Poll
Yes, Much Better!
71 (59.7%)
Yeah
22 (18.5%)
14 (11.8%)
No
4 (3.4%)
I Prefer The Old GUI
8 (6.7%)
Total Members Voted: 1
Offline blt950
Re: URestrict
« Reply #465 on: November 18, 2009, 09:53:04 am »
The tools restrictions seems to be broken. I still can use the tools that I disallowed .. I hope you fix this soon!
Offline Tom
Re: URestrict
« Reply #466 on: November 19, 2009, 12:23:21 pm »
Hey, This has broken on my server. Everything has become unrestricted and it has now an unknown command.
Has there been some sort of update?
Cheers,
Tom. x
« Last Edit: November 19, 2009, 12:27:33 pm by Tom »
Offline Tricks
Re: URestrict
« Reply #467 on: November 21, 2009, 07:03:07 am »
Cheers,
Tom. x
Make sure you are using the latest revisions of the SVN (ULib that is).
I have a question of my own. I have enabled the super admins on my server to have access to urestrict but they state that the server notifies them that they do not have access to the command. Any ideas?
Offline blt950
Re: URestrict
« Reply #468 on: November 21, 2009, 07:34:17 am »
I've the newest Ulib and ULX, and its still not working!
Re: URestrict
« Reply #469 on: November 21, 2009, 08:22:11 am »
All, you must provide more detail when reporting your issues.
"It doesn't work" is not a way that will help you get help in any way, shape, form, or fashion.
Megiddo had a nice link that I now can't find for how to report an error.
Provide Server console errors both from startup and when <x> is attempted. (most important)
Provide Game console errors both from startup and when <x> is attempted. . (not as, but yes, important)
If it just started happening, what did you just do? (new gamemode, addon, swep, sent, whatever, or update to any one of those)
Can you repeatedly cause the problem to happen? How could we, give steps.
Specifically to URestrict, what gamemode are you using? Many gamemodes use thier own restriction setting code which may overwrite what URestrict tries to do. DarkRP is a prime example. If you run Sandbox, default Gmod gamemode, and URestrict works fine, you need to speak to your gamemode's author to have the feature URestrict has that you want in the gamemode.
« Last Edit: November 21, 2009, 08:28:55 am by JamminR »
Offline blt950
Re: URestrict
« Reply #470 on: November 21, 2009, 08:25:41 am »
My problem is:
I add the tools I want to restrict for groups. But when the group that aren't allowed to use that tool try to use it. They can, it doesn't get restricted. I don't get any errors or anything.
I hope this was better described
Offline Tricks
Re: URestrict
« Reply #471 on: November 21, 2009, 09:58:21 am »
Here is the console output from my server.
Edit: For some reason I as well am now unable to access URestrict once again the access issue.
« Last Edit: November 21, 2009, 10:03:09 am by Tricks »
Offline Tom
Re: URestrict
« Reply #472 on: November 21, 2009, 11:43:20 am »
Well i cant even get into the gui....
Just one time i went on my server... everyone had guns...
I wanted to se what was wrong and when i type urestrict it says its an unknown command....
I checked... its still all installed....
No errors that I can see
Offline Tom
Re: URestrict
« Reply #473 on: November 26, 2009, 10:07:30 am »
Sorry to double post but... I reeeeaaallllyyy like Urestrict...
I cant make do with garry's sv_weapons!!!!!
Please help ^^
Re: URestrict
« Reply #474 on: November 26, 2009, 02:48:23 pm »
Tom, please post the output of your server console as;
1) it starts up.
2) You or another 'restricted' player joins.
3) When a 'restricted' player chooses a restricted weapon.
Please place these within the ['code']['/code'] tags (use the bar above the message text area or manually type them (my example has quotes in it, don't use quotes.
Also, not sure you're in America, but this is a holiday for us and therefore many of us are busy with family/friends away from computers.
This is already a slow forum. I check almost daily, Jay and Megiddo both are in college so have little free time.
Please don't double post again unless its been more than one month since last post. (Only because yes, sometimes we do miss a new post or forget to go back)
Saying 'sorry' during the fact doesn't make up for it. You knew it was wrong...so don't do it.
Thanks
Re: URestrict
« Reply #475 on: November 26, 2009, 09:19:38 pm »
1) it starts up.
     - Yeah, I need all that information from the server console.
Offline Tommo1590
Re: URestrict
« Reply #476 on: December 01, 2009, 07:31:46 pm »
Hey im also having a problem with this for some reason... it wont work,
When you join ulib loads it because it says this in the console;
[ULIB] Loading SHARED module: urestrict.lua
ULib/modules/urestrict.lua:267: attempt to index field 'cmds' (a nil value)
[ULIB] Loading CLIENT module: urestrict_cl.lua
but what i say URestrict in the console i just get a
] URestrict
Unknown command: URestrict
Help! Please!
Edit...
Also your spawn with no weapons, tool gun or anything :P
Re: URestrict
« Reply #477 on: December 01, 2009, 07:47:17 pm »
] URestrict
Help! Please!
Edit...
     - URestrict require the latest SVN version of ULib. Get that and your problems are solved.
Offline Tommo1590
Re: URestrict
« Reply #478 on: December 01, 2009, 08:22:57 pm »
Ok thanks ive updated it but now i get this
] urestrict
You Don't Have Access To This Command
Offline Speedpott
Re: URestrict
« Reply #479 on: December 02, 2009, 02:55:45 pm »
can i use it with ulx 3.40 :D`?
