« Reply #270 on: June 26, 2010, 02:29:10 pm »
I still do, haven't found out what happened just yet.
« Reply #271 on: June 26, 2010, 02:43:02 pm »
OK I sent you my adverts.txt
« Reply #272 on: June 26, 2010, 03:05:44 pm »
Hmm, turns out something funky is goin on when ULX parses the adverts.txt file. Basically, on your entry that includes your steamcommunity URL:
"Steam group located @ http://steamcommunity.com/groups/<url>" "60"--It seems to not like the forward slashes.
I'll inform Megiddo and he can probably get it fixed really soon.
« Reply #273 on: June 26, 2010, 04:15:54 pm »
ok
« Reply #274 on: June 26, 2010, 09:44:49 pm »
We've had problems using forward slashes in adverts for a looong time and I'm not sure there was ever a good way to 'fix' it.
Gmod sees // as comments. Again, it's Garry's way of adding comments. True lua = "--"
At the time, I think string.find and other string.replace commands would actually ignore the // because the engine saw it first and thought it was a comment.
It's possible that may have changed now.
I'd have to search 2 or 3 years back, but a discussion here on the forums with someone reporting the same adverts issue ended up being 'don't use //, use "Visit site www.blah.com/pagename.blah" '
EDIT - Found this. /index.php/topic,1260.0.html#msg5994 />No evidence in that post that we tried fixing it, but I seem to remember discussing it with Megiddo in Steam IM.
Again, it's possible we could find a work around now.
« Last Edit: June 26, 2010, 09:53:05 pm by JamminR »
« Reply #275 on: June 27, 2010, 10:59:52 pm »
The "Allowed Maps" in the "Player Votemap List" doesn't save so votemap gets reset every start up and gets overwritten.
Offline maaarten
« Reply #276 on: June 28, 2010, 06:32:55 am »
It doesn't work on my server :(
When i start my server it says this:
addons\xgui\lua\ulx\modules\xgui_server.lua:42: attempt to call field 'replicate
dWritableCvar' (a nil value)
« Last Edit: June 28, 2010, 07:11:10 am by maaarten »
« Reply #277 on: June 28, 2010, 07:36:13 am »
Svn of ulib and ulx is required. You should throw the svn link of xgui up, Stickly.
« Reply #278 on: June 28, 2010, 08:16:46 am »
@Aaron: Hmm, can't really test right now (at work), but as I recall it was working fine for me. Try moving/deleting/renaming your current votemaps.txt file and see if XGUI then saves it.
@maaarten: Like Megiddo said, make sure you're using the SVN ULib/ULX-- If you already are, then make sure you update it!  ;)
Offline maaarten
« Reply #279 on: June 29, 2010, 03:41:45 am »
When i use the svn versions of ulib and ulx i get these errors in the server  console.
//  shared/datastream.lua    //
//  server/upgrade.lua       //
ERROR: ULib upgrade Failed: addons\ulib\lua\ulib\server\upgrade.lua:12: attempt
to index a nil value
//  shared/hook.lua          //
ULIB PANIC: default groups.txt is corrupt!
Groups file was not formatted correctly. Attempting to fix and backing up origin
al
Error while reading groups file was: Bad input on line 1
Original file was backed up to ULib//groups_backup.txt
addons\ulib\lua\ulib\server\ucl.lua:19: bad argument #1 to 'pairs' (table expect
ed, got nil)
//  sh_base.lua              //
addons\ulib\lua\ulib\shared\commands.lua:1167: attempt to call field 'registerAc
cess' (a nil value)
addons\ulx\lua\ulx\base.lua:24: attempt to call field 'registerAccess' (a nil va
lue)
lue)
//  MODULE: uteam.lua        //
lue)
cess' (a nil value)
cess' (a nil value)
cess' (a nil value)
cess' (a nil value)
cess' (a nil value)
addons\ulx\lua\ulx\modules\sh\user.lua:33: bad argument #1 to 'pairs' (table exp
ected, got nil)
cess' (a nil value)
lue)
« Reply #280 on: June 29, 2010, 04:52:52 am »
Looks like your groups.txt file is corrupt... I should make it not fail so hard in that case, though. :)
Offline maaarten
« Reply #281 on: June 29, 2010, 05:42:13 am »
When i replace the groups.txt file with a older version it also doesn't work. I also deleted the groups.txt and let ulib make a new onem, doesn't work either.
i'm out if ideas
« Reply #282 on: June 29, 2010, 05:47:00 am »
i'm out if ideas
Did you change the default groups.txt?
« Reply #283 on: June 29, 2010, 08:22:15 am »
Also, to anyone who uses the PlayX addon, the author has just released an update that fixes an issue with XGUI (After any video started playing, clicking on the tabs would do nothing). So if you use PlayX, be sure to update!
Offline maaarten
« Reply #284 on: June 29, 2010, 08:52:37 am »
no, its says in the file not to edit the default groups.txt
