« Reply #240 on: June 19, 2010, 02:56:40 pm »
Well, if you don't know what sv_downloadurl is, then you probably aren't using it :P
Hmm.. are you on Steam right now? I'd rather try and work this out via chat rather than these forums. Add me via email <redacted>
« Last Edit: July 27, 2011, 04:25:26 pm by Stickly Man! »
Offline Prizim
« Reply #241 on: June 19, 2010, 05:59:24 pm »
Hello. I downloaded xgui and put it on my server on the 11th, and it worked just fine, until I noticed that ulx no longer logs to ulx_logs. Or at all. Anywhere. I've tried configuring the files directly, I've tried checking and unchecking all the stuff in xgui relating to the logs, changing everything, and it still refuses to log. So, I made a logical decision, and removed xgui. Still, no longer logs, at all, and all my gimps are gone. I don't know what to do. I've tried everything, and I've been forced to use darkrp logs, which are completely useless. I even installed the new xgui to see if it would help (it doesn't.) I uninstalled THAT, nothing. Please help.
« Reply #242 on: June 19, 2010, 06:12:46 pm »
Hmm, logs are working fine for me, perhaps you should post your concern in this thread: /index.php/topic,4611.html (I hear some other people have been similar issues). If anything, you should post any addons you have, especially ULX-related addons.
As for the gimps, I have no idea what happened. Check and see if garrysmod\data\ulx\gimps.txt exists.
It sounds like there are some strange bugs probably coming from a conflicting mod somewhere.
Offline Prizim
« Reply #243 on: June 19, 2010, 06:25:59 pm »
Gimps.txt exists, it's just empty all of a sudden. As for related addons, I haven't added anything after xgui, and the only ulx mods I have are !rocket, !resize, and !explode. I'm sorry if I sound whiny. I love your addon, despite all that has happened (if there's any relation), but I'm being accosted by my users, reporting spammers whose steamids I can't find, and who I can't verify either, so I'm a bit strung out.
EDIT: I'll go post in that thread now, by the way.
« Reply #244 on: June 19, 2010, 06:38:31 pm »
Is gimps.txt empty as in completely blank? Or does it also have the comment at the very top? ULX doesn't have built-in support for gimp editing, so it just reads the file, whereas XGUI saves it. But if it were XGUI's fault, I wouldn't know where to begin to find out what exactly happened  :(
I'll go check out those other addons and see if I can find anything.
Offline Tommo1590
« Reply #245 on: June 19, 2010, 07:52:48 pm »
Hey,
This GUI is looking great and i love it however i have got 2 probs.... the Groups and Maps tabs arent loadin any information they both stay blank like the server has no maps and no groups...
Please help :(
Thanks Tommo!
Offline Prizim
« Reply #246 on: June 19, 2010, 08:06:18 pm »
It's completely blank. The one in data/, that is. The one in addons/ulx/data/ulx/ is as I left it. However, ULX no longer reads from this file. All the ones I added under xgui are gone. I'm also seeing no maps in xgui, similar to Tommo's problem, although I THINK (not sure) that the groups remain the same.
Offline Tommo1590
« Reply #247 on: June 19, 2010, 08:08:40 pm »
My groups page is empty just like the maps page  :'(
Edit/Update : Just added URestrict to my server and it also is having the same problem, its not showing any tools or groups... just saying in case it helps fix what ever is wrong... will try get a print screen now.
Image: (Yes i no its URestrict but they both having same problem)....
« Last Edit: June 19, 2010, 08:34:40 pm by Tommo1590 »
« Reply #248 on: June 19, 2010, 09:02:55 pm »
Hmm, sounds like a write bug, but.. I'm not exactly sure how it happened. However, If you delete the gimps.txt in the data/ folder, it will regenerate itself.
Not sure exactly what's causing that.. Have you tried clicking the "Refresh XGUI/Server Data" button in the XGUI settings tab?
As for the maps not showing up, it may be a problem with how you have player votemaps set up. I'm modifying the code to handle it better (As it was never full implemented in the first place)
Offline Tommo1590
« Reply #249 on: June 19, 2010, 09:45:55 pm »
Yes i have didn't change anything... still not show the groups or maps...
I havent touched the vote maps yet, its all the ULX default so thats not the problems :S
Tom
« Reply #250 on: June 19, 2010, 10:01:39 pm »
Tommo, Give me a day or two to modify the maps code, I should hopefully have it working after that.
As for the groups not showing up.. try running this in your CLIENT console, and tell me if anything shows up:
lua_run_cl PrintTable( xgui.data.users )
Then run the following on your SERVER console:
lua_run PrintTable( ULib.ucl.users )
The two tables outputted should be exactly the same.
If the client table is blank, but the server table shows stuff, then try running this command in your server console and post the output here:
lua_run print( xgui )
Offline Tommo1590
« Reply #251 on: June 20, 2010, 05:16:11 am »
im getting a error when running these saying:
Unknown command: lue_run_cl
And...
« Reply #252 on: June 20, 2010, 07:39:44 am »
It's luA not luE
Offline Tommo1590
« Reply #253 on: June 20, 2010, 07:44:17 am »
My bad was trying do it on a huge screen couldnt see it right letters to small lol now i feel dumb  :o
Offline Tommo1590
« Reply #254 on: June 20, 2010, 07:52:47 am »
Came back Blank...
Then i ran this in the server console:
I got this back :
Results:
> print( xgui )...
table: 034FB158
