Offline uacnix
« Reply #435 on: February 09, 2015, 06:21:50 am »
Hello, I'm trying to figure something out with the loadouts- how can I set up a loadout to give e.g. 5 grenades?
I tried some combinations, like 5,"weapon_frag" but it didn't increase the amount of nades I get.
Is there any option to change the amount of "stuff" given?
Offline xLiaMz
« Reply #436 on: February 10, 2015, 02:44:48 pm »
Because people like to use tools on gamemodes I get this mad spam, that goes on for thousands of lines:
[TWK] ZeroX_Pro<STEAM_0:0:36245207> spawned model models/items/car_battery01.mdl
theprestigingace<STEAM_0:0:120908102> used the tool keypad_willox on models/props_lab/keypad.mdl
theprestigingace<STEAM_0:0:120908102> used the tool keypad_willox on maps/rp_downtown_v4c_v2.bsp
[TWK] ZeroX_Pro<STEAM_0:0:36245207> spawned model models/items/grenadeammo.mdl
[TWK] ZeroX_Pro<STEAM_0:0:36245207> spawned model models/items/crossbowrounds.mdl
[TWK] ZeroX_Pro<STEAM_0:0:36245207> spawned model models/items/ammocrate_rockets.mdl
[TWK] ZeroX_Pro<STEAM_0:0:36245207> spawned model models/items/ammocrate_ar2.mdl
How do i disable it? Please help :S
Offline uacnix
« Reply #437 on: February 12, 2015, 10:56:45 am »
I guess you'll want to restrict keypad_willox for some groups:
Offline xLiaMz
« Reply #438 on: February 12, 2015, 03:32:06 pm »
I don't want to just restrict that, It tells me every tool that is being used in the console... is there anyway to disable that?
Offline Bryantdl7
« Reply #439 on: February 20, 2015, 05:37:23 am »
that is a ulx setting. Not Urs
Offline Bryantdl7
« Reply #440 on: February 20, 2015, 05:39:33 am »
I'm having a problem,
I set up my new server got the newest version of ULX which is working fine, I installed URS the same way I installed ULX, into the addon folder but for some reason it won't show up in the settings tab of ULX.
When I type "rcon xgui_urs" it tells me:
Invalid command entered. If you need help, please type "ulx help" in your console.
The server log shows that URS has be successfully mounted:
Adding Filesystem Addon '/garrysmod/addons/urs-master'
So I don't understand why it is not working,
I've already set up a few servers where it worked perfectly fine.
inside the folder urs-master there should be an add on folder. That is all you need
Offline Flinta
« Reply #441 on: February 23, 2015, 08:19:07 am »
Lovely addon! but is there a way to set time limit on prop spawning and time limit on adv dupe so people cant spam it?
Offline uacnix
« Reply #442 on: February 27, 2015, 08:44:38 am »
Hello, I have an issue I cannot figure out by myself- I want to give some groups more items of the same type.
For example, i want to give the Superadmin group 30 combine balls (item_ammo_ar2_altfire).
What should I type in the ulx loadoutadd?
Offline Lnicholls2000|NewGmodServer!
« Reply #443 on: February 27, 2015, 08:56:25 am »
Great plugin, but people can still spawn restricted items with advanced duplicator. Anyone know how to solve the problem?
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
« Reply #444 on: February 27, 2015, 12:03:50 pm »
According to /index.php/topic,5269.0.html that is not possible, because I'm going to assume URS just does ply:StripWeapons(), then some for loop that does ply:Give("WERAPONNAMES"), then it selects the first weapon in the table.
You'd have to make another script that spawns the selected usergroup with that amount of ammo for the ar2, I'm not familiar with the ar2 weapon, so I can not assist, as I do not like engine based weapons.
« Last Edit: February 27, 2015, 12:06:48 pm by Bite That Apple »
Offline nex86
« Reply #445 on: March 08, 2015, 12:52:39 pm »
How do I restrict tools that have a space in the name?
like "eye poser" or "face poser" ?
everything else like remover or dynamite work fine.
Offline nex86
« Reply #446 on: March 09, 2015, 05:35:13 pm »
is there an easier way to edit the restrictions.txt and limits.txt file manually?
the format being everything in one line makes it almost impossible to edit it.
and converting it to Windows/unix format with notepad++ doesn't change anything.
Our server is running on Linux btw.
« Reply #447 on: March 09, 2015, 06:29:26 pm »
What do you need to do to it?  If it doesn't work with linux now, changing the format manually will only be a temporary solution.
I was planning on fixing a few things up over the week, but I have been having computer problems.
« Reply #448 on: March 09, 2015, 06:54:48 pm »
Those are not the actual names of the tools.  If you use the tool, it should print in your console the actual name.  It shouldn't have a space, but if it does, quotes should work.
« Reply #449 on: March 09, 2015, 07:55:42 pm »
*blink*
Wow. Hi Aaron.
Guess it takes Facepunch breaking our stuff for you to come visit, eh?
:P
Good to see you, no matter the reason. :D
