Author Topic: APromote GUI  (Read 66601 times)
Offline Wully616
    • WullysGamers
Re: APromote GUI
« Reply #15 on: November 12, 2012, 01:13:36 pm »
Does anyone have a fixed version of this? When using it in my server I get the following lua error:
[ERROR] addons/autopromotegui/lua/ulx/xgui/settings/cl_apromote.lua:19: attempt to call field 'makepanellist' (a nil value)
  1. unknown - addons/autopromotegui/lua/ulx/xgui/settings/cl_apromote.lua:19
   2. include - [C]:-1
    3. fn - addons/ulx/lua/ulx/modules/cl/xgui_client.lua:121
     4. Call - addons/ulib/lua/ulib/shared/hook.lua:168
      5. fn - addons/ulib/lua/ulib/cl_init.lua:45
       6. unknown - addons/ulib/lua/ulib/shared/hook.lua:168
        7. LocalPlayer - [C]:-1
         8. unknown - addons/utime/lua/autorun/cl_utime.lua:138
Unfortunately I am no good with lua and have no idea how to fix it :(
[/url]
Re: APromote GUI
« Reply #16 on: November 12, 2012, 07:20:03 pm »
Quote from: Lead4u last active
Last Active:
    April 25, 2012, 11:03:13 PM
As majority of the GUI code was redone in Gmod13 (as Stickly Man can attest, with the 4398489230^2 fixes he did to XGUI), it's likely not soon coming unless you try to reach the author by PM.
He's not been here since months before GM13 was released.
Re: APromote GUI
« Reply #17 on: November 13, 2012, 09:16:06 am »
Ah the dreaded panellist. I may be able to ping the author and see what he's up to-- otherwise he pretty much used the code I had in a different XGUI panel, and it should be a 'relatively' simple fix.
Offline Wully616
    • WullysGamers
Re: APromote GUI
« Reply #18 on: December 15, 2012, 10:02:10 am »
Did you manage to get a hold of the author stickly? I think wrex had a fixed version of this or the non-gui version of auto promote, but I can't get a hold of him either.
[/url]
Offline justinboggs
Re: APromote GUI
« Reply #19 on: December 17, 2012, 02:11:20 am »
is there anyone that knows how to fix that i need a copy of this also
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
Re: APromote GUI
« Reply #20 on: December 22, 2012, 11:30:07 pm »
I've spoken with Lead4u on steam to see if he was going to update this at all. He told me this, "When I have time I'll fix it, maybe sometime this winter. At this moment it will remain broken unless someone wants to pick it up, and fix it as someone did to utime from what I've heard."
Offline emilhem
Re: APromote GUI
« Reply #21 on: December 23, 2012, 05:54:05 am »
I'm almost finished with a fix for AutoPromote (the one without the GUI/xgui) so it will work with gmod 13.
I'll post it in the AutoPromote topic when it's done!
Offline TweaK
    • Garry's Mod Engineers
Re: APromote GUI
« Reply #22 on: January 11, 2013, 04:37:36 pm »
Re: APromote GUI
« Reply #23 on: March 04, 2013, 11:04:52 am »
I started to work on this (the cool gui version of this). After speaking with lead4u on steam for a few minutes, and than looking at some GWEN documents I've decided that this might not be too hard to fix as Sticky Man said himself. So I'll hopefully get this fixed by the end of the month because I'm busy with other addons and gamemodes I'm making...
So towards the people who are wanting this back, check back on this thread for an update.
Edit:
Well, I didn't download the one from above, and I downloaded a broken version still... so ofc it didn't work so I assumed it still didn't work. Well I guess my "work" here is done. Sorry for any confusion I created.
« Last Edit: March 04, 2013, 11:28:52 pm by chaos13125 »
Offline delagious
Re: APromote GUI
« Reply #24 on: March 05, 2013, 06:57:54 pm »
Edit:
So you aren't doing anything with this?
Re: APromote GUI
« Reply #25 on: March 05, 2013, 07:09:19 pm »
Offline delagious
Re: APromote GUI
« Reply #26 on: March 07, 2013, 07:59:43 pm »
Why would he if that one is working?
I'm sorry his reply was just really confusing. Sounds great that it's working.
After adding this to my server and restarting the server and logging in I get this error in console:
[ERROR] lua/includes/extensions/table.lua:51: bad argument #1 to 'pairs' (table expected, got nil)
  1. pairs - [C]:-1
   2. Empty - lua/includes/extensions/table.lua:51
    3. fn - addons/ulx/lua/ulx/modules/cl/xgui_client.lua:428
     4. func - addons/ulib/lua/ulib/client/cl_util.lua:22
      5. unknown - lua/includes/modules/net.lua:31
« Last Edit: March 07, 2013, 08:21:19 pm by delagious »
Re: APromote GUI
« Reply #27 on: March 07, 2013, 08:30:21 pm »
Working copy of Utime installed on your server too?
(First post, though actual code/links outdated, say Utime is required)
Offline delagious
Re: APromote GUI
« Reply #28 on: March 08, 2013, 02:59:16 pm »
Yes my Utime is working like a champ and I downloaded the dropbox version of APromote provided in TweaK's reply.
I put it in my addons, stopped the server, started the server and joined then got that error.
Offline pa1n
Re: APromote GUI
« Reply #29 on: May 17, 2013, 11:07:11 am »
I also have the same issue. Utime works but autopromote gui is not working.
Got it working.. I had to add the files into the ulx folder... Seems to be mis-packed in the download for the addon.
« Last Edit: May 17, 2013, 11:11:52 am by pa1n »
