Poll
Yes, Much Better!
71 (59.7%)
Yeah
22 (18.5%)
14 (11.8%)
No
4 (3.4%)
I Prefer The Old GUI
8 (6.7%)
Total Members Voted: 1
JackBauer
Re: URestrict
« Reply #270 on: August 19, 2009, 10:52:25 am »
Run in the server console:
lua_run PrintTable(URestrict)
hmmm nothing. I have see ERRORS:
ERROR: Hook 'URestrict_Loadout_Hock' Failed: Ulib/modules/server/URestrict.lua:151: attempt to index field '?' (a nail value)
ERROR: Hook 'URestrict.PickupHock' Failed: Ulib/modules/server/URestrict.lua:151: attempt to index field '?' (a nail value)
ERROR: Hook 'URestrict_CanTool_Hock' Failed: Ulib/modules/server/URestrict.lua:151: attempt to index field '?' (a nail value)
« Last Edit: August 19, 2009, 10:54:45 am by JackBauer »
Offline SmokingBarrel
Re: URestrict
« Reply #271 on: August 19, 2009, 11:34:13 am »
Also having a problem with URestrict, I've installed it properly in the addons folder it has created the URestrict folder in my data folder however It refuses to use the loadouts in the loadouts.txt file.
Here is my loadouts.txt file in my data\URestrict folder
"rebel"
"loadout"
"weapon_physgun"
"weapon_physcannon"
"gmod_camera"
"gmod_tool"
"weapon_para"
"weapon_deagle"
"weapon_mp5"
"weapon_crowbar"
"weapon_pumpshotgun"
"groups"
"rebel"
"excluded"
"police"
"loadout"
"weapon_physgun"
"weapon_physcannon"
"gmod_camera"
"gmod_tool"
"weapon_m4"
"weapon_stunstick"
"weapon_deagle"
"groups"
"police"
"regular"
"loadout"
"weapon_physgun"
"weapon_physcannon"
"gmod_camera"
"gmod_tool"
"weapon_peapis"
"weapon_peashotty"
"groups"
"regular"
"criminal"
"loadout"
"weapon_physgun"
"weapon_physcannon"
"gmod_camera"
"gmod_tool"
"weapon_mac10"
"weapon_glock"
"groups"
"criminal"
"player"
"loadout"
"weapon_physgun"
"weapon_physcannon"
"gmod_camera"
"gmod_tool"
"weapon_peapis"
"weapon_peashot"
"groups"
"user"
"default"
"loadout"
"weapon_physgun"
"weapon_physcannon"
"gmod_camera"
"gmod_tool"
"groups"
"undead"
"admin"
"loadout"
"weapon_physgun"
"weapon_physcannon"
"gmod_camera"
"gmod_tool"
"weapon_crowbar"
"weapon_AWP"
"rt_combinemortar"
"weapon_godsmiter"
"groups"
"goldadmin"
"vetadmin"
"superadmin"
"supadmin"
"admin"
"soldier"
"loadout"
"weapon_physgun"
"weapon_physcannon"
"gmod_camera"
"gmod_tool"
"weapon_para"
"weapon_deagle"
"weapon_mp5"
"weapon_stunstick"
"groups"
"soldier"
"terrorist"
"loadout"
"weapon_physgun"
"weapon_physcannon"
"gmod_camera"
"gmod_tool"
"weapon_ak47"
"weapon_fiveseven"
"weapon_jihadbomb"
"groups"
"terrorist"
"cadet"
"loadout"
"weapon_physgun"
"weapon_physcannon"
"gmod_camera"
"gmod_tool"
"weapon_mp5"
"weapon_deagle"
"groups"
"cadet"
When I attempt to apply the loadouts to each group I get the following console errors.
] urestrict apply regular regular
ULib/client/cl_util.lua:108: Bad flow
Appreciate any feedback.
-Smoky
Offline bennie900
Re: URestrict
« Reply #272 on: August 19, 2009, 11:35:56 am »
Cant comment on this error, how ever try updating your ulib? May work.
Re: URestrict
« Reply #273 on: August 19, 2009, 11:46:02 am »
Updated Ulib and ULX, The errors went away but nothing happens when I run the commands now. URestrict Loadouts still aren't working, the default gamemode is still being used.
« Last Edit: August 19, 2009, 11:50:05 am by SmokingBarrel »
Re: URestrict
« Reply #274 on: August 19, 2009, 06:08:03 pm »
*Fixed ur.getLoadout() falsely report "excluded"
*Began work on the gui
     -Update URestrict and let me know if that solves your problem, I tested it with your configs and everything works.
Re: URestrict
« Reply #275 on: August 19, 2009, 06:42:42 pm »
Revision 42:
*Added URestrict Modify <loadout> <weapon to add/remove> <weapon to add/remove> ... (Automatically determines if the weapon needs to be added or removed by checking to see if it already exists in the loadout.)
Re: URestrict
« Reply #276 on: August 19, 2009, 08:11:40 pm »
I updated now; All ranks have a loadout of  psygun, Grav gun, camera and Toolgun.
Here's a screenshot of your Gui, I don't know if the information it's displaying is reliable but if it's making all my ranks excluded it explains it.
Some more information: The urestrict apply <rank> <loadout> is giving a message saying it's successful, However it is not changing the loadout.
Re: URestrict
« Reply #277 on: August 19, 2009, 08:29:59 pm »
Revision 43:
*ADDED command URestrict AdminExclude <loadouts|tools> <1|0>
*FIXED admin groups are no longer added to the excluded loadout when Admin Exclusion is set, the script just checks for boolean.
Revision 44
*Fixed GUI showing 90% of the groups excluded
     -URestrict doesn't choose what you spawn with, it only determine whether or not to allow the gamemode to give those items to you. You should be able to spawn/pickup the other items in the loadout  though.
     -If you're using Sandbox, the only items you will be able to spawn with are: weapon_crowbar, weapon_pistol, weapon_smg1,weapon_ frag, weapon_physcannon, weapon_crossbow, weapon_shotgun, weapon_357, weapon_rpg, weapon_ar2, gmod_tool, gmod_camera, and weapon_physgun.
Re: URestrict
« Reply #278 on: August 19, 2009, 09:28:03 pm »
Revision 45:
*Changed dimensions of the gui
*Activated the apply, remove, and update buttons
*URestrict Remove now updates to the gui
*Added admin only access
*Added a close button to the gui
« Last Edit: August 19, 2009, 09:53:13 pm by jay209015 »
Offline bennie900
Re: URestrict
« Reply #279 on: August 20, 2009, 03:26:39 am »
Looks nice!!! Now just for the tool restriction tab :P
JackBauer
Re: URestrict
« Reply #280 on: August 20, 2009, 03:54:32 am »
yes and i hope the bug is fixed.
Offline mishappp
Re: URestrict
« Reply #281 on: August 20, 2009, 02:54:29 pm »
I installed the new one and no one spawns with guns but all guns are allowed to be picked up, almost there, how do I access the gui?
I got into the gui but nothing is in there its blank, I put in that lua_run code and got this in return
includes\util.lua:35: bad argument #1 to 'pairs' (table expected, got nil)
« Last Edit: August 20, 2009, 03:04:10 pm by mishappp »
Re: URestrict
« Reply #282 on: August 20, 2009, 08:08:11 pm »
-URestrict in console to access the gui
-Update ULib/ulx/urestrict to the latest svn
-Make sure you do lua_run PrintTable(ur) in the server console, not the client. (works on client too, but would be lua_run_cl PrintTable(ur))
Re: URestrict
« Reply #283 on: August 21, 2009, 12:17:28 pm »
Requires The Latest SVN Version Of ULib!!
*Remove Update Button
*Added Automatic GUI Refreshing
*Added Working Modify, Make, Loadouts Enabled, Exclude Admins Buttons
*Allowed You To Hold Shift In The Groups Tab To Select Multiple Groups And Apply Them All To The Same loadout/loadouts.lua
*You Can Now Modify Loadouts In Game
*Now If You Select An Item From The Loadout In The GUI And Hit Modify, It Will Remove Those Items From The Loadout. Can Select More Then One At A Time
*If You Hit Modify Without A Weapon/Item Selected A Text Box Comes Up For You To Add Items To The Selected Loadout. To Add More Than One Item, Serate With A Space. Also If The Item You're Trying To Add Already Exists, It'll Remove It Instead.
*Included A Screen Shot With The Addon
*Added URestrict Toggle <tools|loadouts> (Toggles Tool/Loadout Restrictions)
New:
The Old :S
« Last Edit: August 21, 2009, 12:34:18 pm by jay209015 »
JackBauer
Re: URestrict
« Reply #284 on: August 21, 2009, 12:51:54 pm »
i need the tools restrict for my server but 31 not work.
