Author Topic: Advanced Cleanup! (Includes Chat Commands.)  (Read 53484 times)
« on: September 24, 2011, 09:24:55 am »
Advanced Cleanup
I have found that some times I only wanted to cleanup a specific prop rather then a specific player, but I could not find a prop protection that does that.
So I made this.
--Updates--
Quote from: Completed Updates
1. The Next Update Will Include: A menu that can be brought up quickly and easily! (In the Developer version.)
? In addition to the next update:This will no longer require you to replace any files, and will be accessible through a console command or chat command.
2. Surprise: Some chat commands have been added, including RynO-SauruS's decal cleanup command. (!nolag [Freeze props.], !clnup [Cleanup.], !dcals [Clear Decals.], !ups [Bring up the menu.])
3. Some minor errors have been fixed. The menu now shows up, and the ULib.tsay no longer spams.
4. No longer uses ULib.tsay
5. No longer depends on ULX, the console command is hf_clnstr (However having ULX gives you some pluses.)
6. Added the ability to use the command through console.
7. Added a map cleanup ("hf_clnstr *"). ( the !clnup chat commands can still be used but only if you have ULX. )
--Instructions--
Use this SVN link to download https://github.com/KioFox/GLua-Projects.git/trunk/ULX-Cleanup
The SVN link is non-brows-able and will give you a 404 if you try to go to it in your browser.
Need help with SVN? No problem there is an excellent post here on the forums that can help you out.
--Notes--
Please Use The SVN Link To Download: https://github.com/KioFox/GLua-Projects.git/trunk/ULX-Cleanup
« Last Edit: January 21, 2013, 12:39:52 am by HeLLFox_15 »
Offline strategos
  • I wanna be the guy
    • Community
Re: UPS Menu! [v1.0]
« Reply #1 on: October 02, 2011, 10:33:40 pm »
Did the new ulx update break this? I can't seem to get it working...
« Reply #2 on: October 07, 2011, 02:12:04 pm »
Hmm, must have broken it, because it worked, when I was testing it. If you have a server I can join you and see whats up.
Also I would like to know how your installing it, because you do need the original UPS, and you take my file and overwrite the file in UPS.
Then you put the add-on in.
[EDIT-JamminR] - Corrected "URS" to "UPS"
[EDIT-HeLLFox_15] - I don't remember fixing it so did you fix it for me? If you did thanks.
« Last Edit: October 14, 2011, 03:33:24 pm by HeLLFox_15 »
« Reply #3 on: October 07, 2011, 05:05:33 pm »
UPS*
Offline strategos
    • Community
« Reply #4 on: October 07, 2011, 06:56:01 pm »
I'm installing it into addons and yes I am overwriting. I am also using URS if that makes a difference.
« Reply #5 on: October 07, 2011, 09:01:04 pm »
Having URS shouldn't affect anything.
Speaking of URS... I need to finish it still.
« Reply #6 on: October 14, 2011, 03:26:38 pm »
LOL, I have no idea why I wrote URS, guess I was tired that time, and did not bother to re-read my old posts. Its a UPS Menu and has nothing to do with URS.
I will be very great-full if some one offers to help me with this menu.
I will add chat commands to work with it as well but first I am planing to make a GUI that I am having trouble with, PM me and I will tell you exactly what I would like to do with the GUI for it. I would expload with joy if some one helps me make this a plugin for XGUI.
« Last Edit: December 25, 2011, 01:34:47 am by HeLLFox_15 »
« Reply #7 on: October 31, 2011, 09:39:11 pm »
I have got the menu to work now only one thing that I need help with. The spacing of the objects in the menu, because currently they just all overlap, creating a big mess.
Re: UPS Menu! [v1.0.0.1] (Includes Latest Work In Progress Version!)
« Reply #8 on: November 01, 2011, 07:47:27 pm »
I have made some updates in the first post, regarding the menu, I have also added clearer installation instructions.
I hope that peaple like this addon so far, and I would like to talk to Stickly Man! about adding this into XGUI, and if this addon even has potential to be in the XGUI.
Offline krooks
  • I don't like video games.
    • Diamond Krooks
« Reply #9 on: November 04, 2011, 04:04:11 pm »
Looks really nice! Good work!
My TTT server. Join the fun!
Re: UPS Menu! (Includes Chat Commands.)
« Reply #10 on: November 05, 2011, 01:09:08 pm »
Yet Another Update!  ;D
I have added some chat commands.
And Have also made a menu.
Updated First Post.
EDIT: Oh and thanks to every one who is helping and supporting me. I will make a list of names shortly.
EDIT: I have found an error that will make the menu it self not come up, I am working on fixing it. FIXED
« Last Edit: November 08, 2011, 09:06:47 am by HeLLFox_15 »
« Reply #11 on: December 25, 2011, 12:07:53 am »
Ever since the recent Gmod updates the menu, does not seem to be showing up. Can some one look at the code and tell me what's up.
I am also working on a script that will disable things like wall hacks, it will also prevent some fatal errors, that may crash servers.
The script will be in the next update, if I can get every thing working, and don't worry you will have the ability to toggle it on and off.
The download will also be in Zip format, because I no longer use WinRar, I have switched to 7zip.
Also I would really like to see more downloads on this, so tell me what should I add to this?
Edit: Recently a person said that he is going to steal this and say that he made it, and blah blah blah, if you see some thing like that please find a way to let people know it was made by me, because I worked really hard on this and it will be a shame, if some one took credit for my hard work. Speaking of saying that I made it, I should really add some text on the bottom right corner that says that I made it.
« Last Edit: December 25, 2011, 01:35:27 am by HeLLFox_15 »
« Reply #12 on: April 19, 2012, 01:36:49 am »
Ok, so I am back, and I will be updating this some time around next week. I will try to get a nicer looking menu, and the anti-cheat may come a bit later.
I am not making any promises but, I may add some new commands to this.
Here is the SVN link. (updated first post.)
https://pnhscripts.googlecode.com/svn/trunk/hellfox/ups_menu
« Last Edit: June 18, 2012, 08:13:56 pm by HeLLFox_15 »
« Reply #13 on: June 03, 2012, 06:16:57 pm »
Updated!
7. Added a map cleanup ("hf_clnstr s*") and a map reset ("hf_clnstr *"). ( the !clnup chat commands can still be used but only if you have ULX. )
Offline thegtz
Re: Advanced Cleanup! (Includes Chat Commands.)
« Reply #14 on: June 17, 2012, 11:21:48 pm »
SVN link is not working.
