« Reply #195 on: January 03, 2012, 07:06:32 pm »
By the way... I'll probably rewrite this completely and not make it dependent on ULX/ULib for Gmod 13.
Awww... ULib's there to make your life easier, though. :(
Offline Oblivi0us
« Reply #196 on: January 04, 2012, 08:05:09 am »
You don't happen to have a link to the download or the lua file that does it, do you?
http://www.garrysmod.org/downloads/?a=view&id=58183
« Reply #197 on: January 16, 2012, 03:35:49 pm »
I have started rewriting URS.  I plan to be completely independent with this update, no longer depending on ULib or ULX (:().  I intend to make it compatible with most popular mods and even work without one.  So far I haven't got much done past loading URS.  I am going to make a new, easier to use gui.  I don't like the way I have the current one set up.
« Reply #198 on: January 16, 2012, 07:37:18 pm »
Ah, dependency removal perhaps, but, let it still detect, and use extra functionality if the end user does have ULib, right?
Autocomplete, access restrictions, etc, all can be done without yes, but so much easier with :).
« Reply #199 on: January 17, 2012, 08:19:33 am »
Yeah, it will use it if the server has it installed.
Offline powerdpower
« Reply #200 on: February 28, 2012, 07:34:42 pm »
Ummmmm, I cannot restrict some tools for some reason.
I was trying it with Weld tool, worked. I tryed it with Explosive Entities, worked. Tryed it with Laser 2.0, did not work, tryed it with No Collide world, did not work
And for Explosive Entities I had to put in explosive_entities.....
HELP PLEASE!
Offline wishbone
« Reply #201 on: February 29, 2012, 02:52:07 pm »
HELP PLEASE!
If there;s any lua errors when you try to restrict a tool post them. Also, more info could be good.
Offline powerdpower
« Reply #202 on: February 29, 2012, 08:08:01 pm »
Wait, I fixed my problem nevermind............
Offline Digital Spit
« Reply #203 on: March 15, 2012, 12:44:19 pm »
I use this on my server, I have to say, quite the excellent restriction tool, only problem is I don't know how to restrict tools, so I just use FPP
Offline Mathew75
« Reply #204 on: March 21, 2012, 07:55:25 pm »
How do I like restrict a certain tool ? I can't figure it out.
« Reply #205 on: March 22, 2012, 02:39:04 pm »
See http://aaron113.com/urs.php
It gives some examples all around.
Offline Mathew75
« Reply #206 on: March 22, 2012, 06:36:10 pm »
Just so I got the idea I got it down, for example I wanna restrict stacker.
would I do
ulx restrict tool stacker admin
« Reply #207 on: March 22, 2012, 07:33:10 pm »
I believe the actual name is "ol_stacker".  But yes, you have it correct.
Offline Mathew75
« Reply #208 on: March 23, 2012, 11:18:28 am »
is there anyway I can find the full tool name?
Offline ThatBum
« Reply #209 on: March 23, 2012, 12:35:11 pm »
Look at where the tool in installed in /addons. It should be in /lua/weapons/gmod_tool/stools.
