it will not, and it also looks retarded.
If anyone wants to take a shot at making it look prettier, by all means.
Offline Mors Quaedam
« Reply #121 on: November 26, 2012, 09:18:34 am »
Offline nexbr
« Reply #122 on: December 09, 2012, 03:01:25 am »
The version of workshop are not working.
Please keep working on your version @Adult. With or without Utime.
The version from Workshop as created 28 oct this year, so they are not updating, so are not working ok.
Giving errors
[ERROR] lua/autorun/cl_utime.lua:41: attempt to call method 'GetActiveWeapon' (a nil value)
1. unknown - lua/autorun/cl_utime.lua:41
Timer Failed! [UTimeThink][@lua/autorun/cl_utime.lua (line 64)]
And
--- Missing Vgui material gui/silkicons/star
--- Missing Vgui material gui/silkicons/palette
--- Missing Vgui material gui/silkicons/heart
--- Missing Vgui material gui/silkicons/user
--- Missing Vgui material gui/silkicons/exclamation
And Utime are not repositioning
« Last Edit: December 09, 2012, 04:43:11 am by nexbr »
Offline TweaK
    • Garry's Mod Engineers
« Reply #123 on: January 11, 2013, 05:22:44 pm »
I fixed some of the quirks in Wrex's version (the workshop link) and added mute buttons on the player info panels since garry moved that functionality from the menu to the scoreboard
https://dl.dropbox.com/u/7934790/gmod/sui_scoreboard.zip
edit: oh and made the steam avatars clickable again
« Last Edit: January 13, 2013, 12:09:24 pm by TweaK »
Offline krooks
  • I don't like video games.
    • Diamond Krooks
« Reply #124 on: January 12, 2013, 12:12:57 am »
Thanks Tweak, I'll be setting up a SB server here soon, will grab your version.
My TTT server. Join the fun!
Offline naBs
« Reply #125 on: January 23, 2013, 02:59:39 pm »
Hi, using the upload from TweaK I'm getting disconnected every time I bring up the scoreboard, I'm not sure whether it's due to me not installing it properly but I get the 'Too many lua errors' or something like that error...here's what it says in console
'[ERROR] lua/sui_scoreboard/player_row.lua:112: attempt to call method 'GetUTimeTotalTime' (a nil value)
  1. UpdatePlayerData - lua/sui_scoreboard/player_row.lua:112
   2. SetPlayer - lua/sui_scoreboard/player_row.lua:91
    3. AddPlayerRow - lua/sui_scoreboard/scoreboard.lua:94
     4. UpdateScoreboard - lua/sui_scoreboard/scoreboard.lua:269
      5. Init - lua/sui_scoreboard/scoreboard.lua:62
       6. Create - lua/includes/extensions/client/panel/scriptedpanels.lua:153
        7. CreateScoreboard - lua/autorun/sui_scoreboard.lua:33
         8. unknown - lua/autorun/sui_scoreboard.lua:40
[ERROR] lua/sui_scoreboard/scoreboard.lua:234: attempt to index field 'lblPing' (a nil value)
  1. unknown - lua/sui_scoreboard/scoreboard.lua:234
[ERROR] lua/sui_scoreboard/scoreboard.lua:202: attempt to index field 'lblPing' (a nil value)
  1. unknown - lua/sui_scoreboard/scoreboard.lua:202
   2. unknown - lua/sui_scoreboard/player_row.lua:264
[ERROR] lua/sui_scoreboard/scoreboard.lua:202: attempt '
Any help and feedback is appreciated! Would like to know how to properly install this as well please just in case I'm not doing it correctly.
Offline TweaK
« Reply #126 on: January 23, 2013, 06:16:47 pm »
Looks like you don't have UTime installed
Offline naBs
« Reply #127 on: January 24, 2013, 11:43:43 am »
Any ideas as to where I can get Utime? XD
Offline Adult
« Reply #128 on: January 24, 2013, 12:19:51 pm »
« Reply #129 on: January 24, 2013, 12:23:23 pm »
Technically the latest version is on GitHub like all our other up-to-date things. We're hoping to have actual releases sometime soon, though! :)
Offline naBs
« Reply #130 on: January 24, 2013, 12:57:43 pm »
Thanks guys, I'm just adding everything to my server now, and re installing the scoreboard (this time with Utime installed, I got this Utime version from github also so should be the latest one) I'll let you guys know how it goes, thanks again
Offline naBs
« Reply #131 on: January 24, 2013, 01:57:50 pm »
Okay, so I ran the server with Utime and the SUI scoreboard installed, Utime from the github and the scoreboard was TweaKs upload. I still got some errors, I don't think I'm installing the SUI correctly, can anyone provide some quick installation steps please? Just to ensure I am doing it right. Here's the errors still:
  1. unknown - lua/sui_scoreboard/scoreboard.lua:202'
Offline TweaK
« Reply #132 on: January 24, 2013, 03:36:11 pm »
Yeah you might want to check and see if UTime is installed correctly, that "attempt to call method 'GetUTimeTotalTime' (a nil value)" error means it isn't loading. The path should be addons/utime/addon.txt with no folders in between.
Offline naBs
« Reply #133 on: January 24, 2013, 04:31:45 pm »
Finally got it to work, thanks guys appreciate all the help! :)
Offline pieman88
« Reply #134 on: March 03, 2013, 01:57:47 pm »
how do i install it ;(
