Author Topic: Few questions  (Read 6571 times)
Offline Mathew75
Few questions
« on: March 08, 2012, 09:08:45 am »
Hello, I'm gonna be running a community called VTech. And the gamemode will be DarkRP. Now I'm planing on using your guys admin menu for sure. But theres a few things I want to edit.
1) How do I disable the public carves like (Someone) gave <Player> superadmin! or like (Someone) banned <Player> for 1440 mins! So you get the point, is there a way I can make this private as in only Admin+ can see this?
2) I'm gonna have one 1 Donator group and I'm wondering if there's anyway I can set there own prop limit from others?
Thank you.
Re: Few questions
« Reply #1 on: March 08, 2012, 06:18:07 pm »
There is a cvar in your ulx config file.  Just toggle it to the appropriate setting.  I believe there is also a command that you give people access to so they can see the echos.  I don't know the exact folders/files/cvars or I'd be more exact.
URS Beta does exactly this along with tool and prop restrictions (specific to ulx groups at the moment).  I have plans to rewrite this completely for Gmod 13, although I haven't gotten far on that yet.
Offline Mathew75
Re: Few questions
« Reply #2 on: March 09, 2012, 07:54:01 pm »
Anyone that may know where? the toggle command for the echo? Thanks Aaron113
Re: Few questions
« Reply #3 on: March 10, 2012, 08:03:54 am »
gmod_root/data/ulx/confix.txt
Around line 30 change ulx logEcho to 1 if it isn't already.  Then there should be a command, which I'm sure you can figure it out through XGUI, that you give people access to.  It is defaulted to 1, so this may already be like you're asking and you just don't realize it.
Re: Few questions
« Reply #4 on: March 10, 2012, 09:48:59 am »
Additionally all, if the file isn't there, don't panic...just copy it TO that location from gmod/addons/ulx/data/ ... again, copy it to where Aaron says first, don't edit the file in addons.
Offline Mathew75
Re: Few questions
« Reply #5 on: March 10, 2012, 10:20:20 am »
If I use 0, does that just show the echo to admins?
Also is there a way I can make my admins/donators groups global, if I have more then 1 server?
« Last Edit: March 10, 2012, 10:28:11 am by Mathew75 »
Re: Few questions
« Reply #6 on: March 10, 2012, 12:37:02 pm »
Read the file. It explains quite well.
No easy way, no.
MrPresident released some code in our Developer's corner section of the forum that uses SQL and Lua
Offline Mathew75
Re: Few questions
« Reply #7 on: March 11, 2012, 11:19:07 am »
Do you know when he will be releasing it?
Re: Few questions
« Reply #8 on: March 11, 2012, 02:34:44 pm »
Already released. as stated. It's in developers corner section of our forum.
You must know SQL and Lua to use.
