Author Topic: Configuration  (Read 9226 times)
Configuration
« on: June 08, 2010, 03:06:57 pm »
What file are we suppose to edit?  I edited the on in the ULX/data/ulx/cfg.txt and the changes seem not to be taking place.
Re: Configuration
« Reply #1 on: June 08, 2010, 03:59:23 pm »
Don't edit the actual addons ULX folders.
Any editing of those in addons/ulx/data should be copied to gmod root/data/ulx/config.txt (or adverts/gimps/votemaps whatever)
Re: Configuration
« Reply #2 on: June 08, 2010, 04:08:34 pm »
You may want to mention that in the files....
Re: Configuration
« Reply #3 on: June 08, 2010, 04:36:12 pm »
So few read them, but ok.
Rev 108 - Done
Re: Configuration
« Reply #4 on: June 08, 2010, 05:32:08 pm »
Rev 108 - Done
The "DO NOT EDIT THIS FILE" will appear in the actual data files too, JamminR. You might want to reword that... I've been trying to come up with something but failed. :P
Re: Configuration
« Reply #5 on: June 08, 2010, 06:32:25 pm »
Then why didn't you say so.
Oh. Wait. You just did. :)
Working...
Re: Configuration
« Reply #6 on: June 08, 2010, 07:06:00 pm »
Rev 190 - top of every config file
;ATTENTION! /ADDONS/ulx/data/ulx/<this file> is a DEFAULT file. DO NOT EDIT THE /ADDONS/ULX/DATA/ULX FOLDER FILE!!!
; Instead, edit the version in <garrysmod root>/data/ulx/ if it exists. If it doesn't, copy this file to <gmod root>/data/ulx/ to create it.
It seems so few ever read the files or know about them, but perhaps people will see it.
Thanks for reminding us Aaron. we've had similar warning in the Ulib addons/ulib/data/Ulib groups and users files for a long time.
« Last Edit: June 08, 2010, 07:08:17 pm by JamminR »
Re: Configuration
« Reply #7 on: June 09, 2010, 04:06:34 pm »
Split new topic here: /index.php/topic,4757.0.html
