Author Topic: Sourcebans & ULX/ULib  (Read 185614 times)
Offline centran
Re: Sourcebans & ULX/ULib
« Reply #120 on: February 03, 2014, 12:49:43 pm »
Thanks dataviruset for adding to this.
Is there any way to make it actually report the banning admin's name to Sourcebans?
The person needs to be added in Sourcebans and then they should show up properly. Otherwise it will send as admin 0 which is console. So make sure the admin is setup properly in Sourcebans. This script will not add admins from ulx to sourcebans.
« Last Edit: February 03, 2014, 12:52:44 pm by centran »
« Reply #121 on: February 03, 2014, 02:18:47 pm »
Thanks. :)
Offline TechNo
« Reply #122 on: February 09, 2014, 05:44:11 am »
When i am trying to ban a user, i get this error.
What have i done wrong :/? I followed the guide.
« Reply #123 on: February 09, 2014, 12:02:37 pm »
Just a question:
When SourceBans 2.0 launches, will we need to make any changes to anything?
I'm assuming most likely yes, but I don't know...
Offline Storm
« Reply #124 on: March 19, 2014, 06:52:51 am »
I saw earlier in this post that there might be a ULX integration with Sourcebans. Might this still be a possibility at some point? I find setting this up myself would be a bit difficult!
Offline Arhenox
« Reply #125 on: April 21, 2014, 12:53:50 pm »
Almost everything is working ok, except Sourcebans XD
After map change - there's no problem, but after few minutes I get "[SourceBans.lua] The server has lost connection to the database. Retrying..." error, then when I try to ban someone  - bans don't get saved in database. Recently I've changed my hosting provider, but their MySQL settings are exactly the same (although I didn't get this error before). I've added some notifymessage functions to the script, so it would notify me if there were any problems with DB, but they're not showing in the server console (additionaly - message in BanOnSuccess function doesn't show up too, so it's not being called). Any ideas?
Edit: Everything is working OK right now, I've added checking is database connected and if not, database:connect(); :)
« Last Edit: April 22, 2014, 01:51:22 am by Arhenox »
Offline Rhapsody
« Reply #126 on: May 26, 2014, 10:10:39 pm »
Okay, I've done a crapload of fixes (as you also forgot the gatekeeper), but !sban won't put bans onto the SourceBans database.
Dat empty banlist:
Anyway, I've found the working gatekeeper lua for gmod 13. Place it in srcds/orangebox/garrysmod/lua/includes/modules:
gatekeeper={}
local spawning={}
gameevent.Listen("player_connect")
gameevent.Listen("player_disconnect")
function gatekeeper.Drop(userid, reason)
    game.ConsoleCommand(string.format("kickid %d %s\n",userid,reason:gsub(';|\n','')))
function gatekeeper.GetNumClients()
    local active=#player.GetAll()
    return {spawning=#spawning, active=active, total=#spawning+active}
function gatekeeper.GetUserByAddress(addr)
    for k,v in pairs(player.GetAll()) do
        if(v:IPAddress()==addr) then
            return v:UserID()
hook.Add("player_connect", "GateKeeper", function(data)
    local ret=hook.Call("PlayerPasswordAuth", GAMEMODE, data.name, "", data.networkid, data.address)
    print(ret)
    if(type(ret)=="string") then
        gatekeeper.Drop(data.userid, ret)
        return
    elseif(type(ret)=="boolean") then
        if(ret) then
            gatekeeper.Drop(data.userid, "Bad Password")
            return
    table.insert(spawning, data.userid)
end)
hook.Add("player_disconnect", "GateKeeper", function(data)
    for k,v in pairs(spawning) do
        if(data.userid==v) then
            table.remove(spawning, k)
            break
end)
hook.Add("PlayerInitialSpawn", "GateKeeper", function(ply)
        if(ply:UserID()==v) then
            break
end)
function gatekeeper.DropAllClients(reason)
        gatekeeper.Drop(v, reason)
This may seem like quite a bump, but I've used the code from this post to add gatekeeper, and it's working perfectly. However, one of the things that I've noticed, regardless as to whether gatekeeper is installed or not, is that Sourcebans fails to report the name of the person who banned the player, and instead says CONSOLE. Is there anything I can do to fix this?
Offline Xer0n
« Reply #127 on: May 28, 2014, 01:31:50 am »
I did your "second" option to incorporate everything into one command, but ULX seems to be relying solely on Sourcebans and not writing anything to banned_users.cfg and the "listid" function & banlist in ULX are empty when blocking.
I fear that if the bans aren't being written to ULX when a blocked user joins, should the website go down all of the bans will be exempt and be a security risk.
When I was on evolve and a user joined that was source banned it would write that steamid into the server preventing them from even connecting and getting to "Sending Client Info.." on the first connect until the ban was removed.
Also when I click on the 'SourceBans' tab in ULX, it shows a bunch of steamid's.. I don't know what this is showing me.  Is it everyone banned on this server?
« Last Edit: May 28, 2014, 01:36:08 am by Xer0n »
« Reply #128 on: May 28, 2014, 10:11:44 am »
ULX does not natively support SourceBans- what that is referring to is bans that are stored in the Source Engine (banned_users.cfg, via banid command). ULX currently uses these bans in conjuction with data from data/ulib/bans.txt to store bans- any bans that show up in that menu are bans that don't have any data from the bans.txt file.
Offline Xer0n
« Reply #129 on: May 28, 2014, 10:30:27 pm »
Ok, my only concern is that we run 8 GMod servers and when we ban a user from one, they keep trying to connect to other servers.  They never actually get "source banned" according to the ULX Ban Menu.  It gets pretty annoying when sourcebans has to keep blocking.
Evolve would write the ban into the engine, and on it's 5 minute checkup it would remove any that don't exist as active on sourcebans.. maybe I'm just used to that.
Offline [R.B Team]FinnTheHuman
« Reply #130 on: July 01, 2014, 09:03:20 am »
Have a error
[ERROR] addons/ulib/lua/ulib/server/player.lua:267: '<eof>' expected near 'end'
  1. unknown - addons/ulib/lua/ulib/server/player.lua:0
Here`s a player.lua
   Title: Player
   Holds some helpful player functions.
   Table: slapSounds
   These are the sounds used for slaps.
local slapSounds = {
   "physics/body/body_medium_impact_hard1.wav",
   "physics/body/body_medium_impact_hard2.wav",
   "physics/body/body_medium_impact_hard3.wav",
   "physics/body/body_medium_impact_hard5.wav",
   "physics/body/body_medium_impact_hard6.wav",
   "physics/body/body_medium_impact_soft5.wav",
   "physics/body/body_medium_impact_soft6.wav",
   "physics/body/body_medium_impact_soft7.wav",
   Function: slap
   Slaps an entity, can be a user or any entity.
   Parameters:
      ent - The target ent.
      damage - *(Optional, defaults to 0)* The amount of damage to inflict on the entity.
      power - *(Optional, defaults to 30)* The power of the slap.
      nosound - *(Optional, defaults to false)* If true, no sound will be played.
function ULib.slap( ent, damage, power, nosound )
   if ent:GetMoveType() == MOVETYPE_OBSERVER then return end -- Nothing we can do.
   damage = damage or 0
   power = power or 500
   if ent:IsPlayer() then
      if not ent:Alive() then
         return -- Nothing we can do.
      if ent:InVehicle() then
         ent:ExitVehicle()
      if ent:GetMoveType() == MOVETYPE_NOCLIP then
         ent:SetMoveType( MOVETYPE_WALK )
   if not nosound then -- Play a slap sound
      local sound_num = math.random( #slapSounds ) -- Choose at random
      ent:EmitSound( slapSounds[ sound_num ] )
   local direction = Vector( math.random( 20 )-10, math.random( 20 )-10, math.random( 20 )-5 ) -- Make it random, slightly biased to go up.
   ULib.applyAccel( ent, power, direction )
   local angle_punch_pitch = math.Rand( -20, 20 )
   local angle_punch_yaw = math.sqrt( 20*20 - angle_punch_pitch * angle_punch_pitch )
   if math.random( 0, 1 ) == 1 then
      angle_punch_yaw = angle_punch_yaw * -1
   ent:ViewPunch( Angle( angle_punch_pitch, angle_punch_yaw, 0 ) )
   local newHp = ent:Health() - damage
   if newHp <= 0 then
         ent:Kill()
         ent:Fire( "break", 1, 0 )
      return
   ent:SetHealth( newHp )
   Function: kick
   Kicks a user.
   Parameters:
      ply - The player to kick.
      reason - *(Optional)* The reason to give for kicking.
function ULib.kick( ply, reason, calling_ply )
   if reason and calling_ply ~= nil then
      local nick = calling_ply:IsValid() and string.format( "%s(%s)", calling_ply:Nick(), calling_ply:SteamID() ) or "Console"
      ply:Kick( string.format( "Kicked by %s (%s)", nick, reason or "[ULX] Kicked from server" ) )
      ply:Kick( reason or "[ULX] Kicked from server" )
   Function: ban
   Bans a user.
   Parameters:
      ply - The player to ban.
      time - *(Optional)* The time in minutes to ban the person for, leave nil or 0 for permaban.
      reason - *(Optional)* The reason for banning
      admin - *(Optional)* Admin player enacting ban
   Revisions:
      v2.10 - Added support for custom ban list
function ULib.ban( ply, time, reason, admin )
   if not time or type( time ) ~= "number" then
      time = 0
   ULib.addBan( ply:SteamID(), time, reason, ply:Name(), admin )
   -- Load our currently banned users so we don't overwrite them
   if ULib.fileExists( "cfg/banned_user.cfg" ) then
      ULib.execFile( "cfg/banned_user.cfg" )
   Function: kickban
   Kicks and bans a user.
   Parameters:
   Revisions:
function ULib.kickban( ply, time, reason, admin )
      time = 0
   Function: addBan
   Helper function to store additional data about bans.
   Parameters:
      steamid - Banned player's steamid
      time - Length of ban
      reason - *(Optional)* Reason for banning
      name - *(Optional)* Name of player banned
      admin - *(Optional)* Admin player enacting the ban
   Revisions:
      2.10 - Initial
      2.40 - If the steamid is connected, kicks them with the reason given
function ULib.addBan( steamid, time, reason, name, admin )
        local strTime = time ~= 0 and string.format( "for %s minute(s)", time ) or "permanently"
        local showReason = string.format( "Banned %s: %s", strTime, reason )
        if ( sourcebans ) then
                sourcebans.BanPlayerBySteamID( steamid, time*60, reason, admin, name )
                local players = player.GetAll()
                for i=1, #players do
                        if players[ i ]:SteamID() == steamid then
                                ULib.kick( players[ i ], showReason, admin )
                -- This redundant kick code is to ensure they're kicked -- even if they're joining
                game.ConsoleCommand( string.format( "kickid %s %s\n", steamid, showReason or "" ) )
                game.ConsoleCommand( string.format( "banid %f %s kick\n", time, steamid ) )
                game.ConsoleCommand( "writeid\n" )
        local admin_name
        if admin then
                admin_name = "(Console)"
                if admin:IsValid() then
                        admin_name = string.format( "%s(%s)", admin:Name(), admin:SteamID() )
        local t = {}
        if ULib.bans[ steamid ] then
                t = ULib.bans[ steamid ]
                t.modified_admin = admin_name
                t.modified_time = os.time()
                t.admin = admin_name
        t.time = t.time or os.time()
        if time > 0 then
                t.unban = ( ( time * 60 ) + os.time() )
                t.unban = 0
        if reason then
                t.reason = reason
        if name then
                t.name = name
        ULib.bans[ steamid ] = t
        file.Write( ULib.BANS_FILE, ULib.makeKeyValues( ULib.bans ) )
   local admin_name
   if admin then
   local t = {}
   if time > 0 then
      t.unban = 0
   if reason then
      t.reason = reason
   if name then
      t.name = name
   ULib.fileWrite( ULib.BANS_FILE, ULib.makeKeyValues( ULib.bans ) )
   Function: unban
   Unbans the given steamid.
   Parameters:
      steamid - The steamid to unban.
   Revisions:
      v2.10 - Initial
function ULib.unban( steamid )
        --Default banlist
        if file.Exists( "cfg/banned_user.cfg", "GAME" ) then
                ULib.execFile( "cfg/banned_user.cfg", "GAME" )
                sourcebans.UnbanPlayerBySteamID( steamid, "In game unban", nil)
                ULib.queueFunctionCall( game.ConsoleCommand, "removeid " .. steamid .. ";writeid\n" ) -- Execute after done loading bans
        --ULib banlist
        ULib.bans[ steamid ] = nil
local function doInvis()
   local remove = true
   for _, player in ipairs( players ) do
      local t = player:GetTable()
      if t.invis then
         remove = false
         if player:Alive() and player:GetActiveWeapon():IsValid() then
            if player:GetActiveWeapon() ~= t.invis.wep then
               timer.Simple( 0.05, function () ULib.invisible( player, true, t.invis.vis ) end )
               t.invis.wep = player:GetActiveWeapon()
   if remove then
      hook.Remove( "Think", "InvisThink" )
   Function: invisible
   Makes a user invisible
   Parameters:
      ply - The player to affect.
      bool - Whether they're invisible or not
      visibility - *(Optional, defaults to 0)* A number from 0 to 255 for their visibility.
   Revisions:
      v2.40 - Removes shadow when invisible
function ULib.invisible( ply, bool, visibility )
   if not ply:IsValid() then return end -- This is called on a timer so we need to verify they're still connected
   if bool then
      visibility = visibility or 0
      ply:DrawShadow( false )
      ply:SetMaterial( "models/effects/vol_light001" )
      ply:SetRenderMode( RENDERMODE_TRANSALPHA )
      ply:Fire( "alpha", visibility, 0 )
      ply:GetTable().invis = { vis=visibility, wep=ply:GetActiveWeapon() }
      if IsValid( ply:GetActiveWeapon() ) then
         ply:GetActiveWeapon():SetRenderMode( RENDERMODE_TRANSALPHA )
         ply:GetActiveWeapon():Fire( "alpha", visibility, 0 )
         ply:GetActiveWeapon():SetMaterial( "models/effects/vol_light001" )
         if ply:GetActiveWeapon():GetClass() == "gmod_tool" then
            ply:DrawWorldModel( false ) -- tool gun has problems
            ply:DrawWorldModel( true )
      hook.Add( "Think", "InvisThink", doInvis )
      ply:DrawShadow( true )
      ply:SetMaterial( "" )
      ply:SetRenderMode( RENDERMODE_NORMAL )
      ply:Fire( "alpha", 255, 0 )
      local activeWeapon = ply:GetActiveWeapon()
      if IsValid( activeWeapon ) then
         activeWeapon:SetRenderMode( RENDERMODE_NORMAL )
         activeWeapon:Fire( "alpha", 255, 0 )
         activeWeapon:SetMaterial( "" )
      ply:GetTable().invis = nil
   Function: refreshBans
   Refreshes the ULib bans.
function ULib.refreshBans()
   local err
   if not ULib.fileExists( ULib.BANS_FILE ) then
      ULib.bans = {}
      ULib.bans, err = ULib.parseKeyValues( ULib.fileRead( ULib.BANS_FILE ) )
   if err then
      Msg( "Bans file was not formatted correctly. Attempting to fix and backing up original\n" )
      if err then
         Msg( "Error while reading bans file was: " .. err .. "\n" )
      Msg( "Original file was backed up to " .. ULib.backupFile( ULib.BANS_FILE ) .. "\n" )
      ULib.bans = {}
   local default_bans = ""
      ULib.queueFunctionCall( game.ConsoleCommand, "writeid\n" )
      default_bans = ULib.fileRead( "cfg/banned_user.cfg" )
   --default_bans = ULib.makePatternSafe( default_bans )
   default_bans = string.gsub( default_bans, "banid %d+ ", "" )
   default_bans = string.Explode( "\n", default_bans:gsub( "\r", "" ) )
   local ban_set = {}
   for _, v in pairs( default_bans ) do
      if v ~= "" then
         ban_set[ v ] = true
         if not ULib.bans[ v ] then
            ULib.bans[ v ] = { unban = 0 }
   for k, v in pairs( ULib.bans ) do
      if type( v ) == "table" and type( k ) == "string" then
         local time = ( v.unban - os.time() ) / 60
         if time > 0 then
            game.ConsoleCommand( string.format( "banid %f %s\n", time, k ) )
         elseif math.floor( v.unban ) == 0 then -- We floor it because GM10 has floating point errors that might make it be 0.1e-20 or something dumb.
            if not ban_set[ k ] then
               ULib.bans[ k ] = nil
         Msg( "Warning: Bad ban data is being ignored, key = " .. tostring( k ) .. "\n" )
   -- We're queueing this because it will split the load out for VERY large ban files
   ULib.queueFunctionCall( function() ULib.fileWrite( ULib.BANS_FILE, ULib.makeKeyValues( ULib.bans ) ) end )
ULib.pcallError( ULib.refreshBans )
   Function: getSpawnInfo
   Grabs and returns player information that can be used to respawn player with same health/armor as before the spawn.
   Parameters:
      ply - The player to grab information for.
   Returns:
      Updates player object to store health and armor. Has no effect unless ULib.Spawn is used later.
function ULib.getSpawnInfo( player )
   local result = {}
   local t = {}
   player.ULibSpawnInfo = t
   t.health = player:Health()
   t.armor = player:Armor()
   if player:GetActiveWeapon():IsValid() then
      t.curweapon = player:GetActiveWeapon():GetClass()
   local weapons = player:GetWeapons()
   local data = {}
   for _, weapon in ipairs( weapons ) do
      printname = weapon:GetClass()
      data[ printname ] = {}
      data[ printname ].clip1 = weapon:Clip1()
      data[ printname ].clip2 = weapon:Clip2()
      data[ printname ].ammo1 = player:GetAmmoCount( weapon:GetPrimaryAmmoType() )
      data[ printname ].ammo2 = player:GetAmmoCount( weapon:GetSecondaryAmmoType() )
   t.data = data
-- Helper function for ULib.spawn()
local function doWeapons( player, t )
   if not player:IsValid() then return end -- Drat, missed 'em.
   player:StripAmmo()
   player:StripWeapons()
   for printname, data in pairs( t.data ) do
      player:Give( printname )
      local weapon = player:GetWeapon( printname )
      weapon:SetClip1( data.clip1 )
      weapon:SetClip2( data.clip2 )
      player:SetAmmo( data.ammo1, weapon:GetPrimaryAmmoType() )
      player:SetAmmo( data.ammo2, weapon:GetSecondaryAmmoType() )
   if t.curweapon then
      player:SelectWeapon( t.curweapon )
   Function: spawn
   Enhanced spawn player. Can spawn player and return health/armor to status before the spawn. (Only IF ULib.getSpawnInfo was used previously.)
   Clears previously set values that were stored from ULib.getSpawnInfo.
   Parameters:
      bool - If true, spawn will set player information to values stored using ULib.SpawnInfo
   Returns:
      Spawns player. Sets health/armor to stored defaults if ULib.getSpawnInfo was used previously. Clears SpawnInfo table afterwards.
function ULib.spawn( player, bool )
   player:Spawn()
   if bool and player.ULibSpawnInfo then
      local t = player.ULibSpawnInfo
      player:SetHealth( t.health )
      player:SetArmor( t.armor )
      timer.Simple( 0.1, function() doWeapons( player, t ) end )
      player.ULibSpawnInfo = nil
Offline Kerdizoume
« Reply #131 on: July 15, 2014, 01:39:57 pm »
Hey. I just spent this morning setting this up for my 2 servers. Everything seemed to be working, but when I did a test ban, it said (CONSOLE) banned him on TF2. Anyone else with a similar problem? I can't seem to find what's wrong...
Also, when I ban in-game and then unban via the web panel it doesn't work.
Offline Avoid
« Reply #132 on: July 15, 2014, 04:35:53 pm »
Hello,
this bug has been fixed in the newest version of ULX/ULib, so make sure you are running it aswell! :)
To SourceBans: I managed to get it working with this module found on FP here.
Hope I helped you, Avoid!
Offline Storm
« Reply #133 on: July 16, 2014, 06:21:10 am »
Avoid, if you got the fp version working, can I ask you a question? It says that ulx sb addon isn't supporting sb 2.0 and when I installed the 1.411 version it automatically updated to 2.0. The server.cfg needs to be changed, as stated there, to include the server id number. What I can see is 2.0 doesn't have a server id number. Did you have this problem? Thanks if you can help!
Offline Avoid
« Reply #134 on: July 16, 2014, 07:58:55 am »
That is weird, Sbans did not update to 2.0 for me, so I sticked to version 1.4.11 and it just works fine.
You could try downloading the version 1.4.11 and see if that does the trick for you!
Avoid
