Author Topic: last update , one command don't work  (Read 14668 times)
Offline Enrico42
« on: September 27, 2008, 06:54:42 pm »
Hello, I noticed that the command !Gimp "...." did not work in the last update of ULX
it produces no errors in the console, confirms that it is applied , but the person can still speak correctly in the chat, his words are not replaced
Re: last update , one command don't work
« Reply #1 on: September 27, 2008, 07:35:44 pm »
Which update? Release (3.31), or SVN?
Have you edited any of the gimp statements?
If so, make sure you're syntax is correct.
Offline Enrico42
« Reply #2 on: September 28, 2008, 06:12:30 am »
it's last version svn , yes i edited , but my friends , he have ulx don't edited and also it does not work anymore
look my server.ini
//Any of the settings in here can be added to the per-map configs.
ulx showMotd 1 // Set to 0 to disable showing motd on connect. Shows the file the cvar motdfile says to.
ulx addGimpSay "Je suis un gros gay"
ulx addGimpSay "Je l'avoue je suis un boulet"
ulx addGimpSay "ahahaha que je suis con"
ulx addGimpSay "Achevez moi !!"
ulx addGimpSay "J'ai pas d'amis , SOS amitier"
ulx addGimpSay "j'aime les pommes"
ulx addGimpSay "kiker moi !!! je sert a rien"
ulx addGimpSay "Acheter moi un cerveau svp !"
ulx addGimpSay "Je suis un noob !"
ulx addGimpSay "pourquoi suis-je con ??"
ulx addGimpSay "ahhhhhh mongoleeeee"
ulx addGimpSay "boulet power !!!"
ulx addGimpSay "on peut me kicker je sert a rien"
ulx addGimpSay "c'est quoi un ordinateur , acheter moi un cerveau"
ulx addGimpSay "je suis finis a la pisse"
ulx mingekick 0 // If set to 1, players with the name MingeBag will be kicked
ulx chattime 0 // Players can only chat every x seconds (anti-spam). 0 to disable
« Last Edit: September 28, 2008, 06:14:11 am by Enrico42 »
« Reply #3 on: September 28, 2008, 07:52:45 am »
French server? What would be your interest in future ULX versions having a separated list of strings for easy translation?
Offline Enrico42
« Reply #4 on: September 28, 2008, 08:05:51 am »
yes i'm french and my server is french too ,
in the future, it would be nice to have translations in French, or at least have the opportunity to change things in French ^^
Otherwise, the command "!gimp" does not work?
« Reply #5 on: September 28, 2008, 10:18:57 am »
Confirmed. Gimp isn't working, and I'm concerned that perhaps none of the other ULX commands in server.ini aren't working either.
Several 'unknown command: ulx" appear at first startup, as though the server.ini ulx commands aren't being executed.
I'll do more testing if I have time today.
« Last Edit: September 28, 2008, 10:40:08 am by JamminR »
Offline Enrico42
« Reply #6 on: September 28, 2008, 11:51:24 am »
if you need help count on me ^ ^, I like your job on ULX, this is a wonderful plugin, hold me up to date for the translation and when it is repaired
thank you
« Reply #7 on: September 28, 2008, 01:01:52 pm »
Megiddo, Jay, Spbogie
I've gone back as far as revision 10. (TortoiseSVN reports we're currently on 17)
This same error keeps happening, and no changes I make to server.ini (saved into /gmod/cfg/server.ini) get applied.
In revision 13 and up, during load of local game, I see several "Unknown Command: ulx" - exact number matching the amount of server.ini ulx commands.
In 10,11 and 12, I oddly enough don't get that error, but, none of my server.ini settings are applied.
I'm starting to suspect this isn't a change we made, but something to do with Garry's 'Fix' Gmod patch for the exploit comwalk discovered and reported.
I believe one of you will need to dig further for me.
Megiddo, you're top notch with the ULX initialization you've constantly had to re-do due to Garry's methods...I'm betting you could find it in a heartbeat.
Offline Enrico42
« Reply #8 on: September 28, 2008, 03:44:50 pm »
Great Megiddo, and good luck to correct these bugs ^ ^
« Reply #9 on: September 28, 2008, 07:08:43 pm »
Will look at it this afternoon...
Offline Enrico42
« Reply #10 on: October 01, 2008, 07:01:07 am »
This advance, you found the problem?
« Reply #11 on: October 01, 2008, 07:36:27 am »
Just tried it and was unable to replicate this problem.
« Reply #12 on: October 01, 2008, 12:14:13 pm »
On a listen server?
« Reply #13 on: October 01, 2008, 05:00:32 pm »
Dedicated
« Reply #14 on: October 01, 2008, 07:45:31 pm »
Dedicated
Enrico, are you on a dedicated, or listen server?
Megiddo, I tried it in game on a listen of my own.
What Enrico stated happened to me too. None of the server.ini commands were executed.
I _COULD_ run addGimpSay from console once in game, then run !gimp on myself, and it worked fine.
Something about server.ini just didn't execute and caused errors at startup.
