Poll
Yes, Much Better!
71 (59.7%)
Yeah
22 (18.5%)
14 (11.8%)
No
4 (3.4%)
I Prefer The Old GUI
8 (6.7%)
Total Members Voted: 1
Re: URestrict
« Reply #540 on: March 21, 2010, 12:06:53 am »
Hmm.... all you configs look perfect, and I don't see any immediate errors in any of the code. Are you able to locate any errors in either server or client console? Look carefully.
Offline Kenny_
Re: URestrict
« Reply #541 on: March 21, 2010, 01:29:58 am »
I've been having the same problem for the past two weeks. I also have Falco's Prop Protection installed, which I think is causing the problem. I'll try to look into it tomorrow.
Offline superkyol
Re: URestrict
« Reply #542 on: March 21, 2010, 09:31:58 am »
Quote from: JamminR
Yes, clearing it is fine, but, are you then uploading it to your fast download server after a server restart?
Yup! I clear cache, restart, copy cache from server to HDD to fast download server, then restart again just to be safe.
Quote from: JamminR
Should have NO need to upload addons folder. Not recommended
Oh, that's what I hoped was the case.. I'm not sure why URestrict decides not to restrict tools then.
Quote from: jay209015
No errors at all, as far as I know.
Offline superkyol
Re: URestrict
« Reply #543 on: March 21, 2010, 12:39:26 pm »
Sorry to doublepost, for starters..
But yes, FPP is the culprit. I edited every LUA file and every reference to any tool restrictions called in FPP. and voila! :)
I know it's a very hack-and-slash approach that may render some other functions completely useless if used improperly, but so far everything seems to be okay.
So yeah, case in point, FPP is a giant douche. Hope this helps.
Re: URestrict
« Reply #544 on: March 21, 2010, 12:44:21 pm »
Can't wait to see how FAdmin turns out. :)
Re: URestrict
« Reply #545 on: March 21, 2010, 01:16:48 pm »
Well, that's good to know. :D
Offline superkyol
Re: URestrict
« Reply #546 on: March 21, 2010, 02:18:23 pm »
There has been a development.
In changing FPP to disable all tool-related goodies, I somehow disabled prop protection in toolguns, so people could use any tool on each others' props. So now I have to figure out how to disable the tool restrictions WITHOUT disabling prop protection. Yikes! I'll upload a zip with the fixed FPP if I manage to do so, to help anyone who uses DarkRP and ULX and has any conflict issues.
Are there any ULX/ULib mods that provide protection against people using tools on others' props?
« Last Edit: March 21, 2010, 02:47:47 pm by superkyol »
Re: URestrict
« Reply #547 on: March 21, 2010, 05:13:58 pm »
UPS
Re: URestrict
« Reply #548 on: April 22, 2010, 06:43:20 pm »
I realize I am bumping by like a month (Dunno if that applies in Releases)
Could someone please fix the fact that you can advance duplicate something that is restricted and spawn it in the advance duplicator.  It might work with regular advance duplicator also.
Also adding restrictions to certain ragdolls?  There are ragdolls I wish people not to be able to spawn but still can.
Re: URestrict
« Reply #549 on: April 22, 2010, 07:43:08 pm »
Could you please post the contents of you data/URestict  folder? The problems you are mentioning should not be possible.
Re: URestrict
« Reply #550 on: April 23, 2010, 01:27:19 pm »
"ragdoll"
"sent"
"respected2"
"jetpack"
"sent_sakariashelicopter"
"sent_spawnplatform"
"superadmin"
"barrel_sent_atomic_bomb"
"briefcase_sent_atomic_bomb"
"melon_sent_atomic_bomb"
"soda_sent_atomic_bomb"
"canister_sent_atomic_bomb"
"crate_sent_atomic_bomb"
"jetpack"
"admin"
"mk-82_sent_atomic_bomb"
"jetpack"
"user"
"jetpack"
"respected"
"jetpack"
"respected3"
"jetpack"
"temp-admin"
"jetpack"
"vehicle"
"npc"
"prop"
"respected3"
"models/props_phx/huge/evildisc_corp.mdl"
"models/Combine_dropship.mdl"
"models/props_bts/glados_generator.mdl"
"models/props_phx/misc/flakshell_big.mdl"
"models/props_c17/utilitypole01d.mdl"
"models/cranes/crane_frame.mdl"
"models/props_buildings/building_002a.mdl"
"models/props_buildings/collapsedbuilding02b.mdl"
"models/props_buildings/collapsedbuilding02c.mdl"
"models/props_buildings/project_building01.mdl"
"models/props_buildings/project_building02.mdl"
"models/props_buildings/project_building03.mdl"
"models/props_buildings/project_destroyedbuildings01.mdl"
"models/props_buildings/row_church_fullscale.mdl"
"models/props_buildings/row_corner_1_fullscale.mdl"
"models/props_buildings/row_res_1_fullscale.mdl"
"models/props_buildings/row_res_2_ascend_fullscale.mdl"
"models/props_buildings/row_res_2_fullscale.mdl"
"models/props_buildings/watertower_001a.mdl"
"models/props_buildings/watertower_002a.mdl"
"models/props_canal/canal_bridge01.mdl"
"models/props_canal/canal_bridge02.mdl"
"models/props_canal/canal_bridge03a.mdl"
"models/props_canal/canal_bridge03b.mdl"
"models/props_combine/combine_citadel001.mdl"
"models/props_combine/combineinnerwallcluster1024_001a.mdl"
"models/props_combine/combineinnerwallcluster1024_002a.mdl"
"models/props_combine/combineinnerwallcluster1024_003a.mdl"
"models/props_wasteland/rockcliff_cluster01b.mdl"
"models/props_wasteland/rockcliff_cluster02a.mdl"
"models/props_wasteland/rockcliff_cluster02b.mdl"
"models/props_wasteland/rockcliff_cluster02c.mdl"
"models/props/de_nuke/storagetank.mdl"
"models/props/de_train/biohazardtank.mdl"
"models/props_phx/huge/tower.mdl"
"models/props_phx/playfield.mdl"
"models/props_phx/torpedo.mdl"
"models/props_combine/prison01.mdl"
"models/props_combine/prison01b.mdl"
"models/props_combine/prison01c.mdl"
"models/props_combine/cell_array_01.mdl"
"models/props_combine/cell_array_01_extended.mdl"
"models/props_combine/cell_array_02.mdl"
"models/props_combine/cell_array_03.mdl"
"models/props_combine/cell_01_supports.mdl"
"models/props_combine/cell_01_supportsb.mdl"
"models/combine_strider_vsdog.mdl"
"models/Combine_Strider.mdl"
"models/Combine_dropship.mdl'"
"models/props_combine/combinewallcrushed.mdl"
"models/props_phx/amraam.mdl"
"models/props_phx/cannonball.mdl"
"models/props_phx/mk-82.mdl"
"models/props_phx/rocket1.mdl"
"models/XQM/jetbody3_s5.mdl"
"models/XQM/jetbody3_s4.mdl"
"models/props_phx/misc/big_ramp.mdl"
"models/hunter/blocks/cube8x8x8.mdl"
"models/hunter/blocks/cube6x6x6.mdl"
"models/hunter/blocks/cube8x8x4.mdl"
"models/hunter/blocks/cube4x6x4.mdl"
"models/hunter/plates/plate32x32.mdl"
"models/hunter/plates/plate24x32.mdl"
"models/hunter/plates/plate24x24.mdl"
"models/hunter/plates/plate16x32.mdl"
"models/hunter/plates/plate16x24.mdl"
"models/Advisorpod_crash/Advisor_Pod_crash.mdl"
"models/Cliffs/bridge.mdl"
"models/Cliffs/bridge02.mdl"
"models/Cliffs/cliff01.mdl"
"models/Cliffs/o5cliff01.mdl"
"models/Cliffs/o5cliff02.mdl"
"models/Cliffs/o5cliff03.mdl"
"models/Cliffs/o5cliff04.mdl"
"models/Cliffs/o5cliff05.mdl"
"models/Cliffs/rockcluster01.mdl"
"models/Cliffs/rockcluster02.mdl"
"models/Cliffs/rocks_large01.mdl"
"models/Cliffs/rocks_large01_veg.mdl"
"models/Cliffs/rocks_large02.mdl"
"models/Cliffs/rocks_large02_veg.mdl"
"models/Cliffs/rocks_large03.mdl"
"models/Cliffs/rocks_large03_veg.mdl"
"models/Cliffs/rocks_medium01_veg.mdl"
"models/Cliffs/rocks_medium02.mdl"
"models/Cliffs/rocks_medium02_veg.mdl"
"models/Cliffs/rocks_medium03.mdl"
"models/Cliffs/rocks_small01.mdl"
"models/Cliffs/rocks_small01_veg.mdl"
"models/Cliffs/rocks_small02.mdl"
"models/Cliffs/rocks_small02_veg.mdl"
"models/Cliffs/rocks_small03.mdl"
"models/Cliffs/rocks_small03_veg.mdl"
"models/Cliffs/rocks_xlarge01.mdl"
"models/Cliffs/rocks_xlarge01_veg.mdl"
"models/Cliffs/rocks_xlarge02.mdl"
"models/Cliffs/rocks_xlarge02_veg.mdl"
"models/Cliffs/rocks_xlarge03.mdl"
"models/Cliffs/rocks_xlarge03_veg.mdl"
"models/SmallBridge/Hulls,SW/sbhullcurvel.mdl"
"models/combine_dropship.mdl"
"models/props_granary/conveyer_belt4.mdl"
"models/combine_helicopter.mdl"
"respected2"
"user"
"respected"
"owner"
"user2"
"temp-admin"
But what I am trying to say, is if I were to spawn a atomic bomb (sent), one of my superadmins or admins could advance duplicate it then spawn it even though it is restricted.
Let me know if you want all the rest of my data files.
One more thing, it seems I am unable to restrict the MK-82 from PHX in any form (sent or prop).
Edit:  Are you talking about ragdolls or the advance duplicator?
With ragdolls I am just unable to use urestrict denyspawn ragdolls user "" ,  I'll check to make sure it is on owners commands.
« Last Edit: April 23, 2010, 01:37:07 pm by Aaron113 »
Re: URestrict
« Reply #551 on: April 23, 2010, 04:12:33 pm »
You get an error when trying to run the code below?
urestrict denyspawn ragdoll user ""
I ask because I just check my scripts and I actually never added ragdoll to the list of commands.
Also were you just using "" as an example or are you trying to block all ragdolls?
If you ware trying deny users from spawning ragdoll. Use this instead:
urestrict ragdolls users 0
Re: URestrict
« Reply #552 on: April 23, 2010, 08:20:21 pm »
I did the "" on purpose just to show the command.
And that still does not solve the advance duplicator problem.
Re: URestrict
« Reply #553 on: April 25, 2010, 02:51:02 pm »
Your problem with the advanced duplicator is elsewhere. You either have an error showing up somewhere, or a conflicting addon.
Re: URestrict
« Reply #554 on: April 29, 2010, 02:07:24 pm »
Could ASpam be messing with it?
