Author Topic: Advanced Cleanup! (Includes Chat Commands.)  (Read 53484 times)
Re: Advanced Cleanup! (Includes Chat Commands.)
« Reply #15 on: June 18, 2012, 02:26:56 pm »
Dig a little deeper (up the url chain)
Doing so, I found it.
Specifically, it's been moved to https://pnhscripts.googlecode.com/svn/trunk/hellfox/ups_menu/
« Reply #16 on: June 18, 2012, 08:15:05 pm »
SVN link is not working.
( Sorry every one I moved it and forgot to update the links here that's why it was broken before.  :-[ )
I updated the links they should work now.
« Last Edit: June 20, 2012, 02:40:43 pm by HeLLFox_15 »
Offline brandon5050
« Reply #17 on: August 23, 2012, 04:55:44 am »
Well it's working for me, are you sure you've got Tortoise SVN?
« Reply #18 on: November 28, 2012, 07:57:44 am »
Hello again every one, this should work for Garrysmod 13, how ever there is a 200% chance. That the menu still does not work, sorry about that... but that really does not matter because as long as the command it self works.
If you have any suggestions or ideas I will add them when I move to GitHub.
Yes I am moving to GitHub because I have heard many good things about it plus I want to stop using the current repository as soon as I can because I share it with a friend, who now hates me... so yea...
Offline ViktorK
« Reply #19 on: January 01, 2013, 07:40:51 am »
Hi,
you've forgot to add clientside lua file into ups_menu addon.
[AddCSLuaFile] Couldn't find 'upsmenu/ups_menu.lua' (@addons/ups_menu/lua/autorun/init.lua (line 7))
Couldn't include file 'upsmenu\ups_menu.lua' (File not found) (@addons/ups_menu/lua/autorun/init.lua (line 12))
Please try to fix it asap. :-)
« Reply #20 on: January 04, 2013, 02:00:15 am »
Hi,
Thanks very much, I will fix it and add it to my Github as soon as I can. (Probably tomorrow.)
Also sorry for the bump, I accidentally deleted my previous post instead of editing it.
« Last Edit: January 04, 2013, 02:02:29 am by HeLLFox_15 »
Offline thegtz
« Reply #21 on: January 07, 2013, 08:45:36 pm »
Has the new svn at github been posted or should we still use the old svn link?
« Reply #22 on: January 08, 2013, 08:41:33 am »
These are the github links you can use via SVN.
« Reply #23 on: January 08, 2013, 09:03:58 am »
My add-on will be updated and put on Github soon, I promise. (Been busy lately.)
Also I am not quite sure because maybe I misunderstood but this may be getting put into UPS ( no, not United Postal Service ). So I want to make sure the code is super clean and sparkly before uploading it to my Github. ( If any one wants to help me clean my code they are welcome to do so. )
Offline ViktorK
« Reply #24 on: January 12, 2013, 01:18:51 pm »
OK we're waiting for it ! :-), don't forget to us !! ;) :D
« Reply #25 on: January 15, 2013, 11:31:13 pm »
Here you go, https://github.com/KioFox/GLua-Projects.git/trunk/ULX-Cleanup
Edit: I assume this is working fine, because I have not gotten any complaints yet :)
« Last Edit: January 19, 2013, 01:18:42 am by HeLLFox_15 »
Offline ViktorK
« Reply #26 on: January 21, 2013, 11:24:46 am »
Hi,
it seems that almost everything is working, but this warning gives me console:
Couldn't include file 'clnupcmd\clnup_control.lua' (File not found) (@addons/ulx-cleanup/lua/autorun/init.lua (line 11))
but cleanup clean map, but Ive only used it for cleanup everything, not as ususal custopm settings.
Take a look into in :-)
« Reply #27 on: January 21, 2013, 01:44:00 pm »
Hi,
Are you sure you have every thing correctly installed? Because I am running the exact same version of this on my server, and I am not getting that error.
