Poll
Yes, Much Better!
71 (59.7%)
Yeah
22 (18.5%)
14 (11.8%)
No
4 (3.4%)
I Prefer The Old GUI
8 (6.7%)
Total Members Voted: 1
Re: URestrict
« Reply #555 on: April 29, 2010, 05:31:55 pm »
Shouldn't be able too.
Re: URestrict
« Reply #556 on: April 30, 2010, 01:47:45 pm »
K and the latest update on Garrys mod screwed URestrict up, I don't know if just a fix of ulx and ULiB will fix this but here is error.
[ULIB] Loading SHARED module: urestrict.lua
ULib/modules/urestrict.lua:267: attempt to call field 'addCommand' (a nil value)
« Last Edit: April 30, 2010, 03:29:06 pm by Aaron113 »
Re: URestrict
« Reply #557 on: April 30, 2010, 02:05:13 pm »
K an the latest update on Garrys mod screwed URestrict up, I don't know if just a fix of ulx and ULiB will fix this but here is error.
You using ULib svn?
Re: URestrict
« Reply #558 on: April 30, 2010, 03:10:45 pm »
Yes, and I know ULX and ULiB has been fixed. (Or so I think it has)
EDIT:  I"m not sure if the fix has fixed URestrict, checking now.
EDIT:  Yes it is fixed, just one last bug with ULiB, but URestrict is working fine.
Also, did you ever fix the ragdoll problem?
« Last Edit: April 30, 2010, 03:25:08 pm by Aaron113 »
Offline ngc0202
Re: URestrict
« Reply #559 on: May 01, 2010, 07:48:30 am »
How can I restrict certain weapons with it?
Re: URestrict
« Reply #560 on: May 01, 2010, 08:00:51 am »
See first post.
Offline ngc0202
Re: URestrict
« Reply #561 on: May 01, 2010, 08:17:39 am »
See first post.
It says tool restrictions not weapon restrictons...
Re: URestrict
« Reply #562 on: May 01, 2010, 09:24:51 am »
Creating Loadouts
1: Type URestrict in the console
2: Open the loadouts tab
3: Click Add ( Middle Column )
4: Type in a name for your loadout ( Text box appears after clicking add )
Changing Group Loadouts
3: Select what group you want to modify ( Column on the far left )
4: Select what loadout you wan that group to use ( Column in the middle )
5: Click apply ( Middle Column 3rd button from the bottom )
Modifying Loadouts
3: Select what loadout you want to modify  ( Column in the middle )
4:   To Remove Items From The Loadouts
      1: Select what items you want to remove (Column on the right )
      2: Click modify ( Column on the right )
5:   To Add Items To The Loadouts
      1: Click modify ( Column on the right )
      2: Type in what you want to add ( Text box appears after clicking modify)
Really?
Re: URestrict
« Reply #563 on: May 02, 2010, 01:55:54 pm »
Ok I know what you were thinking of.  You were thinking of props.  (Duplicating issue)
I was talking about certain tools (What tools spawn).
It doesn't restrict them, and people can duplicate sents(if restricted)
Re: URestrict
« Reply #564 on: May 03, 2010, 06:39:34 am »
     - Oh ok, I see what you're talking about now. I will look into it further. But as far as the tools/weapons duplicating, they still can't pick them up/use them correct?
Re: URestrict
« Reply #565 on: May 03, 2010, 07:02:52 am »
Ok, I've made a big decision today to rebuild URestrict. So, to all of you, this means I am open to suggestions again.
Currently this is what's on my list:
URestrict Updates:
File update optimization
Server - Client optimization
Make it more modular
New Limits tab
More spawn control
Prepare for LuaJIT
Function optimization
Better documentation
Offline ngc0202
Re: URestrict
« Reply #566 on: May 03, 2010, 07:17:05 am »
URestrict Updates:
New Limits tab
More spawn control
Prepare for LuaJIT
Sugestion: Weapon restrictions added!
Re: URestrict
« Reply #567 on: May 03, 2010, 05:11:15 pm »
      - Already in there. Has been ever since v1
Offline Simple
Re: URestrict
« Reply #568 on: May 04, 2010, 06:25:38 am »
If possible could you make it work for gamemodes such as DarkRP.
Re: URestrict
« Reply #569 on: May 04, 2010, 01:46:54 pm »
Just a couple suggestions
Kind of a extension to above question :  Could you make it have certain restrictions for certain gamemodes.  Say I have weapons restricted on sandbox and we switch to some deathmatch gamemode, we would have to re-apply all the restrictions to fit with teams so it doesn't block a weapon they are suppose to have.
Will just prevent some problems.
Could you add a prop restriction menu in the menu so we don't have to look in data files to see who is allowed to spawn what.
I can't really think of anything else off hand but will let you know if I can think of anything.
