Author Topic: Motd White  (Read 16655 times)
Offline Digital Spit
Re: Motd White
« Reply #1 on: July 16, 2012, 12:58:06 am »
This is a Garry's Mod problem...
Just wrote a panel from scratch in my gamemode I'm working on to test it. Don't even have ULX/ULib installed.
edit: I tried the HTMLPanel:SetHTML control as well and it still shows a white screen. This leads me to believe that it's not so much a loading issue as it is a problem with the actual HTML panel itself. Probably webkit is broken in a recent patch to GMod.
« Last Edit: July 16, 2012, 01:02:21 am by MrPresident »
Re: Motd White
« Reply #2 on: July 16, 2012, 07:01:35 am »
Thank you very much with assisting me in my issue Mr President.
Re: Motd White
« Reply #3 on: July 18, 2012, 04:06:17 pm »
I think this post is related to this...
If videos are not working remove the "http://" part, because apperently garry broke comment blocking and when you input some thing like this...
http://www.youtube.com/watch?v=OFUdKVN4ivQ
the server sees this...
http:
Other wise it should work unless your getting a plugin related error. ( Probably meaning you need to install or update flash player. )
« Last Edit: July 18, 2012, 04:08:07 pm by HeLLFox_15 »
Re: Motd White
« Reply #4 on: July 22, 2012, 07:30:25 am »
Ha ha ha. Garry broke comments? He can't even write a proper tokenizer and lexer? For shame...
Offline Assault_Trooper
    • Trooper's Gaming Servers
Re: Motd White
« Reply #5 on: July 24, 2012, 05:18:32 am »
It can be fixed by docking the HTML panel. It's the HTML:SetSize what breaks the panel and makes it white.
local Panel = vgui.Create( "DPanel" )
Panel:SetSize( 500, 500 )
Panel:Center()
local HTML = vgui.Create( "HTML", Panel )
HTML:Dock( FILL )
Re: Motd White
« Reply #6 on: July 24, 2012, 03:38:52 pm »
I can confirm that this works. Thanks Assault_Trooper for providing the solution to this issue!
*edit* As it turns out I can not give Karma.. so +1 Virtual Karma for you! Maybe one of the UStaff guys can make it official. :P
Offline Wully616
    • WullysGamers
Re: Motd White
« Reply #7 on: July 24, 2012, 05:42:06 pm »
Would someone be able to post motdmenu.lua with this fix? I don't have a clue when it comes to lua.
[/url]
Re: Motd White
« Reply #8 on: July 24, 2012, 06:01:12 pm »
Karma has been given, thanks Assault_Trooper! :)
I have fixed the issue in motdmenu.lua and am finishing up some changes in XGUI, I'm going to try my hardest to get it released or at least pushed to SVN by tonight.
Offline Wully616
    • WullysGamers
Re: Motd White
« Reply #9 on: July 24, 2012, 06:13:16 pm »
That's great! No rush :)
[/url]
Re: Motd White
« Reply #10 on: July 24, 2012, 06:49:15 pm »
Whoo okay, turns out I have more to do than I thought, so we won't be pushing tonight lol. Here is the ulx.showMotdMenu() function from the motdmenu.lua that I fixed:
\ulx\lua\ulx\modules\cl\motdmenu.lua line 6
This isn't the full code, replace this with the existing ulx.showMotdMenu() function only!
function ulx.showMotdMenu()
local window = vgui.Create( "DFrame" )
window:SetSize( ScrW()*0.9, ScrH()*0.9 )
window:SetSize( 640, 480 )
window:Center()
window:SetTitle( "ULX MOTD" )
window:SetVisible( true )
window:MakePopup()
local panel = vgui.Create( "DPanel", window )
local html = vgui.Create( "HTML", panel )
local button = vgui.Create( "DButton", window )
button:SetText( "Close" )
button.DoClick = function() window:Close() end
button:SetSize( 100, 40 )
button:SetPos( (window:GetWide() - button:GetWide()) / 2, window:GetTall() - button:GetTall() - 10 )
panel:SetSize( window:GetWide() - 20, window:GetTall() - button:GetTall() - 50 )
panel:SetPos( 10, 30 )
html:Dock( FILL )
if not isUrl then
html:SetHTML( file.Read( "ulx/motd.txt" ) )
html:OpenURL( url )
*Disclaimer! Code was not really approved by Megiddo and may be slightly changed before fix is released! But it still should work just fine :P
« Last Edit: July 31, 2012, 09:09:30 am by Stickly Man! »
Re: Motd White
« Reply #11 on: July 24, 2012, 07:08:33 pm »
What do you mean you can't give Karma, MrP?
Re: Motd White
« Reply #12 on: July 25, 2012, 07:34:51 am »
Not an option for me. :P I think it used to be before you guys made me a Global Mod, but I currently do not have the ability to modify a user's karma.
Offline Wully616
    • WullysGamers
Re: Motd White
« Reply #13 on: July 25, 2012, 10:36:35 am »
window:Center()
window:MakePopup()
html:Dock( FILL )
if not isUrl then
html:OpenURL( url )
I tried this motdmenu.lua, it work's but only shows the clients cached motd from a previous server they have joined. I've got it set to the URL option.
I get this error in console when joining the server:
LX version 3.54 loaded.
[@ulib\client\cl_util.lua:9] Received bad RPC, invalid function (ulx.rcvMotd)!
Is that anything to do with it or am I missing something?
[/url]
Re: Motd White
« Reply #14 on: July 25, 2012, 11:10:45 am »
Thanks for the support guys!
