Poll
Yes, Much Better!
71 (59.7%)
Yeah
22 (18.5%)
14 (11.8%)
No
4 (3.4%)
I Prefer The Old GUI
8 (6.7%)
Total Members Voted: 1
Re: URestrict
« Reply #450 on: September 27, 2009, 09:21:54 am »
I have removed urestrict from my server until this problem is fixed.     - That doesn't help me at all. I need errors.
Re: URestrict
« Reply #451 on: September 27, 2009, 09:31:55 am »
Revision 29:
* Fixed tools not working do to a nil value
Offline Mysterymeat201
Urestrict
« Reply #452 on: September 29, 2009, 08:58:49 pm »
I'm running the current svn versions of ulib and ulx, however, when I attempt to install URestrict on my dedicated server (Run through lowpings) it doesn't really work. When the player spawns, they have no weapons whatsoever, including admins (I'm going to assume this is the default setting). As a superadmin, i have tried to access the console command for the gui but have only gotten a return message saying that the command was unrecognized. I looked through the console on my initial spawn and was greeted with this error message.
Ulib/modules/urestrict.lua:267: attempt to index field 'cmds' (a nil value)
Any help would be appreciated
Re: URestrict
« Reply #453 on: September 30, 2009, 04:36:20 am »
What revision of ULib are you using?
Offline NikoKun
Re: Urestrict
« Reply #454 on: September 30, 2009, 02:41:25 pm »
I have this exact same problem. I just got URestrict from the SNV today, Rev 29. (And I have ULX v3.40 and ULib v2.30)
"ULib/modules/urestrict.lua:267: attempt to index field 'cmds' (a nil value)"
No weapons, no tools, can't even spawn anything.
« Last Edit: September 30, 2009, 02:45:29 pm by NikoKun »
Re: URestrict
« Reply #455 on: September 30, 2009, 02:46:55 pm »
You need ULib SVN.
Offline NikoKun
Re: URestrict
« Reply #456 on: September 30, 2009, 03:36:48 pm »
ooooh... silly me. Thanks, I'll try that in a bit.
Edit: OK I got it working. Maybe the OP should mention that we need the SVN version.lol
« Last Edit: September 30, 2009, 09:19:27 pm by NikoKun »
Offline blt950
Re: URestrict
« Reply #457 on: October 04, 2009, 02:13:33 am »
I got a problem that I can't restrict some wiretools like wire_forcer.. It just says "invalid tool"
What to do?
Re: URestrict
« Reply #458 on: October 06, 2009, 12:31:44 pm »
For the time being, you'll have to do some wire tools manually in the data/urestrict files. For some reason wiremod doesn't follow the rules.
Offline Wayne Brady
Re: URestrict
« Reply #459 on: November 01, 2009, 05:53:53 pm »
I have this on my darkrp server, and I have a glitch with it. As soon as someone spawns, this error appears -
It causes players to spawn without weapons. How do I fix this?
Re: URestrict
« Reply #460 on: November 01, 2009, 07:41:14 pm »
Run latest SVN of ULib.
That error sounds like you aren't.
The official release version (v2.3) and below of ULib, URestrict isn't compatible with
Offline Simple
Re: URestrict
« Reply #461 on: November 04, 2009, 11:40:17 am »
          -Control what weapons/swept users are allowed to use based on what group they're in. Usage include spawning, picking up, and spawning with.
How do you go about doing that?
« Last Edit: November 04, 2009, 11:42:08 am by Simple »
Re: URestrict
« Reply #462 on: November 05, 2009, 08:21:06 am »
Creating Loadouts
1: Type URestrict in the console
2: Open the loadouts tab
3: Click Add ( Middle Column )
4: Type in a name for your loadout ( Text box appears after clicking add )
Changing Group Loadouts
3: Select what group you want to modify ( Column on the far left )
4: Select what loadout you wan that group to use ( Column in the middle )
5: Click apply ( Middle Column 3rd button from the bottom )
Modifying Loadouts
3: Select what loadout you want to modify  ( Column in the middle )
4:   To Remove Items From The Loadouts
      1: Select what items you want to remove (Column on the right )
      2: Click modify ( Column on the right )
5:   To Add Items To The Loadouts
      1: Click modify ( Column on the right )
      2: Type in what you want to add ( Text box appears after clicking modify)
Offline giloh
Re: URestrict
« Reply #463 on: November 07, 2009, 01:32:24 pm »
Is there a way to disable loadouts, because if you Exclude a group from it, they can use weapons that have been defined admin only in the .lua code of the weapon (eg. Admin Gun from CSS Realistic Weapons)
Re: URestrict
« Reply #464 on: November 08, 2009, 01:41:15 am »
     - Yes, but you bring up a good point. Even if you disable the loadouts, it'll override the admin only weapons. I'll work on a fix asap.
