Author Topic: ulib/ulx -> php/asp  (Read 7031 times)
Offline odyss3y
ulib/ulx -> php/asp
« on: November 06, 2009, 03:33:35 pm »
I'm looking to display data about who are ULX admins and what groups they are in.  Has anyone done anything like this in php or asp?
Also, how is UID calculated?  Currently I'm using ulib, ULX, utime, and darkrp.  What I'm hoping to do is display the people's wallets based on the last time they were logged on.  I can do this if I know how to convert a steamid into a UID.
Re: ulib/ulx -> php/asp
« Reply #1 on: November 06, 2009, 05:21:08 pm »
I'd integrate it the other way if I were you. Start out with a website that has the ability to do what you want from a database, then share that information with ULib as needed. See the docs for information on how to do that.
« Reply #2 on: November 06, 2009, 06:52:48 pm »
odyss3y,
See also this post - /index.php/topic,3241.0.html
It's a discussion of how someone wanted to use ULib to pull groups/users from a database instead of our flat text file.
It also has example code we once used to pull admins/donator access from the forum database here when we ran a gmod server.
Offline Ploo
« Reply #3 on: February 24, 2010, 03:16:43 pm »
Your best bet would be to convert the entire data system (users.txt, bans.txt, groups.txt and the rest) to MySQL. I think ACProdigy has done just that.
