Author Topic: last update , one command don't work  (Read 14668 times)
Re: last update , one command don't work
« Reply #15 on: October 01, 2008, 08:27:57 pm »
Enrico, are you on a dedicated, or listen server?
Megiddo, I tried it in game on a listen of my own.
What Enrico stated happened to me too. None of the server.ini commands were executed.
I _COULD_ run addGimpSay from console once in game, then run !gimp on myself, and it worked fine.
Something about server.ini just didn't execute and caused errors at startup.
Bah (humbug), I'll try it in a listen. Darn listen servers are always causing problems... :)
Offline Enrico42
« Reply #16 on: October 04, 2008, 06:26:00 am »
I corrected the problem, it is enough simply to make a copy of server.ini and paste it into garrysmod / cfg / ..
all work  ;D
« Reply #17 on: October 04, 2008, 08:09:53 am »
Odd. gmod/cfg is where I have mine. Still not working for me.
Megiddo, though not always read, perhaps we should give more clear direction in the readme and the actual server.ini itself that people should save the ini to the cfg folder.
I think we do it in ULibs group and user.txt, but we don't do it for server.ini now that we've moved the default load location.
