Yeah, I am a bit far behind
And with my new job starting Tuesday, My free time is getting sparse. I do like this newfound motivation though!
What do I need help with, what do I need help with.. Ooh! Megiddo, perhaps you could continue going over the parameters in the players menu, getting those all .. player/group/global restrictions checked! You've seen where the code is in players.lua, it's all basically in the same spot, lemme know if you need help finding anything.
EDIT: Actually, perhaps you could also help with the saving of adverts and gimps and other things you kept bugging me about, too
Secondly, JamminR, keep it up with the ideas and suggestions! Let us know when we add something new if it's good or bad, or possibly layout changes. Here's a couple of starting points:
1- Look at the right side of the maps tab, is there anything you can think of that we can put there? Should I move some of the elements around to better manage the space?
2- Where can I add something that states "XGUI for ULX"? I was thinking of making a 50% transparent colored "toolbar" type thing at the very bottom (that's centered and takes up about 90% of XGUI's width, and is about 20-25 pixels high)-- That would say XGUI, promote ULX, maybe show the server name, and the time? (Maybe show author of the current module?)
3- Players tab- I don't like the separate columns for commands and command arguments. I've been thinking of doing something like seen
here in Overv's Evolve.4- Same players tab, Since the arguments are generated from ULX's commands, I feel the layout of the arguments and the button to run command thing looks a bit crude. Any ideas there?
(Okay, I could probably go on for a while, but, since my mind is drawing a blank, I'm going to stop thinking about it)
As for the final polished XGUI-- It depends. I would like to have XGUI 100% complete for release mainly because of the sparseness of ULX's actual release schedule (like.. once a year?) I figure we can probably release another 'Release' version later, but.. That's more work for you guys. Other than that, Without sitting here and thinking about how much work there is to do, I can't really say how long it might take me to finish, so, I best be back to work
. Let me know what you guys think!
