Author Topic: UTeam working on Spacebuild2?  (Read 5909 times)
Offline johnlukeg
« on: December 13, 2008, 04:55:16 pm »
I swear I searched, but since the uteam file has SpaceBuild written in it by default, it wasn't much use.
Anyway, I was wondering if it's possible for UTeam to work on SB2, or if perhaps mine is bugged.  In the scoreboard (SUI Scoreboard modified v2) it displays everyone as unassigned, and nobody has their proper amount of health or armor.
It worked perfectly on Sandbox on the same server with the same files, just not in spacebuild.  I assumed it would work since Spacebuild is a default gamemode in the uteam text setup.
Any thoughts?
Re: UTeam working on Spacebuild2?
« Reply #1 on: December 13, 2008, 07:11:55 pm »
The name of SB2 changed, forget what it's called these days
Offline johnlukeg
« Reply #2 on: December 13, 2008, 07:27:00 pm »
Hmm, well in UTeam, it lists it as SpaceBuild, and that is what I have down for my server's default gamemode and it knows exactly which gamemode I'm talking about.  Are you sure?
Also if you are indeed right, does anyone know what I should put for its name in Uteam?
« Reply #3 on: December 13, 2008, 08:36:14 pm »
The name of the Spacebuild gamemode has changed several times since UTeam example text was released.
This post (and a few above it) in the actual UTeam thread show a user having similar issues. They ended up going to the SB devs for help. I don't know how they contacted them.
Offline johnlukeg
« Reply #4 on: December 14, 2008, 12:03:36 am »
Alright, thanks for the help, I got it.
