« Reply #375 on: August 30, 2010, 03:32:52 pm »
Odd, but they'll probably get that fixed pretty quick.
« Reply #376 on: August 30, 2010, 05:04:15 pm »
Also, where did you get the skins?  I downloaded a few but they seemed not to work.
« Reply #377 on: August 30, 2010, 06:27:29 pm »
Can you link the ones that aren't working?
« Reply #378 on: August 30, 2010, 06:35:47 pm »
I just download random ones via gmod.org-- I'm not real knowledgeable on the status of derma skins in gmod.
Did you put them in the right spot? I ended up sticking mine in the garrysmod/lua/skins/ folder.
« Reply #380 on: August 30, 2010, 07:28:11 pm »
I did end up getting them to work after reading that post a second time.  The Skins come in a derma folder and they don't tell you that you don't need to extract the derma folder.  Unless that derma folder was for a older version of gmod.
EDIT:  You also need to have it update the groups after removing a player from a group.
« Last Edit: August 30, 2010, 07:32:58 pm by Aaron113 »
Offline aolko
« Reply #381 on: September 03, 2010, 09:28:51 am »
how to setup this?
« Reply #382 on: September 03, 2010, 01:27:36 pm »
Place directly into addons.  If your using SVN it is a little bit different, you have to create a folder called XGUI then place in addons.
Offline aolko
« Reply #383 on: September 04, 2010, 09:43:43 am »
not working
writes error like tried to use nill etc.
« Reply #384 on: September 04, 2010, 12:32:38 pm »
Do you have the SVN revisions of ULX and ULib?
Offline Fleamonji
« Reply #385 on: September 04, 2010, 02:27:02 pm »
I get the following errors when joining a server in the console.  I also have this annoying "loading" box stuck above the UI on the latest revision - "waiting for clientside processing".
Hook 'XGUIQueueThink' Failed: ulx\modules\cl\xgui_client.lua:435: attempt to call field 'isInHook' (a nil value)
When I click a dropdown:
Hook 'ULibQueueThink' Failed: ulib\shared\util.lua:180: attempt to call field 'isInHook' (a nil value)
ULX, ULib, XGUI latest revisions.
EDIT:  Also won't load any bans up.  This is a fresh server.
« Last Edit: September 04, 2010, 04:39:00 pm by Fleamonji »
« Reply #386 on: September 05, 2010, 06:40:02 pm »
What other mods are you running? Sounds like either ULib isn't the SVN version on your server or you have a conflicting addon.
Offline riki137
  • lol wuttermelon
    • SapphireWebsites
« Reply #387 on: September 06, 2010, 03:37:12 pm »
Does this replace UTeam? Because i had problems (diferrent colors) in svn chat command reporting. Removed UTeam.txt and now works everything fine. So does it replace uteam?
« Reply #388 on: September 06, 2010, 03:50:11 pm »
riki, no (and yes). ULib now incorporates UTeam into it. XGUI just modifies ULib (and ulx) settings.
See the SVN stuff forum area where Megiddo made the post regarding incorporating UTeam.
Offline Fleamonji
« Reply #389 on: September 06, 2010, 05:04:33 pm »
Running ASSMod, Wire, PHX3, and some STools like Stacker and Unbreakable.
