Offline nexbr
« Reply #255 on: November 28, 2012, 04:16:47 pm »
I fixed the checkbox problem by replacing with a textbox when are not on loadout part, but now seems the weapon restrictions are not working, i restrict a weapon, then changed to User and retry but yet i was able to spawn the weapon i don't know how fix this, The Addon Creator need fix this because i don't know what is wrong are not showing any errors log.
« Last Edit: November 30, 2012, 07:12:18 pm by nexbr »
Offline Tristian Wood
« Reply #256 on: November 29, 2012, 09:40:45 pm »
Aaron, are you going to put the Official Version on SVN? Also you should work together with nexbr, he has done some nice work with his patch.
Owner of soul gaming
Offline bungletrpg
« Reply #257 on: December 01, 2012, 08:30:14 pm »
I get this when I try to set a prop limit:
Lua Error: [ERROR] addons/urs/lua/ulx/modules/sh/urs_cmds.lua:103: attempt to index a nil value
1. call - addons/urs/lua/ulx/modules/sh/urs_cmds.lua:103
2. __fn - addons/ulib/lua/ulib/shared/commands.lua:943
3. unknown - addons/ulib/lua/ulib/shared/commands.lua:1296
4. Run - lua/includes/modules/concommand.lua:69
5. unknown - addons/ulib/lua/ulib/shared/commands.lua:1310
6. unknown - lua/includes/modules/concommand.lua:69
« Reply #258 on: December 03, 2012, 06:08:29 pm »
I'll check out his version and possibly upload it.  I don't think I'm going to have time to work on it.
« Reply #259 on: December 06, 2012, 01:45:01 pm »
I should be able to work some time in to test it this weekend and upload one of the fixes given.  I might even be able to get it in tonight, but unsure.
« Reply #260 on: December 06, 2012, 08:26:09 pm »
That is great news :D
« Reply #261 on: December 07, 2012, 08:24:48 pm »
I'm so beyond thrilled to see you continuing with this project!
I really enjoyed building URestrict as I'm sure you are enjoying URS. ( No pun intended )
Maybe one day I'll be able to contribute to the community again.
« Reply #262 on: December 09, 2012, 09:24:44 am »
http://steamcommunity.com/sharedfiles/filedetails/?id=112423325
That is a mostly working version.  As far as I can tell, everything works except the gui.  The gui needs to be recoded.  You can still use the gui, but it will be limited on what you can do with it.
NOTE:  You may have to delete your data files if you used someone else's fixed version or haven't used it since GM12.
Offline pandaman09
« Reply #263 on: December 13, 2012, 01:07:29 pm »
I am not sure if i am just an idiot or what, but it seems to not be loading at all. This is supposed to go into the "addons" folder of gmod correct?
« Reply #264 on: December 13, 2012, 07:43:30 pm »
You're downloading the workshop addon, right?  Not the SVN.  The SVN is outdated.  I should update the OP.
Offline Milk_
« Reply #265 on: December 16, 2012, 07:20:45 am »
Do you still have a copy of the command list?
« Reply #266 on: December 16, 2012, 08:16:54 am »
Read the OP.
Offline Milk_
« Reply #267 on: December 17, 2012, 04:04:07 am »
I did,
Want additional command help?  Visit this:  http://aaron113.com/index.php?a=urs
url is dead.
« Reply #268 on: December 18, 2012, 07:53:36 pm »
Look just a couple lines farther down!  :-\
Offline mikey
« Reply #269 on: December 29, 2012, 10:23:15 pm »
I can't seem to get setlimit to work.
ulx setlimit prop superadmin 500, admins are still restricted to the normal sbox_maxprops 30
