Poll
Yes, Much Better!
71 (59.7%)
Yeah
22 (18.5%)
14 (11.8%)
No
4 (3.4%)
I Prefer The Old GUI
8 (6.7%)
Total Members Voted: 1
Offline bennie900
Re: URestrict
« Reply #255 on: August 18, 2009, 04:42:52 pm »
Your doing some thing very wrong then. Mine works (31) with latest ULX and ULIB.
JackBauer
Re: URestrict
« Reply #256 on: August 18, 2009, 05:54:47 pm »
I use the latest ulx and ulib this admin mod is 99% okay , only my motd is disabel. I use only ULX not Assmod or anything.
Offline bennie900
Re: URestrict
« Reply #257 on: August 18, 2009, 06:09:06 pm »
To enable motd goto garrysmod/addons/ulx/cfg/server.ini and edit the first bit of code
ulx showMotd 0
so it looks like
ulx showMotd 1
Do a restart and it should appear.
NOTE: 0 = Disabled and 1 = Enabled.
« Last Edit: August 18, 2009, 06:10:39 pm by bennie900 »
JackBauer
Re: URestrict
« Reply #258 on: August 18, 2009, 06:13:57 pm »
thanks, my URestrict Problem still.
Offline bennie900
Re: URestrict
« Reply #259 on: August 18, 2009, 06:15:18 pm »
Tell me step by step what you do with URestrict.
JackBauer
Re: URestrict
« Reply #260 on: August 18, 2009, 06:23:03 pm »
1. I have load the Latest Version and i cant Open the Menu.
2. I Update the Version and i type URestrict in to my console: You have not acess to this Command JackBauer
3. I load version 31 and set acess and test it.
4. I can spawn all.
4. I have downgrade to 30 and Test it.
5. I can spawn all.
« Last Edit: August 18, 2009, 06:56:13 pm by JackBauer »
Re: URestrict
« Reply #261 on: August 18, 2009, 07:46:57 pm »
Revision 39:
     *Added Autocomplete For The Console Commands
Offline bennie900
Re: URestrict
« Reply #262 on: August 19, 2009, 02:10:14 am »
In your data folder (garrysmod/data) do you have a URestrict folder in there? It should look like (garrysmod/data/URestrict/Loadouts and garrysmod/data/URestrict/Tools)
JackBauer
Re: URestrict
« Reply #263 on: August 19, 2009, 02:31:04 am »
yes i have.
JackBauer
Re: URestrict
« Reply #264 on: August 19, 2009, 04:49:50 am »
can not anyone help` ???
Admin)*G»P«O* Dr. JackBauer, revoked user use of dynamite
] rcon_password **
] rcon ulx removeuser jack
(ADMIN) (Console) removed all of *G»P«O* Dr. JackBauer's access rights
] kill
*G»P«O* Dr. JackBauer suicided!
noclip ON
You have hit the dynamite limit!
« Last Edit: August 19, 2009, 07:45:51 am by JackBauer »
Offline bennie900
Re: URestrict
« Reply #265 on: August 19, 2009, 07:51:45 am »
Thats a good thing? You have taken away the rights from the group "user" so they can't use the tool... "You have hit the dynamite limit!" Means its working... Don't see what the problem is..
« Last Edit: August 19, 2009, 07:56:19 am by bennie900 »
JackBauer
Re: URestrict
« Reply #266 on: August 19, 2009, 09:06:33 am »
I can use this tool but i  set it to not allowed...
You hit the dynamit limit means it is not working i can spawn it!
Admin)*G»P«O* Dr. JackBauer, revoked user use of dynamite (user not allowed to spawn this)
] rcon_password **
(ADMIN) (Console) removed all of *G»P«O* Dr. JackBauer's access rights (set me to user)
] kill
*G»P«O* Dr. JackBauer suicided! (me killed)
noclip ON
You have hit the dynamite limit! (it dont work i can spawn it)
« Last Edit: August 19, 2009, 09:13:44 am by JackBauer »
Offline bennie900
Re: URestrict
« Reply #267 on: August 19, 2009, 09:39:48 am »
Try to remove URestrict from addons, and the data folder. Restart your server then re add the addon, then do another restart. Not sure why its not workin.
JackBauer
Re: URestrict
« Reply #268 on: August 19, 2009, 10:35:33 am »
I have make it bu my Problem still.
Re: URestrict
« Reply #269 on: August 19, 2009, 10:38:13 am »
Run in the server console:
lua_run PrintTable(URestrict)
