Author Topic: ULX exploit and/or bug.  (Read 64487 times)
Offline NaRyan
Re: ULX exploit and/or bug.
« Reply #30 on: March 07, 2011, 06:00:03 am »
Got it installed on my 3 servers now.
Only "used" it on my TTT server and I do have one little problem.
On map change I have to re-connect for ULX to work for me.
If I try to use any ULX commands or change any settings it does not do the commands or change settings.
However if I re-connect then it works fine.
« Reply #31 on: March 07, 2011, 09:48:49 am »
NaRyan, even though it works fine for me I had forgotten about the really annoying bug of utter mystery, sorry about that. I'll be switching over the data transmission to another method shortly, so let me know if it fixes it for you.
Edit: Changed in ULib rev 185. Be sure to let me know if this fixes it for you NaRyan, as I have never been able to replicate this problem on my test server.
« Last Edit: March 07, 2011, 09:55:40 am by Megiddo »
Offline NaRyan
« Reply #32 on: March 07, 2011, 10:56:36 am »
Ahh cool thanks :)
I'll let you know how it goes once I get a chance to update my servers....
*edit*
I tested it on my sandbox server, and after changing map I was still able to change settings and use Admin commands.
« Last Edit: March 07, 2011, 11:37:42 am by NaRyan »
« Reply #33 on: March 07, 2011, 02:46:49 pm »
CURSE YOU!
You're sadly awesome
Most interesting complement I've heard in a while.
Kudos!
We hope the changes made help in overall anti-exploitation, but, as this is a Source issue..those abusing it may know other ways around using ULX.
Offline krooks
  • I don't like video games.
    • Diamond Krooks
« Reply #34 on: March 07, 2011, 04:51:00 pm »
Ok so people on the FP thread are suggesting that we disable rcon, I'd rather not ask there how to go about doing that (for obvious reasons), anyone here know how to completely disable rcon?
My TTT server. Join the fun!
Offline Pantho
« Reply #35 on: March 07, 2011, 04:59:13 pm »
Many ways, disable the port, set it to no password.
Not really sure why you would disable Rcon, I mean long as your not silly enough to set it inside a config and use command line.
I don't think there are many exploits that directly get rcon like there suggesting. Just make your rcon something long and obscure ;) I normally go for #randomwords@841235#smells@ etc ;)
Offline krooks
    • Diamond Krooks
« Reply #36 on: March 07, 2011, 05:25:02 pm »
ah ok, thanks for the information, I'll just go TheL0ngPassw0rdR0ut@!  :P
also by not setting in a config, do you mean not to have it in server.cfg? Then where should it go?
I don't and have never used rcon, so I'm very nooby about it.
« Reply #37 on: March 07, 2011, 06:12:09 pm »
If you're going to enable it (by setting a password instead of rcon_password "" (which disables it)), you use a command line option in server startup.
I forget if you use a plus (+rcon_password) or minus (-rcon_password), but many Source exploits ago, it was recommended the command line option be used.
Offline krooks
    • Diamond Krooks
« Reply #38 on: March 07, 2011, 07:19:16 pm »
ah ha, thanks again guys!
« Reply #39 on: March 07, 2011, 07:39:04 pm »
It's +rcon_password
Offline NaRyan
« Reply #40 on: March 08, 2011, 01:50:09 am »
I updated Ulib on my 3 servers, and ULX commands now work fine after gamemode\map change :)
« Reply #41 on: March 08, 2011, 07:14:17 am »
Thanks, NaRyan!
Offline Pantho
« Reply #42 on: March 09, 2011, 12:09:49 pm »
Not as long as you think.
The exploit got a refresh recently, still private. Might be patched again I've no idea.
But, here was a new download exploit around 1 month ago.
Offline krooks
    • Diamond Krooks
« Reply #43 on: March 09, 2011, 05:07:18 pm »
Ugh, not another download exploit..
Now that I look at it, I still have my sv_allowupload/download settings at 0, from the last time :P
Offline ceribik
« Reply #44 on: March 20, 2011, 04:45:16 am »
There appears to be some variation of this exploit floating about... similiar things are happening again
admin timesout --> admin rejoins --> ulx command is spoofed
I'm not entirely sure how this is working now that the server + client share a secret key, but i want to emphasise that this occurs when the admin rejoins and not while the admin is dc/d (like in the original variation of this exploit).
